Muffler Packing
Old Nov 3, 2011 | 09:41 AM
StreetGlidinFreak's Avatar
StreetGlidinFreak
Default Muffler Packing
Has anybody on here tried using STAINLESS STEEL WOOL scouring pads for muffler packing?? I like the volume and overall sound of my pipes with out the packing, but there is a little high frequency "chirp" (I guess you would call it) here and there through the RPM range that I would love to get rid of. Just wondering if anybody has tried this and if it works for keeping most of the volume but helps lower the note of the exhaust. Of course, I have lived with the little chirp since 07.. so I guess it doesn't REALLY bother me and if I have to I can keep on living with it.
Old Nov 3, 2011 | 09:52 AM
TUCCI's Avatar
TUCCI
Yes I have....don't use it as it heatsup and smokes like your burning oil until its completely burned away which won't take long. Use the fiberglass muffler packing instead. It will burn away also but at a much slower rate....depending on how many mile you ride could take a year or so. Of course it depends on how you wrap, how much yummy use etc etc.etc
Old Nov 3, 2011 | 09:55 AM
TUCCI's Avatar
TUCCI
Correction: not yummy use (damn self correcting phones!!) How much you use.
Old Nov 3, 2011 | 12:11 PM
StreetGlidinFreak
ehhh..... if I have to go back to fiberglass packing, I think I will just stay with the packing removed and deal with the chirp here and there. I didn't like the note of the exhaust with the factory Rush packing, a different kind MIGHT sound different but...............
Old Nov 3, 2011 | 12:43 PM
shooter5074's Avatar
shooter5074
From: Western Illinois, land of bad roads, and corrupt politicians
What kind of phone do yummy have? Your flagship might cause a whammy if your glad have no nookie.
Put down your drink (don't want to be responsible for stuff shooting out your nose) and go here http://fyouautocorrect.com/
Old Nov 3, 2011 | 01:15 PM
mkguitar's Avatar
mkguitar
one of the concerns with packing is that with out it, the gasses can flow into where the packing was, then "back up" or cause flow characteristics which are not part of the design- which can reduce performance.
( I am repeating a statement from one of the Guys at Supertrapp in response to a question about removing packing).
I know that with my pipes when the packing is degrading I can certainly hear it as a "less pure" tone
remember from grade 4 science class that steel wool does burn--- the fine mesh allows great amounts of oxygen to aid combustion, and cannot conduct heat away fast enough as would a heavier piece of steel.
2.) exhaust gas pulses can pull back up to the cylinder, I'd hate to think that fine pieces of steel could be pulled up
Mike
Old Nov 3, 2011 | 01:32 PM
StreetGlidinFreak
yeah regular steel wool will burn easily.... but alot of baffles are wrapped with stainless steel mesh before the fiberglass matting though. It takes alot to melt stainless. The pads I'm talking about are long thick ribbons of stainless all bunched up, not the fine wire with a sponge and soap.
Like the ones in the link here... (if it works)
http://www.hardwareandtools.com/3M-2...gle%20Products
Old Nov 3, 2011 | 01:56 PM
fabrik8r's Avatar
fabrik8r
Silent Sport packing, best stuff going.
Old Nov 3, 2011 | 02:00 PM
djl's Avatar
djl
There is a ceramic packing that will not burn; McMaster Carr sells it in rolls. Wrap and secure with SS wire.
l.ray
Jan 19, 2012 01:35 PM
UltraDave
Dec 18, 2011 08:11 PM
hdgzr
Aug 27, 2010 07:46 AM
keithj
Oct 12, 2008 07:07 PM
52edub
Exhaust System Topics
Apr 27, 2008 11:27 AM
