Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
Appreciate the scoop, I read the manual on the gauges but didn't see the section that covered changing them. Thanks again.
When you get to the guage screen, remember there are numerous of different types of guage screens, there is a 6 guage digital read out AND a 4 guage digital read-out. Look at the bottom of the screen on the right and left and you will see little arrows. touch the arrows and you go to different guage screens.
So.. In reading through the hundreds of posts here, I read about something called logtuner. Obviously I cant use that.. but is there something that I load my logs into, and it gives me intelligent recommendations as to what I should adjust to fix issues?
Thanks
Glen
Thanks
Glen
The program I use is MegaLogViewer HD. It is designed from scratch for looking at engine data. Power Vision and TTS both have what they consider to be Autotune that suggests and builds new tunes.
Andy
Andy
Thank you, but does MegaLogViewer make recommendations, and things like that?
Glen
Andy
I have the paid version. I only wish I knew what I was looking at and what to do with it......
Thanks
Glen
I would recommend starting with the Auto Tune Basic application with your Power Vision which will automatically populate tune corrections for your calibration. Here are two helpful videos that outline this procedure:
But.. If I am understanding this correctly, AT basic makes no adjustments or corrections to timing, AFR, etc.. Only the VE tables...or am I misinformed or misunderstanding?
Glen
