Help getting throttle cables off
Old Feb 20, 2018 | 03:27 PM
cbacon1788's Avatar
cbacon1788
Default Help getting throttle cables off
hi all, need to get carb off my 1986 Sportster 883 and having a difficult time figuring out how to get the throttle cables off, any help is appreciated pics below
Old Feb 20, 2018 | 04:39 PM
HOTLAP's Avatar
HOTLAP
Looks to me like you will have to loosen the adjusters off and see if that gives you enough slack to rotate the cable around to the slot to slip them out, if you don't have enough slack you will have to take the handle bar throttle housing apart and release the cables from the from the throttle hand grip, that will for sure give you enough slack.
Be careful when you take the throttle hand grip apart, there are small pieces in there that like to jump out and roll into the farthest reaches of your garage.
Old Feb 20, 2018 | 04:59 PM
FreedomRider's Avatar
FreedomRider
As HOTLAP said you need to create as much slack at the grip adjusters as you can ... you should then be able to remove the cables from the carb ...
Old Feb 20, 2018 | 05:17 PM
John Harper's Avatar
John Harper
Yes, I found my little adjuster shoe months later. My little star wheel broke off so it was useless anyway.
John
Old Feb 20, 2018 | 07:13 PM
cbacon1788's Avatar
cbacon1788
Would love to get enough slack in the cables without taking the hand grip apart.... will try tomorrow thanks everyone!
Old Feb 20, 2018 | 07:19 PM
RedRanger7's Avatar
RedRanger7
Have a look on you tube, Moonfleet41 has good Sportster service vids.
Dave 04 XL1200C
Old Feb 21, 2018 | 09:55 AM
HOTLAP's Avatar
HOTLAP
Looking at the first picture once again does that bracket that holds the two cable sleves happen to have nuts or bolts holding it on to the carb that are out of view in the picture? if so removing them would allow you to move the bracket over and down creating lots of slack.
Old Feb 21, 2018 | 10:42 AM
John Harper
Don't forget, you can manually open the carb and get more slack on the throttle cable, then remove the idle cable.
John
cbacon1788
Oct 22, 2017 10:06 AM
Springer91
May 24, 2015 10:33 PM
Russian
May 30, 2014 10:28 PM
bigrob219
Jun 21, 2012 06:06 AM
TCC2
Feb 27, 2012 01:12 AM
