Engine Build Time
Old Feb 25, 2014 | 08:31 PM
  #331
soft 02's Avatar
soft 02
Originally Posted by alansummrs
Hey soft 02, my rod bushings look the same as yours? I don't see a difference
Old bad one.
New H beam compatition rods.
Old Feb 25, 2014 | 09:04 PM
  #332
soft 02's Avatar
soft 02
Problem is with the tappered rod is they are not as easily servicable. Did DH replace your rod wrist pin bushing? My rods were junk so I upgraded them.
Old Feb 25, 2014 | 09:14 PM
  #333
hell hound's Avatar
hell hound
this is an awsome thread
thanks for sharin
Old Feb 25, 2014 | 09:21 PM
  #334
HD Pilot's Avatar
HD Pilot
No, DH left my bushings alone, just replaced the rod roller bearings when installing the Pro
Plug. Can't tell for sure, but those H beam look like they have bushings too?
I think I have a little rod envy
Old Feb 25, 2014 | 09:26 PM
  #335
senna's Avatar
senna
Yours aren't spun!
Old Feb 25, 2014 | 09:33 PM
  #336
soft 02's Avatar
soft 02
Cool. It is the 2010+ that do not have the wrist pin bushing but there are exceptions.
Old Feb 25, 2014 | 09:34 PM
  #337
HD Pilot's Avatar
HD Pilot
Originally Posted by senna
Yours aren't spun!
Hoping that statement stays true
  #338
soft 02's Avatar
soft 02
They do have bushings but are not **** to turning. With heat and wear the tappered ones can turn. Not trying to scare you or anything. If you read the pic the ones with bushings are not forged but rather plain steel.
Old Feb 25, 2014 | 09:48 PM
  #339
senna's Avatar
senna
You'll be fine, the odds are in your favor. The failures are a small percentage, just like any other part if you think about it!
Old Feb 25, 2014 | 09:53 PM
  #340
senna's Avatar
senna
Alan, the main thing that makes the stock connecting rod pin bushing a weak spot is the fact that the rod is tapered to the top. The taper reduces the amount of material for the bushing to press into or hold onto if you will.
