Tracking down a new noise
Old Oct 26, 2011 | 10:14 AM
  #31
miacycles's Avatar
miacycles
If you put it back together and the noise diminished, I'd start by re-checking the adjustment.
Old Oct 27, 2011 | 06:38 PM
  #32
D1gger's Avatar
D1gger
Pulled the covers and double checked the pushrods and they seem right. They can rotate freely but have no play at all. Next check will be the compensator nut. I just haven't pulled the primary cover yet...
Old Oct 28, 2011 | 02:38 PM
  #33
Spanners39's Avatar
Spanners39
Yup, that's how you do it. Spin the lifter rollers carefully and also look for signs of the hardening flaking off......look at your cam lobes too as they can wear over high mileages. My standard cam had done 68,000 miles and the hardening was starting to go.
Old Mar 6, 2013 | 12:44 PM
  #34
The Shute's Avatar
The Shute
Just had an exhorbitant increase in "exhaust" noise appear last night on my 95 FLHT. D1gger did you ever discover what exactly the problem was? Since it was so sudden I am hoping to find it tot be exhaust gaskets this weekend, but I'm assuming I'll have to hunt further.
Old Mar 6, 2013 | 06:45 PM
  #35
machinehed's Avatar
machinehed
First... buy a $ 10.00 stethascope from any auto.parts shop and determine where the noise is coming from.
Second... i am a little concerned about the " tight spot " you noticed while you were checking the lifter rollers ., it probably has no bearing on your current noise problem but i suspect that the rollers are in need of replacement as tight spots should not be there.
You have done your share of wrenching here for sure and i hope we all can help you fix this Bitch of a problem.
Try to determine what area of the motor the noise is coming from , what type of noise you think it is and any other info. you can provide .
Fatboy Brian
Engine Mechanical Topics
15
Dec 12, 2018 03:14 PM
CVO SG
General Topics/Tech Tips
Aug 27, 2016 01:18 AM
cajun1957a
Shovelhead
Aug 29, 2015 10:08 AM
96roadking
EVO
13
May 22, 2010 12:14 PM
jokenroll
EVO
Jul 9, 2008 02:40 PM
