"DYNO" Numbers For SOFTAILS
Old Dec 4, 2013 | 12:54 PM
  #931
lemonade_07flstc's Avatar
lemonade_07flstc
Bought my 07 Heritage in March and it already had V&H Big Shots Long on it and doesn't appear to have had anything else done to it. I am not one to burn up the road but it just seems like it could have a little more giddy up. Want to install a Stage 1 AC and get it tuned. Does anyone know of a good Dyno guy in Central IL? I am willing to travel a few hours but do in case ever need any changes do not want to go too far. Have heard of a few guys South of Chicago that are pretty good but that would be almost a 4 hr haul.
Old Dec 9, 2013 | 06:28 PM
  #932
hihosilver's Avatar
hihosilver
Stage II
my 03 heritage with 78,000 miles 95 bore kit w/flat top screaming eagle pistons and total seal rings, ss 510 cams w/ gear drive my ported heads w/ manley high flow valves was 86hp and 97lbtq using power commander and baker direct 6 trans
Old Dec 9, 2013 | 07:37 PM
  #933
highbarst's Avatar
highbarst
My 92 Softail 30k mi. S&S Super E , Thunderheader , S/E non adj. ign., HQ-0024 cam. was burning a qt. of oil every 250-300 miles when dyno was done . Top end is now at machine shop bumping comp. up to 9.5:1 , adding Daytona ignition and match porting the heads .
Pre work dyno run
Old Dec 12, 2013 | 11:19 PM
  #934
stal94gt's Avatar
stal94gt
2007 hd night train.
performance mods:
stock 96 ci
short shots
hd stage 1 intake
power commander
weather:
86.93 degrees
29.53 hg
Old Dec 21, 2013 | 05:10 PM
  #935
Knuckles73's Avatar
Knuckles73
Ok I'll play...dyno sheets after christmas... baseline run yesterday...
95" kit, Andrews 37's, Hydraulic tensioner upgrade, Wiseco pistons, hi flow SE air filter, Samson true duals,TTS tuner
No head work...Compression 10:5:1
78HP 92tq
first tune after build...The final dyno will be with above and new D&D Fatcat exhaust
Stayed tuned...
Old Dec 27, 2013 | 11:18 PM
  #936
Coban's Avatar
Coban
2nd Gear
Default Fatboy Dyno
Anyone have 2-1 Bub Lakesters on a Fatboy they have Dyno'd?
Old Dec 28, 2013 | 12:08 PM
  #937
Knuckles73's Avatar
Knuckles73
Just got off the phone with Tuner Guy...He wasnt able to get full throttle runs done due to clutch slipping, fixing that now...
96hp 106TQ... Probably wont change much after clutch is done...from 78Hp and 92TQ with Samson True duals and get 18hp more just by switching pipes...I am happy happy happy!
Old Jan 1, 2014 | 11:11 AM
  #938
Ed Davis's Avatar
Ed Davis
Stage II
Default New Harley performance
I've rode a lot of miles and have had quite of few bikes but after cruising across our country I have found Harley gave a smooth ride and good MPG. I now ride a 2012 FLSTCI and can tell you what a disappointment with performance and mpg. I've had 4 touring Harleys previous and the 88cu.in Road King had better mileage pulling the same small trailer as the 103cu.in Heritage and better power. Now I've had the same weight and performance additions on almost every single Harley. 2003 Road King 42 mpg no trailer/38 with trailer, 2012 Heritage 38mpg no trailer/ 25 with trailer. I had Dynojet which was in Sturgis checked the bike and they ran the numbers and said they did a little adjustments but not much. Now many of you are going to tell me rubber mounted versus counterbalance shaft motor which I get all of that. So I think Harley should make a Heritage with a touring motor/rubber mounted for 2015. If you can help with this problem let me know..
Old Jan 7, 2014 | 09:41 AM
  #939
millermax3477's Avatar
millermax3477
Originally Posted by oct1949
POST your (DYNO SHEET [preferred]) or NUMBERS) for Ur softail?
Looking for DYNO sheets or numbers on different builds to help make a decision when choosing pipes and cams. might find one like Ur thinking in here.
Touring area also has a DYNO thread ( ITS FOR BAGGERS )!
(INCLUDE) --- YR; MOTOR; CAMS; PIPES; DYNO numbers-before and after?; (STATE if DYNO was SAE or STD), other info.
Thumbnails of my dynos,-- with Andrews 26H's (80HP/92TQ)--- base run on 96''er average 58HP and 75# TQ. Sheet below With Stg-1 installed, But before Dyno tuned which I got 63hp/78.8Tq---(Both are SAE corrected) So just the Rush pipes got 5 more HP and 3# of TQ.
Cams and Stg-1 added 22 HP and 17# of tq over stock motor. 58hp/75tq VS 80hp/92tq....
update on the andrews 26H cams in post # 88 in this thread..........
Why did you choose the Andrews 26h cam?I to have a 03 heritage and im looking to put a cam in but don't know what to go with.I have a stage one air breather,vance&hines big shots with a power comander3.Any insight would be appreciated.
Old Jan 7, 2014 | 10:07 AM
  #940
millermax3477
I have an 03 heritage with a 88'' with stg1 breather,vance&hines longshots and a power comander3.Im looking to do a cam upgrade but don't know what to go with as there are so many cam sizes to go with.I just want a strong running bike to rip across the country on.Im a daily rider so I need something that will last.Any help would be great.I have 1,500 for the upgrade.Help me send my money please!
