Radio antenna question
Old Aug 12, 2012 | 06:29 PM
Renold's Avatar
Renold
Default Radio antenna question
Few months back I replaced the "whip" with the HD hidden antenna(mounts under fairing). I was not pleased with this reception so today while I had the fairing off replacing a clutch cable I added an antenna splitter at the radio back. I plugged in the old antenna wire and the hidden antenna wire into the splitter. Will this help hurt or hinder the reception? I need one of you electronic guys on here to answer. I know the hidden antenna is equivalent to the length of the whip. I did not put an external antenna I am just using the existing wire for a little extra umph. Any input? Am i just showing my electronic ignorance?
Old Aug 12, 2012 | 06:53 PM
slimvela's Avatar
slimvela
Cable is shielded, without antenna it does nothing. As far as the hidden, it also hid my reception...worked to well...lol
Old Aug 12, 2012 | 07:03 PM
R Hill's Avatar
R Hill
Is right will not help.
What is the conditions that is reducing your signal. Middle of nowhere or obstrution reducing signal. You are talking FM not AM correct.
Old Aug 12, 2012 | 07:29 PM
Renold's Avatar
Renold
Yes FM just when I get way out from broadcasting area
Old Aug 12, 2012 | 07:37 PM
big TYME's Avatar
big TYME
I had this same prob. Bad rec using hidden ant. Bought a complete 10 inch whip and zip tied it inside the fairing. Just underneath the windshield screws running left and right. Out of sight and perfect reception. Doesnt rattle either.
Old Aug 26, 2012 | 03:50 PM
ADay73's Avatar
ADay73
Did you just plug this in to the back of the head unit and just return the HD hidden antenna or just this in conjunction with the hidden antenna?
Old Aug 26, 2012 | 08:13 PM
HOGBOY57's Avatar
HOGBOY57
i did the same thing no problems. i also bought hds hidden attenna still in box have not used it.need to sell.
Old Aug 27, 2012 | 08:40 PM
ADay73's Avatar
ADay73
Anyone remember the vendor of the whip antenna that has shown it works?
ccessna
Jun 21, 2019 06:18 AM
bgdv1
Audio Systems
Sep 15, 2011 01:24 PM
rickshog1
Jun 2, 2009 12:49 PM
THABULL
Mar 18, 2008 09:04 AM
05Fatty
Mar 16, 2008 04:38 PM
