Old Feb 13, 2015, 01:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
• Customizing you bike
• Seats
• Risers
• And much more!
Print Wikipost
Old Jul 6, 2020 | 10:49 PM
  #7291
NSR's Avatar
NSR
Originally Posted by Teddy Vedder
I only took my fork lowers off to install new race tech springs and Ricor Intiminators, which is a total game changer. My bike is a completely different ride now.
Originally Posted by vtchopperdude
...so I'll need to disassemble as much as possible...
Hey man, I'll second the fork mod. If you haven't done it yet, do it. It's a great improvement. Really changes the bike. No more nose dives.
Old Jul 7, 2020 | 04:13 AM
  #7292
showin4fun's Avatar
showin4fun
Wanting to get mine powdercoated so I'll need to disassemble as much as possible. That being said, are the handlebar riser bushings easy to remove? What about the steering stem...? Does that come out easily? I assume that it's press fitted...so probably not...?
Don't bother removing the stem off the lower tree. The Powder Coater can easily tape the stem during sandblasting and powder coating. I would rather have the stem in place
because it is good to hang from to keep the piece in the upright position during powder coating.
Old Jul 7, 2020 | 07:50 AM
  #7293
Teddy Vedder's Avatar
Teddy Vedder
[QUOTE=showin4fun;19244569]Don't bother removing the stem off the lower tree. The Powder Coater can easily tape the stem during sandblasting and powder coating. I would rather have the stem in place
Showin4fun, that is good advice. Saves a lot of time and effort.
Also, you’re going to need a 1 1/2” socket to get the stem nut off.
Old Jul 9, 2020 | 07:43 PM
  #7294
vtchopperdude's Avatar
vtchopperdude
I'm re-exploring the idea of going open primary like several members here. Sounds like a very limited choice. However, there are several models out that fit the rocker, which is essentially the same setup. The ones I've come across thus far that are complete kits are the Primo Brute IV and the BDL. Both are 3 inch. I really like the Ultima 3.35 inch drag kit, but I don't think they make it for the Rocker/Breakout.
Old Jul 9, 2020 | 08:12 PM
  #7295
Rocker B's Avatar
Rocker B
I like the 2" BDL I have on my Rocker, it also fits the BO. I have a custom cover on mine, but it comes with a domed cover...and yes it's available in black! Just another option for those interested in open belt.
Old Jul 9, 2020 | 10:11 PM
  #7296
Teddy Vedder
Some pics today of the finished product. Of course I’m never finished, always planning more to do. Next is cam, port and polish...and gotta make a decision on the rear suspension upgrade.
Old Jul 9, 2020 | 10:35 PM
  #7297
HKMark23's Avatar
HKMark23
Originally Posted by TCZ
Hi guys,
I have a 2018 and am thinking of throwing a shorter Progressive mono shock in it to bring the rear end down an inch or 2 to improve the look. Wondering if you guys with the slammed bikes scrape your exhaust much in turns? Your bikes look awesome!
Appreciated
As an alternative, you can extend the forks for about 150 bux but you'll need to add a 1 1/4" jiffy stand boot and a fork brace, (good idea for the BO anyway), if you do.
https://www.denniskirk.com/cycle-vis...prd/585278.sku
Old Jul 10, 2020 | 12:55 AM
  #7298
Teddy Vedder
NSR -
Are you running rear air suspension? I like the stance of your bike, but wondering how well you like the ride.
Old Jul 10, 2020 | 09:32 PM
  #7299
vtchopperdude
Got a response back from Ultima today. I asked if they had a 3.35" drag kit for the BO, and he said they only offer a 2" open belt. He mentioned that "these late model twin cams have a pretty weak sprocket shaft. Probably a bad idea to run a big belt drive." That being said, for those with the RP 3" how is it holding up? The last time I checked, they wanted around $2350 for it. For that kind of money, I want quality that has been time tested. And they don't offer it in black currently, so I'd have to get it powdercoated before install.
Old Jul 11, 2020 | 05:45 PM
  #7300
Scott Deh2o's Avatar
Scott Deh2o
3rd Gear
Default 2020 M8 air cleaner
The factory air cleaner on my 2020 BO 114 is considerably larger than the one I had on my old 2014 103ci BO. Would adding a Screamin Eagle Heavy Breather be of any benefit? Better to stay with the factory breather? I’ve added V&H Big Radius 2-2 and SE Pro Street tuner.
