2010 Deluxe
103 stage 3
100hp and 106 TQ.
This will change as I have just put in a 113pro race kit. I hope to get
125hp and 121TQ. Will post after custom map
87 hp and 92 Trq. Looking at possible Dewys heads blue print for approx 5hp and trq gain.
Or a bitchn 103 build or GRM 107 kit.
Never have left anythign stock engine wise that I ever drove.
Now have gone with 103 build, Baisley heads 9:8.1 compression.
91.6 Hp with 101.5 torque run date 3/16/2010
I did the build myself, 103 CI, SE255 cams, SE Kompressor Heads, V&H Big Radios 2-2, Heavy Breather and the SR Supper Race Tuner. I got all the parts from Lake Shore HD with the 20% discount. This build is a low end torque build. If you look at how fast the power comes on I am cruising in 6th gear and have 100 fp of torque.
2011 heritage,120 miles.lower line is stock,upper line is stock with rush 2" slip ons.it looks like the mufflers alone were a big improvement but the stock mufflers have converters in them and they alone probably take 3 to 4 hp away.se pro tuner is on order so it can be tuned for se air cleaner and 26h cam.
If U want to look at my sheets.. it the starting post in this thread..
I have what Ur goiing to... 07 st1. SE A/C, sert, Rush 2'' and the 26h cams..
2007 Night Train D & D exhaust, screamin eagle intake, fuel pak, and the number are 92hp/93tq will post dyno sheet later. I was thinking cams for it but motor has 28,000 miles on it not sure if it would be a good thing
