Engine Build Time
Old Jan 20, 2014 | 08:26 PM
  #121
soft 02's Avatar
soft 02
I'd ship the whole case to DH as djl suggested.
Old Jan 20, 2014 | 09:13 PM
  #122
mud's Avatar
mud
Originally Posted by djl
I hear ya on the 117" although I don't see another $1000,
maybe $700 for cylinders and case bore;
right.
back in 2008 when I built my 121 inch monster
bore case - 195
cylinders - 440
Old Jan 20, 2014 | 09:38 PM
  #123
senna's Avatar
senna
Originally Posted by alansummrs
OK, here is my big news on the crank run-out, been churning this decision around and because of the pain involved of shipping a crank/pulling the case/splitting the case I had decided to take my chances and not do anything but I got an email from a local motorcycle mech here that had helped me before and he said he could help me get it done. I will pull the case(75% there already) and take it to him and he will split the case for me, ship it to Darkhorse(most likely) and then reassemble the case with Timken on the left and a new bearing on the right too(can't remember what kind - maybe y'all can help?).
Anyway looks like I will have more work ahead and more $$ into the build but should be interesting and a solid build.
Sorry djl, no 117", got to draw the line somewhere, in my books that would be at least another grand and I have planned my cams/throttle body/etc for a strong 107" and that is where I am heading.
Thanks for everybody's input on the crank decision - I was "split" over it but looks like crank repair is coming
Soft 02 - watch over me pulling that case, probably wont happen until next week. I have to work to pay the bills Thurs - Sun.
I agree with dji, send the whole bottom end in. Mine is there now. Crank true,weld,plug and ballance. Plus H beam rods and timken conversion with blue print reassymble.
And, I agree with you on having to stop spending money some where. I stopped at 107, figureing if I went to 117 I would need a larger TB new cylinders and possibly a switch to chain drive if you atart tearing up belts
Old Jan 20, 2014 | 09:41 PM
  #124
hell hound's Avatar
hell hound
good thread, very interested to see everything come together
also i am very jealous
you are not messin around with the specialty tools either
Old Jan 20, 2014 | 09:43 PM
  #125
HD Pilot's Avatar
HD Pilot
Yall are killing me on the 117"! I would have to make a lot of fast calls: Dont bore my cylinderss, don't order the AV&V springs I wanted, hold off on our compression plans, and I would have to see what Tman could do to swap the cams out. No, I think it is just too much to sort through and I probably would need a better clutch too - no?
Ok, I know I should talk to Darkhorse, but how do you ship a case? It has to be something pretty stout like wood and most of the carriers I know would probably tumble the box upside down a couple of times
My Indy said he could split the case, install the 2 bearings(cost of Timken included), provide and package the crank(I pay shipping), then once it comes back install the crank and put the case back together for $500.
Old Jan 20, 2014 | 09:52 PM
  #126
soft 02's Avatar
soft 02
Alan. Make a wood crate. Did you see the one I made in my crank thread. Some 5/8 plywood and a saw.
Old Jan 20, 2014 | 09:53 PM
  #127
senna's Avatar
senna
I built a wooden crate for mine, bolted the bottom end to the motor stand and bolted the stand in the crate.
Old Jan 20, 2014 | 10:04 PM
  #128
HD Pilot's Avatar
HD Pilot
I would have to go back and look(I saved your thread), I do remember some wood strips at the bottom for the flywheels but that is all I remember.
If y'all have not figured it out by now, I am very good with instructions but maybe not so good at improvising(engineering type!), if there are instructions anywhere on how to ship a case then I could make it happen.
Is the $500 so bad? Or is it that Darkhorse is so great at sealing a case or what?
Old Jan 20, 2014 | 10:10 PM
  #129
soft 02's Avatar
soft 02
When you ad the timken kit and the machining and the labor and set up I'd feel comfortable with what DH charges. In the end you will have no worries with your bottom end. As far as making a crate I'm the improvisational type. Once you make the crate find a cardboard box to put it in and pad the inside.
Old Jan 21, 2014 | 06:36 AM
  #130
HD Bobber's Avatar
HD Bobber
DH charged me $200 to take apart and put together my bottom end. Well worth the money!
I got dibs on you T-Body of you end up changing your setup.
