starter
Old Jun 21, 2017 | 04:37 PM
hntrdane1's Avatar
hntrdane1
Stage II
Default starter
I have a 1973 superglide power to headlight
Push the handlebar button nothing happens.
Screwdriver across the 2 big bolts on the starter relay engine turns over. Is the relay bad?
Old Jun 21, 2017 | 08:51 PM
TwiZted Biker's Avatar
TwiZted Biker
Could be one of several things, the button's bad, wiring break somewhere, relay or a circuit breaker gave it up. You need to do a little more troubleshooting narrow it down a bit.
Old Jun 21, 2017 | 09:24 PM
Rusty Axle's Avatar
Rusty Axle
I need to diagnose my non-functioning starter as well, hope no one minds if I tag onto this thread. To determine whether the solenoid is the issue, short across the two big posts? Does key need to be on? Neophyte here... ;-)
Old Jun 23, 2017 | 08:22 AM
hntrdane1's Avatar
hntrdane1
Stage II
I have replaced that stupid little start button quite a few times. I have power at the button. Ill check the breakers. I've had the bike almost 20 years never replaced those. Thank you
Old Jun 23, 2017 | 02:27 PM
Tom84FXST's Avatar
Tom84FXST
If you go from the top big terminal to the little terminal with the key on...the bike should crank...that will tell you if the solinoid is working.
Going from one big terminal to the other one just spins the starter without pushing out the bendix.
Old Jun 23, 2017 | 02:41 PM
Tom84FXST's Avatar
Tom84FXST
Default Best emegency start button for a shovelhead
Old Jun 24, 2017 | 08:31 AM
Rusty Axle's Avatar
Rusty Axle
Now that is clever...
Old Jun 25, 2017 | 10:08 AM
Rusty Axle's Avatar
Rusty Axle
Ran a wire from the small terminal to the large and got nothing but sparks. Ran wire across the two large terminals and got nothing but sparks. Time for a starter/solenoid swap it appears.
jgreco123
EVO
Sep 24, 2017 04:52 PM
shiznits75
May 20, 2010 12:31 PM
glide1996
May 28, 2007 01:39 AM
zacjac
May 5, 2007 10:50 AM
Jim Wurbel
Apr 16, 2006 12:48 PM
