They did a baseline, put the exhaust on and 5 more runs and tuned it in about 30 minutes?
Originally Posted by FLSTFI Dave
You will be hard pressed to beat the performance of the Fullsac MX head pipe on an M8. My 18 CVO road glide has had the following done to it. Fullsac MX head pipe, Fullsac 2.25 muffler cores, with the tech mat, TTS tuner and a full dyno tune. Talk about a good gain from just a good exhaust.
Just messing with you... Good luck making up your mind.
For $700 I do like to ask a lot of questions and take time as to hopefully only purchase once. I don't have a problem spending it on something that I can see and know the difference it makes, exhaust is much more tricky and has a bigger "is it worth it" factor, does for me anyway.
The following link shows the difference from a 107 Stage II bike with the OE headpipe and a Fuulsac MX headpipe. Plenty of added power from it there.
