Power In-Line fuse keeps blowing
Old Mar 7, 2015 | 08:18 PM
haze324's Avatar
haze324
Default Power In-Line fuse keeps blowing
I have a PPI 900.4 in one of my bags and the other day riding I hit a bump and the inline fuse blew. Figured I had a short somewhere. I replaced the fuse and it blew right away. I pulled my cables and noticed the power cable had some frays on it at the entry point/hole of the bag (it was kinda tight).
So tonight I pulled the wires out, made the hole a tad bigger and used smaller speaker wires and a 4 channel into 1 cable to make some space, along with 8ga power and ground wires. Plenty of wiggle room.
I hooked it up, the amp turned on and immediately I heard a light "whining" type noise and pop the AGU fuse blew.
All wires are new. No speakers were connected. I have a second amp in the fairing connected the same way and it turned right now. If I fried my amp, I'm getting a BT4180
Old Mar 7, 2015 | 08:23 PM
davidwruth's Avatar
davidwruth
When fuses blow instantly, almost always shorting to ground somewhere. You need to trace all the wiring. Sorry it's a bummer
Old Mar 7, 2015 | 08:30 PM
haze324's Avatar
haze324
I'm gonna re-check it now. Thing is I just replaced EVERY wire/cable.
Going to try and pull it out and connect some short wires to see if it still blows.
This blows!
Old Mar 7, 2015 | 08:39 PM
haze324's Avatar
haze324
........ehhhhhhh, pretty sure the amp is fried!! Fak.
So I connected it to the same connections of my other amp (was working so figure they are fine). Connected ground, remote, and as the power cable touch the amp it started to spark. Then after a second or two smoke came out of the amp.
Can't be good.
Old Mar 7, 2015 | 09:01 PM
Roadie13's Avatar
Roadie13
That sucks, but deep down you really wanted the 4180 anyways. They need to make electronic components with more smoke in them. I've let just a tiny bit out of a few things and that does it every time - it doesn't take up much room so they really need to start with more or sell replacement smoke.
Old Mar 8, 2015 | 07:42 AM
z71_fourwheelin's Avatar
z71_fourwheelin
Slow clap and chant starts (kinda like U.S.A.) ....41.80...41.80...41.80...41.80.....
Old Mar 8, 2015 | 08:51 AM
haze324's Avatar
haze324
Originally Posted by Roadie13
That sucks, but deep down you really wanted the 4180 anyways. .
Ha ha!!!
Ok you got me.
Is there such a thing as 4180 peer pressure? Looks like I'll be calling Bill tmw.
Old Mar 8, 2015 | 11:06 AM
enodrano's Avatar
enodrano
Originally Posted by haze324
...Then after a second or two smoke came out of the amp.
You're not suppose to let that smoke out. They install it at the factory.
Old Mar 8, 2015 | 09:17 PM
davidwruth's Avatar
davidwruth
It's called Magic Smoke. When you let it out things stop working
Old Mar 8, 2015 | 10:39 PM
haze324's Avatar
haze324
Well damn, that amp was full of "magic" cause tons of smoke came out!!!!
41.80.....41.80 (chant)
have it stuck in my head.
doctorgoo
Audio Systems
Mar 12, 2018 09:00 PM
Sandhog
Audio Systems
11
Jul 4, 2017 03:22 PM
Springerfan
Audio Systems
19
Jul 5, 2016 05:46 PM
decencyxdefied
Audio Systems
Jun 8, 2016 11:54 AM
vhmike73
Audio Systems
Oct 17, 2014 11:38 AM
