"DYNO" Numbers For SOFTAILS
Old Sep 22, 2009 | 06:23 PM
  #211
bartallica2006's Avatar
bartallica2006
I just went from a stock 88 with a PCIII, to heads, TW55 cams, heavy springs, oversized oil pump, SE cam plate, adjustable push rods, 3 7/8 SE High Comp. pistons. Let me tell you, it is really alive now. I have a SE 103" Street Bob map with same cams as mine in it now. Breaking it in before Dyno. I will let you know
Old Sep 27, 2009 | 03:45 PM
  #212
bartallica2006
Angry Dyno Numbers
OK, i got my 2001, EFI TC88 Deuce on the dyno. The numbers are 102.34 HP, 104.56 torque. Upgrades are:
bored out from 3 3/4" to 3 7/8" cylinders
SE High Compression 3 7/8" dometop pistons
port/polish/decked heads
heavy valve springs
Andrews TW55 cams
SE billet cam plate
SE oversized oil pump
Welded flywheel
Power Commander III USB with base tune only so far
Hardkrome 2 3/4" long shots( no baffles)
K&N air filter
The reason I had all this work done is that I was blowing oil out the intake, and it turnes out my flywheel was out of true, therefore walking my crank against my oil pump, and it wouldnt scavenge the oil out the crank case, and blowing it out the intake. Thats what I was told anyway. So I had tthe flywheel trued, and welded, and all the upgrades done. Now, however, after 800 miles, Im losing my rear cylinder fire at cruising speed at acceleration, and hearing a "tink tink" noise, and its blowing oil out the intake again. Someone please help me. Im really frustrated, for having spent 4000 dollars on this, qand havent put 1000 miles on it yet.
Old Sep 28, 2009 | 07:07 AM
  #213
imrotton2's Avatar
imrotton2
check your pushrods,, adjusting nut mite have backed off
Old Sep 28, 2009 | 05:53 PM
  #214
wouldie59's Avatar
wouldie59
Just had mine dynoed last week, but the only literature I got was the invoice. I will go back and ask, but it was an independent shop and I don't know if they charted it.
Made a huge difference. Reduced first gear whine, no more 5th gear clatter, 30 degrees cooler, and only a flutter on decel. Worth every penny.
Old Sep 29, 2009 | 06:58 PM
  #215
jay36's Avatar
jay36
6th Gear
2009 Fatboy - 74.13 HP and 85.52 Torque
Screamin Eagle Pro Super Tuner
Screamin Eagle Stage I Air Cleaner Kit
K&N HD-0800 Air Filter
Screamin Eagle Forged Billet Aluminum Air Cleaner Cover
Vance & Hines Big Shots Staggered
Old Sep 29, 2009 | 07:20 PM
  #216
brandon373's Avatar
brandon373
2nd Gear
Default Dyno Results 97 Fatboy with 125 PR stock motor
Guys, I have a question. I had my motorcycle dyno yesterday as I put in a new engine on my 97 Fatboy (Patrick Racing 125 cu with 48mm Mikuni Carb). While I am impressed with the results, everyone seems to be confused on why my power fell off after 5000 rpm (we even set the rev limiter at 5000 in the end). The attached pic shows intial run, then final run with rev limiter adjusted down.
The technicians seemed to think the vibrations from the motorcycle disrupted the fuel flow past 5000 rpm. The engine is not counterbalanced nor rubber mounted.
Anyone have any additional explanation or advice?
BTW, my bike is much more responsive AND has much less vibration since its been tuned.
Thanks.
Old Oct 2, 2009 | 05:54 PM
  #217
SEDELUXE's Avatar
SEDELUXE
Thanks.
would need to know the especifics of the build in order to make ea guess.
best guess is the cam.
seems to rise quick and fall off. prettty good #
Old Oct 5, 2009 | 04:53 AM
  #218
zer0t's Avatar
zer0t
I can't find the sheet that Dave gave me when he dropped the bike off. But here are the numbers 104.49 HP & 108.03 TQ.
Old Oct 8, 2009 | 09:07 AM
  #219
Saltydog's Avatar
Saltydog
Found my Dyno sheet. 09 CVO Fat Bob with V&H big radius 2 into 1.
Old Oct 8, 2009 | 07:34 PM
  #220
zer0t's Avatar
zer0t
Nice numbers.
