2000 softail deuce
vance and hines straightshots
k&n big filter
max torque 73.67
max power 66.58
Put the big shots staggerd on
max torque 78.47
max power 71.61
Sounds really loud now nice deep rumble
1450cc 88 cubic inch
I don't much about any of this, but here is my dyno and tune job i got yesterday, im a bit curious if these are average numbers, and why does the base run lines look smooth but the after tune lines look so jumpy, thanx all !
just wondering if those muffler bearings come in CHROME
Originally Posted by beaureed445
Here's mine....for now........
2007 FXST,
103" w/ SE255 cams,
Stock Heads
V&H Big Radius,
SE Heavy Breather,
PCIII,
84 HP, 104 lbs TQ.
.......Getting torn down again this winter to add R&R Stage IV Heads, R&R 615 cams, SE Cam Plate, Rev Perf Roller Rockers, GMR Push Rods.....Should be a nice improvement.
95", 9.7:1 compression with Weisco pistons
SE Heads
High flow air cleaner
SE 257 Cams
Power Commander
Vance & Hines Big Shots Staggerd
With a quick tune on the power commander she dyno'd at 92 Hp, don't remember the torque. A little sluggish on the low end, but I knew that when putting in the cams. For most people, I would recommend a smaller set of cams.
Yep...sure do. Man, that's an old post. I've made so many motor changes since then. I didn't add the R&R heads- went with Baisley instead. And I've swapped cams twice since then. And changed it to a 113".
