Power Vision Information Thread
thanks
Jeff
i did it the hard way...i just ran logs and made manual changes based on my logs knock events.
I think there is a company called tech mount that makes a mount for it as well as Fuelmoto has mounts. Dont know if either one of them is a quick disconnect but its not too much trouble to unbolt the fuel moto one. i got one with my purchase from them. Dynojets web site points you to one and you could call fuelmoto and they can hook ya up.
Crazy...when you pulled the extra 1 deg of timing did you notice a differance> What i meen is did it make the bike sluggish in that range like it was maybe a little too much?
If you don't like the dynojet manuals, this will make things easier for you. Discoveries are made by mistakes......don't be afraid to experiment.
In step 3 of the document, this is the process I use:
From the main screen select Datalog/Gauges. At the lower right corner of the screen I believe it has the option to "Datalog" or "Start Log", select this. When you are done and before you shut the bike off, select End Log or Stop Log (I'm on vacation and am going from memory). This will generate a .csv log file without any of the adjustments that autotune applies. The code of 319245 that is mentioned in this step will bring up the autotune screen.
If you want a log of the autotune process just select start log from the autotune green screen.
Again this file is for info purposes. Read it from beginning to end, and then use it at your own risk.
http://www.dynojet.com/powervision/p...cessories.aspx
Did not know that. i will have to take a look at that.
