changing primary chaincase oil question
Old Jul 6, 2019 | 07:44 PM
kwisor's Avatar
kwisor
Default changing primary chaincase oil question
hello
I have a 2001 dyna wide glide I have the t40 bolt I am reinstalling the drain bolt but it seems that it dose not want to tighten I am afraid it will go all the way into the cover and not tighten should I keep trying will it tighten. I have a 2nd question since I got the bike is has a cough it runs great but at idle it will cough and at speed it will cough it has a stage one kit on it do I need to re jet
kevin
Old Jul 6, 2019 | 08:29 PM
Screamin beagle's Avatar
Screamin beagle
Either pull the cover off and fix it with a heli coil or time cert or put some Teflon tape on it and tighten it "just enough" and fix it right when you have time. It does sound like your a little lean too...disclaimer: I'm no expert just made lots of mistakes along the way.
seniorsuperglideE8's Avatar
seniorsuperglideE8
If it's like the drain on my 02 Superglide it's a plug with pipe threads. It is slightly tapered and is supposed to fit with 4.1-4.6 mm extending from the bottom of the case. Some times if the drain is run too far in it may cause hairline cracks in the case and that could cause leaks/seeping of oil. Clean the drain of any oil residue and use some pipe thread sealant 565 on the threads (straight from my owners manual). If it's cracked you my have to have the hole welded/fixed then tap it out and use a straight bolt and "o" ring to seal it.
Old Jul 6, 2019 | 08:32 PM
Cobra1's Avatar
Cobra1
If it’s the same as my Heritage it is a 1/8” pipe plug. I wrap it with a little Teflon and screw it in. It does not get tight but just snug.
Old Jul 6, 2019 | 09:01 PM
kwisor's Avatar
kwisor
hello
thank you for the replys I did put Teflon tape on it and snugged it up I didn't think it got tight but I will keep a eye on it. road warrior I am no expert either so if running lean do I need to go next size larger on the jets?
thank you
kevin
Old Jul 6, 2019 | 11:15 PM
Blue Bob's Avatar
Blue Bob
Teflon tape on tapered pipe threads in castings is not usually recommended. The Teflon is so slippery that its very easy to over tighten and crack the casting. Tighten carefully if you do.
Old Jul 7, 2019 | 07:21 AM
John CC's Avatar
John CC
Originally Posted by Blue Bob
Teflon tape on tapered pipe threads in castings is not usually recommended...
Plus, when you take the plug out the Teflon turns into little threads that can make their way into places you don't want them. Pipe dope is a much better choice, IMHO.
Old Jul 7, 2019 | 08:44 PM
Rsbenden's Avatar
Rsbenden
I'll 2nd the pipe dope,it liquid Teflon n will dry w heat and solidify n keep it in place tight. Tape is a bad option imo.
ffron69
Jun 18, 2015 06:23 AM
brrrd
EVO
May 19, 2014 11:15 AM
sportster 883
Dec 31, 2009 08:54 PM
24guns
Nov 24, 2007 03:04 PM
Softtail Bob
Mar 14, 2007 05:34 PM
