"DYNO" Numbers For SOFTAILS
Old Dec 8, 2012 | 10:54 AM
  #761
wagon50's Avatar
wagon50
Is anyone hear runnin a 95" with .625 or. 640 cams?
Old Dec 12, 2012 | 07:49 AM
  #762
oct1949's Avatar
oct1949
Originally Posted by windycity
Getting ready to do SE stage 4 kit on stock bike except for 2 into 1 rhinehart high performance exhaust and RSD air cleaner already on. Should i just do stage 2, and can you tell the difference. deciding if stage 4 is worth the $
Thanks
Too many Ideas and versions of what the different stages are made up of.
Usually STG4 means adding a BLOWER or running NOS after You've done all the rest of Ur motor build, like cams, ported heads with bigger valves, BB kit, bigger TB.
IMO I wouldn't want either one for a daily ridder.
Old Dec 16, 2012 | 03:16 PM
  #763
dakotared's Avatar
dakotared
2010 FXSTC: 103", Andrews 37H cams, SERT, Roland Sands open air filter, Rush 2" baloney cut slipons.
Old Dec 16, 2012 | 06:42 PM
  #764
TheTroupe's Avatar
TheTroupe
Real good start, but the A/F ratio is to sloppy. It should be much more flat. Ask your dyno guy why he let it like that.
Old Jan 1, 2013 | 12:39 PM
  #765
FatBoyTig's Avatar
FatBoyTig
Default Need help with dyno reading
Hello all,
I have a 2010 Fatboy with D&D 2:1 exhaust, AN big sucker stage 1 exhaust and power commander V. With the map I have now the ride is great - it's smooth, good acceleration and runs cool. I just had a dyno run and the torque number is about 83 ft-lbs. The stock 2010 Fatboy has a spec'd torque of 93.7 ft-lbs. What am I missing? How can my bike have worse performance than out of the factory? That said I think the bike is running better now than before the upgrades so I don't think I can believe the factory numbers. The dyno run is below.
Thanks and Happy New Year to all.
Old Jan 1, 2013 | 03:07 PM
  #766
BlackSpecial's Avatar
BlackSpecial
I'm guessing that is just a baseline dyno and no tuning.
Bottom line.....your a/f ratio at the bottom of the graph is way lean. You need a tune or a better map.
Old Jan 2, 2013 | 08:34 AM
  #767
FatBoyTig's Avatar
FatBoyTig
Thanks for the quick response mstngjoe. I'll do some more digging into a/f ratios. I do know the current map has it boosted quite a bit over stock so I'm still confused over the stock numbers.
Old Jan 2, 2013 | 09:51 AM
  #768
txphatboy's Avatar
txphatboy
I'm no expert, but I think you are comparing Harley numbers at the crank vs Dyno numbers at the wheel. I have not seen stock Harley's put out those kind of numbers at the wheel.
Old Jan 3, 2013 | 11:32 AM
  #769
Weevil's Avatar
Weevil
Originally Posted by FatBoyTig
Hello all,
You failed to say if your running a 96ci or a 103ci engine. Where are you getting these factory "spec" torque numbers from? Are you running a canned map or did you actually have a custom map done?
Old Jan 4, 2013 | 06:45 AM
  #770
FatBoyTig's Avatar
FatBoyTig
txphatboy, I think you may be on to something - power at the crankshaft vs power at the wheel.
DD&Weevil, it's a 96CI engine (stock) and the spec is from the HD website. The map is tailored by dynojet for 2010 Fatboys with stage 1 and D&D fatcats. I've tried other maps from fuelmoto which had similar map numbers and performance but were not dynojet tested.
