Old Feb 13, 2015, 01:41 PM
How-Tos on this Topic
Last edit by: IB Advertising
• Customizing you bike
• Seats
• Risers
• And much more!
Print Wikipost
Old Dec 27, 2016 | 06:00 PM
  #5311
rodrocket's Avatar
rodrocket
will this pulley suit the Breakout
http://www.ebay.com.au/itm/Performan...p2047675.l2557
or is this from an earlier model
Old Dec 27, 2016 | 06:37 PM
  #5312
Rocker B's Avatar
Rocker B
No, it's 1-1/2" wide.... you need a 1" or 1-1/8" pulley for the BO.
Old Dec 27, 2016 | 07:20 PM
  #5313
rodrocket's Avatar
rodrocket
Originally Posted by Rocker B
No, it's 1-1/2" wide.... you a need 1" or 1-1/8" pulley for the BO.
Thanks for that
Guess I will just re list it on Flea Bay as I had already pulled the trigger on it
Old Jan 10, 2017 | 09:24 AM
  #5314
Jimstang's Avatar
Jimstang
Here's a small project I did the other week. I cut and shaped the fender struts to make the Alloy Art turn signals fit. I'm pretty satisfied with the look but plan to cut the signals down to about half the length...then I'll remove some of the contour on the struts where they meet up with the signals to make it flow better.
Attached Thumbnails The Everything Breakout Thread-bo-light-1.jpg   The Everything Breakout Thread-bo-light-2.jpg   The Everything Breakout Thread-bo-light-3.jpg   The Everything Breakout Thread-bo-light-4.jpg   The Everything Breakout Thread-bo-light-5.jpg
Old Jan 10, 2017 | 10:33 AM
  #5315
LA_Dog's Avatar
LA_Dog
that's awesome - you've got a pretty steady hand with that grinder!
the results look great, sorta like the bike should have come that way.
suggestion, paint the strut bolt heads black to blend in? I use spray can black lacquer or gloss enamel. fasten the bolts, wipe them off, mask around them and then hit with a few coats until shiny to match struts.
i found that if i paint the bolt heads before assembly, the tool will always chip the paint off and it looks ratty.
easiest way to mask off the bike is to throw a painters plastic sheet over it, poke some holes in the sheet where the bolt heads are, then use pieces of masking tape to complete the masking around the bolt head to the plastic sheet.
Old Jan 10, 2017 | 11:03 AM
  #5316
Jimstang's Avatar
Jimstang
Thanks LA_Dog. I did the final shaping by hand with a file. Hell, I wish I had that steady of a hand with a grinder...it would have shaved off about 2 hours of work (pun intended haha).
Great idea with painting the bolts black. I added the chrome fender strut bolt kit but I think they stand out too much now.
Old Jan 10, 2017 | 12:56 PM
  #5317
rquest's Avatar
rquest
Nice Job! I'd be interested in seeing the finished project. Post a pic of the signal separately when it's cut down.
Old Jan 10, 2017 | 05:30 PM
  #5318
02603SEC's Avatar
02603SEC
Does anyone have a part # for a front brake line in black that is 2" over stock?
Old Jan 10, 2017 | 06:11 PM
  #5319
tphykitt's Avatar
tphykitt
how do i do this?
i asked how to rake the bike so the frame was pointed up more and everyone said to chop the frame. i don't think this guy did that. looks sexy.
Attached Thumbnails The Everything Breakout Thread-fullsizerender.jpg   The Everything Breakout Thread-fullsizerender-2.jpg   The Everything Breakout Thread-fullsizerender-1.jpg
Old Jan 10, 2017 | 10:20 PM
  #5320
Dalt10's Avatar
Dalt10
Not sure but looks like they just have longer fork tubes.
