screaming eagle 113"
Old Dec 23, 2012 | 02:11 PM
rrcap2001's Avatar
rrcap2001
Originally Posted by Brick0044
I had FM send me heads and juggs, had to pay the core charge. Then when I got them I did the build and sent them my heads and juggs and got my core charge money back. That way you have the packing material also.
Sweet!! That's how I was hoping it worked!!! I did send Jamie an s email asking, but I'm sure with the holiday I may be waiting for a response. I knew I'd get the answer here!! 107" is probably the way i'll go. The 113" may be a little out of the price range. I'll get the heads and throttle body done too. I did notice someone saying on another post about the bottom end not being able to handle torque higher than 120. Is this true? I do ride it hard, wouldn't want to have problems down the road!!
Old Dec 23, 2012 | 02:37 PM
Brick0044's Avatar
Brick0044
I haven't heard of anyone having a bottom end problem with the 107 FM kit. I just did my build and only rode it about 10 miles so far. Can't wait for spring.
Old Dec 23, 2012 | 03:58 PM
2009blackpearle's Avatar
2009blackpearle
Default think 120 is limit
i think 120 tq and hp is about the limit unless cranks is trued and welded bearing up grade and clutch upgrades too
Old Dec 23, 2012 | 04:37 PM
0ldhippie's Avatar
0ldhippie
I know alot of folks push 100+hp without crank work but imho they are pushing their luck. Maybe a good thing 100+hp is also pushing the stock intake.
Old Dec 23, 2012 | 04:41 PM
chuck3049's Avatar
chuck3049
Do you really trust Harleys stock bearings, plus what is the crank run out at this time. anything over 3 thou. is pushing it for tq and 100 plus hp. may seem like costly until you figure the cost of total rebuild, which may even include replace the cases.
Old Dec 23, 2012 | 05:00 PM
soft 02's Avatar
soft 02
Not only do you have to worry about crank run out but you also have the non replaceable rod bearings! This rod bearing will cost me 1500
Old Dec 23, 2012 | 05:34 PM
rrcap2001's Avatar
rrcap2001
keep going back and forth. i like the torque of the 107", but i like the fact that with harley's you get injectors, intakes, and get the cranks machined or buy a new one...i'll wait to hear back from fuel moto before deciding anything. in the mean time keep the opinions coming!!
Old Dec 25, 2012 | 05:53 PM
rrcap2001's Avatar
rrcap2001
Bump , and merry Christmas!!!!
Old Jan 1, 2013 | 07:45 PM
rrcap2001's Avatar
rrcap2001
i am going to go with fuel moto's 107" kit with the level b heads. i already have the 555 cams, and lifters installed. so, how long do you think it would take a dealer to do this work? seriously considering doing it myself.
Old Jan 1, 2013 | 07:59 PM
soft 02's Avatar
soft 02
If your even slightly handy you should do it. The hard part is the cams and thats done. Between FM video's, the forum, and the manual it should be easy. Start a thread and everyone will pitch in!
Great step by step write up! https://www.hdforums.com/forum/touri...-write-up.html
cmdevil16
Sep 5, 2015 07:13 AM
jaws52
Aug 1, 2014 09:33 AM
cliffd
Feb 1, 2011 09:10 PM
Kickstand69
Dec 14, 2005 12:10 PM
berryw
Exhaust System Topics
Oct 8, 2005 12:31 AM
