Old Feb 13, 2015, 01:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
• Customizing you bike
• Seats
• Risers
• And much more!
Print Wikipost
Old Apr 25, 2015 | 04:15 PM
  #2561
JimGnitecki's Avatar
JimGnitecki
Originally Posted by Dynaunder
All of my bikes had abs ,and no fault code was displayed when I changed rear pulley
Dynaunder
Well that's one concern off the list!
Jim G
Old Apr 25, 2015 | 04:37 PM
  #2562
Pointman SQ8's Avatar
Pointman SQ8
Stage III
Default dyno & emblems
I'm swapping out my tank emblems and would love to know which 3m product would be best to attach the new ones. I also have a stage 1 installed which dyno'd at 76 to wheel. Does that sound about right or par for the course? First Harley for me, prior knee dragger making the conversion. Any input would be greatly appreciated! ! !
Old Apr 25, 2015 | 04:55 PM
  #2563
REDGKO's Avatar
REDGKO
6th Gear
Hey all,
Either I am not the best trying to find them on the internet or they are very hard to find, but wondering if anyone knew where I can a find the black Speedo housing? I have seen them on a few bikes, but can't seem to find one.
Thanks in advance.
Mike
Old Apr 25, 2015 | 05:25 PM
  #2564
DaSandmanCometh's Avatar
DaSandmanCometh
Either the 3mm or 5mm tape should work fine.
Originally Posted by REDGKO
Hey all,
Thanks in advance.
Mike
Are you taking about the top speedo trim or the part the gauge sets in?
Old Apr 25, 2015 | 07:13 PM
  #2565
LA_Dog's Avatar
LA_Dog
Originally Posted by Joe Reefer
I know this probably won't go over well with other breakout owners but with upcoming road trip. I had to find a way to make some storage. On my last trip I nearly had to get the rear fender painted from the t-bag rubbing on the fender. So this is what I came up with. 2014 FL bags with a slightly modified baggertail bracket. Surprisingly I would consider these more or less detachable, only 3 bolts per bag to remove.
JoeReefer- Welcome brother. that's some cool **** right there, you had a need and came up with an innovative mod for the BO. Definitely worth some cred and recognition. Does not look bad either, tastefully done.
It's stuff like this that keeps our forum valuable. Thanks for the addition of knowledge, and if you can, please post details like parts etc in case someone else wants to duplicate.
more info-
Sportster 1200 68T rear pulley and bolts that can be used for the swap on FXSB Breakout:
2011 XL1200 pulley PN 40444-07 - or - can use PN 40350-07 pulley for 2007 and up XL 1200's as it is still used on the 2013 XL1200 72.
The 40350-07 has a machine finish outer rim where the 40444-07 has a black outer rim. both have the machine finish detail on the inner part of outer rim with the black dots. otherwise it's the same sprocket.
I will probably order the 40444-07 pulley and also the PN 3899 sportster pulley bolts, 7/16-14 x 1-3/4" - Same bolts as the Breakout but shorter length. The sportster pulley is thinner on the bolt area so the Breakout's 2-5/8" length bolts will be too long.
Pulley bolt tightening:
Never re-use the pulley bolts, always use new ones.
Tighten using the following sequence:
a. Tighten to an initial torque of 60 ft-lbs (81.4 Nm).
b. Back off 1/2 turn (180 degrees).
c. Tighten to a final torque of 77-83 ft-lbs (104.5-112.6 Nm).
Surdyke seems to have the best price on the pulley ($157) and free ship on orders over $149 until May 05. The bolts are $1.09 each and washers (PN 6516HW WASHER 7/16 X 1-1/8 X 1/8) are another $1. Five of each on bolts / washers are needed. If you buy bolts at the hardware store instead, make sure they are Grade 8.
As a side note, touring bikes would use the 40518-08 rear pulley, still current to 2015 on XL Superlow, Custom, etc, as it has the built in bearing and cush-drive compatibility.
40350-07 pulley:
40444-07 pulley:
Old Apr 26, 2015 | 12:36 AM
  #2566
jgos929's Avatar
jgos929
The brackets were for a deluxe The top tabs needed to be moved forward and new hole drilled were the lower part connects to the peg. I would be more concerned about the tail lights not fitting. I already had a chop z light installed this is for other reasons the Canadian bikes do not come with a side mount plate and the stock assembly is to say the least fugly.
Man from the side you had me sold. Then when I saw that pic from the back you had me running for z hills. I applaud your ability to think outside the box and fab up something like that and it looks like it would be very useful. But damn from the rear that just doesn't look right
Originally Posted by LA_Dog
more info-
40350-07 pulley:
40444-07 pulley:
The black pulley is gonna look sick. Can't wait for you to get it on and tell us how it changes the bike. Definitely a mod I'm gonna have to do ASAP.
Old Apr 26, 2015 | 02:25 AM
  #2567
REDGKO's Avatar
REDGKO
6th Gear
[QUOTE=
Are you taking about the top speedo trim or the part the gauge sets in?[/QUOTE]
I guess both, mainly the part the gauge sits in and mounts to the handle bar.
Old Apr 26, 2015 | 09:08 AM
  #2568
LA_Dog's Avatar
LA_Dog
Jgos- I don't expect a big change from the rear pulley swap, as JimG mentioned earlier it is only a 3% change in gearing- should help a bit with take-off from stop and roll-on from cruise, every little bit counts. eventually I still want to drop in a smaller front pulley. I think the XL pulley actually looks nicer than the BO pulley, I was kinda surprised..
Old Apr 26, 2015 | 09:11 AM
  #2569
JimGnitecki
more info-
40350-07 pulley:
40444-07 pulley:
Thanks for taking the time to research and post this LA Dog. It is valuable info for others! Be sure to let us know how much of a difference the rehearing seems to make once you have the pulley swapped!
Jim G
Old Apr 26, 2015 | 09:35 AM
  #2570
LA_Dog's Avatar
LA_Dog
Jim- I can pretty much guarantee it's only going to be a small difference, but I will definitely post my impressions of the install process and the ride test.
BTW if anyone wants some super cool bolt cap covers for the pulley bolts, there are a few sets on ebay right now pretty cheap. Normally this crap is like $40 (seriously..).
http://www.ebay.com/itm/251920524483 - they are chromed plastic
If you want them black just scuff with 1000 grit, wipe clean with denatured alcohol, and paint black with some of that new paint+primer satin black spray paint from home depot / lowes. easy-peazy
