Sears red jack modification
Old Jun 27, 2012 | 09:42 AM
  #441
8541hog's Avatar
8541hog
Originally Posted by SC-Longhair
I don't know but that piece if wood looks like its bending under force. Could be an issue.
Not to mention the bolts, I think I would be looking to buy a better lift.
Old Jun 27, 2012 | 01:48 PM
  #442
kiethf's Avatar
kiethf
Its certainly not as elegant, but it allowed me to get the bike up finally. Didnt mean to complicate the mod design thread but it seems you have to go this route when the original jack forks are that narrow... i'll be looking out for a cheap Craftsman on CL!
Old Jun 28, 2012 | 03:43 AM
  #443
bicio's Avatar
bicio
I have the same sears jack since I got my FXDC in '08. From day 1 I kept using the "twin cam equipped dyna service lift adapter" HD pn 98965-99 $24.95 without any issue.
Even if this mod seems to be a smart one, you should consider the fact that loads work in a completely different way (from push to cut) on the jack's frame and you can't be sure it has been engineered for that.
Dynas are heavy and expensive at the body shop..... I prefer to play by the book about lifting.
Old Jun 28, 2012 | 05:23 AM
  #444
FXDWG12's Avatar
FXDWG12
There is an inherent risk buit into anything you do. And there are only a few ways to reduce the risks. The best way is to use equipment that is well over rated for the job. Another way is to be knoledgeable and comfortable with the procedures. The safety margin for the "Jack Mod" lies in it's rateing. Even with the modification on the jack, It's still rated to lift well more than the weight of the bikes. And by expanding the lifting platform, you actually increase the stability of the lift. Also, not having to use the lifting blocks is simpler and more comfortable to me.
The only gain from using the blocks is having full capacity of the lifting device. The inherent risk is using the blocks themselves. Most lift manufactures do not recommend using other lifting devices with their lifts. That combined with the narrower lifting platform and extra procedures for lifting the bike makes the lift to risky for me.
Old Jul 4, 2012 | 12:52 PM
  #445
chris h.'s Avatar
chris h.
I didn't read all 45 pages, but does anyone know if it will still work on the sportster after the modification. I don't think the frame is as long. I have both a dyna and a sportster so if it won't work on the sportster still I guess I'll just have to get the adapter.
Old Jul 4, 2012 | 01:34 PM
  #446
SC-Longhair's Avatar
SC-Longhair
If you have a sporty then measure it. The jack after mod is ~19" wide.
Old Jul 5, 2012 | 12:53 PM
  #447
chris h.'s Avatar
chris h.
Whelp, I went for it. Measured the sporty first and it seemed like it would work. Good news, it totally works on both the sporty and the dyna. Definitely appreciate this thread and this is why I love this forum. Here's a couple pics:
Old Jul 5, 2012 | 04:40 PM
  #448
Puffdaddy's Avatar
Puffdaddy
Thanks for the pic 8541hog, I think i have figured why the lift arms hit my jiffy! My Sears jack is only 12 11/16" inches from outside to outside the lift arms instead of the 13 7/16th" in your pics. I didn't get this jack new so I have no idea how old it is. They must have changed the design of the jack since mine was made.
Wonder if I should just get a new jack at this point...
Originally Posted by Puffdaddy
I got a Sears Red Jack from a co-worker who had upgraded to a PitBull lift. He gave it to me, so I was excited to try it out with this mod.
(It was funny that I just mentioned that I was going to get a lift this weekend from Sears (on sale for $99). He said "I have one I don't don't need any more, I'll bring it in for you"
Anyway, I did the mod with no problem (Sawzall with a Bimetal blade make QUICK work of the center bar!).
I have an 08 Fat Bob and have a problem with jack placement. I looked at Vic's pics in post 73 and see where he hits the frame. On mine, if I go immediately behind the oil pan frame guard I run DEAD into the middle of the Jiffy stand. If I move it forward to clear the Jiffy stand (and stop) it is on the pan. Is the FBob frame different? Is there something I may be doing wrong?
I see others that have used this with FBob without complaint.
I can post pics if necessary
BTW I am trying to lift from exhaust side :-)
Thanks
Old Jul 5, 2012 | 04:54 PM
  #449
8541hog's Avatar
8541hog
Glad to hear you found the answer, I think if it were me, I would get a new lift and do the mod, not sure I would feel safe adding more spacers than I already have.
Old Jul 5, 2012 | 05:45 PM
  #450
lo-rider's Avatar
lo-rider
Puff--This whole thread is about modifying YOUR jack to better accommodate our bikes. Go to page 1
