2018+ Softail Models Breakout
The Everything Fat Bob Thread
Old Jul 10, 2018 | 10:07 AM
  #111
Bowhunter8607's Avatar
Bowhunter8607
Originally Posted by Adamreading
I’ve done 650 Miles now, and I’m hearing a weird noise from the front of the bike (it seems to be the front anyway).
Its a sort of tinny, rasping sound which is there intermittently on acceleration and deceleration. The best way I can describe it is like spinning the wheel of a skateboard, hearing the bearings move.
Has anyone come across anything like that?
When you hear this try putting your hand or a couple of fingers on your gas cap. It may just be the gas cap rattle. I started hearing a similar noise on mine and after reading that the gas cap tends to rattle it put my finger on it when I heard it while riding and it stopped. It doesn't sound like a typical rattle but more like you described. I just give it a twist until it clicks again and it seems to stop for a while.
Old Jul 10, 2018 | 10:09 AM
  #112
Adamreading's Avatar
Adamreading
thanks. Sounds sensible, I’ll give it a try.
Old Jul 10, 2018 | 11:39 AM
  #113
Decker72's Avatar
Decker72
Default Tire Options
I'm getting fairly close to needing new tires. I know there has been some discussion earlier in the thread about tires, but have any of y'all pulled the trigger on installing new tires other than the stock Dunlops?
Just looking for input so I can do my research before buying.
Old Jul 10, 2018 | 01:51 PM
  #114
FatBob2018's Avatar
FatBob2018
Just curious -- how many miles before you needed a new set?
Old Jul 10, 2018 | 02:41 PM
  #115
Decker72's Avatar
Decker72
They've got some life left in them, but I want to go ahead and plan for my next set. I'm pushing about 10k miles.
Old Jul 10, 2018 | 04:42 PM
  #116
Yzzyx's Avatar
Yzzyx
I have 14K on mine. The front has a real bad humming sound from the knobby bits wearing weird. I can't feel it riding but pushing it around my garage feels like pushing a motocross bike around. Both tires still have a significant amount of tread left.
The front rim hasn't changed from last year's Fat Bob, which had a 130/90-16 tire. Most tire manufacturers recommend a 130-width tire for a 3" rim. I plan to put on a Dunlop Elite 4 both front and rear with the front being 130/90-16 bias and the rear a 180/70-16 radial. I have had Elite 4 tires in the past and I like how they wear and handle. The 130 up front will be slightly narrower than the OEM tire. If anything, it will improve the steering a bit.
https://www.dunlopmotorcycletires.co...-line/elite-4/
Old Jul 10, 2018 | 04:52 PM
  #117
FatBob2018's Avatar
FatBob2018
Glad to hear it. I am close to 5,000 miles and the tires look fine. I know some tires wear out in no time at all, but these seem like they would go 10,000 or so, so thanks for confirming.
Old Jul 11, 2018 | 07:27 AM
  #118
beardo's Avatar
beardo
I also went with a 130 front tire, with the expectation that it would help quicken turn in, which it did. I also extended the shock to get the bike more on it's nose. That also helped.
The bike in stock form was good, but wasn't great. And I think a couple of changes really helped in the handling department.
Mids also helped in quicker body placement.
Old Jul 11, 2018 | 07:44 AM
  #119
Decker72's Avatar
Decker72
I do still have quite a bit of meat left on my tires, but my confidence level in them (especially in the rain) is waning. For me, once I stop trusting my tires, it's time for a new set. I'll look into the Elite 4 tires. In the past, I've had awesome experience with Dunlop American Elites. Good call on using the 130 up front ... something to consider. Thanks for the insight!
Old Jul 11, 2018 | 08:21 AM
  #120
Yzzyx's Avatar
Yzzyx
What tire did you choose?
