PDA
View Full Version : Primary/Transmission/Driveline/Clutch
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 [21] 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36
  1. Final Drive options for 08 FXD
  2. Help adjusting clutch
  3. 63 stock duoglide clutch problem
  4. Clutch cable replacement
  5. 2006 RKC bike wont shift
  6. Clutch/shifter out..??? Help
  7. Limp Clutch Lever
  8. Cruise drive 6 speed sprocket tool
  9. Derby Cover Gasket & VPC Install?
  10. primary chain adjustment
  11. Convert to Heel & Toe Shifter on '92 Softail Springer?
  12. Primary oil
  13. primary leak
  14. Locktite on outer primary cover bolts?
  15. big bore kit
  16. Installing SE Performance Clutch Kit
  17. '02 FXDX Drive belt replacement procedure
  18. Gear Adjustment: I Need Help.
  19. Clutch pushrod too long.
  20. Engine Swap
  21. Five Speed Shifter Rachet Spring
  22. high rpms when warmed up
  23. Clutch screeches under load
  24. Rivet Tech
  25. 06 Road Glide Tranny Leak
  26. 06 FB Primary Auto Chain Tensioner
  27. Synthetics in primary?
  28. Question - Starter
  29. DD7 arrived today.
  30. Had to make my own "Better Lever"
  31. No 3rd gear???
  32. Jumping into 1st from neutral
  33. Heel/toe shifter
  34. 83 fxr
  35. Sprocket bolt torque, how much?
  36. evo primary need some help
  37. evo primary need some help
  38. sportster starter
  39. Sloppy Shifter
  40. Sloppy Shifter
  41. 120R + Rivera Primo - Pro Clutch 1056-0020 - slipping
  42. Knocking noise at compensating sprocket
  43. 1960 panhead trany
  44. Gear Whine
  45. 2000 softail transmission gears
  46. Baker DD6
  47. Vibration
  48. Carb or timing problem
  49. Clutch oil capacity
  50. Clutch problem
  51. Leaking drain bolt
  52. 3:37 Gearing
  53. 6spd swap on 04 5spd Tranny
  54. 2008 Primary belt drives???
  55. transmission output spline
  56. 69 Shovel Transmission problem
  57. Stripped out threads in Transmisson case
  58. help with Sporty trans
  59. Clutch Release Cover
  60. I screwed up royally need help
  61. Any idea what transmission this is???
  62. shift points?
  63. My 2008 FLHX transmission bearing is bad...
  64. New FatBob ,Hard to find neutral
  65. real advantages of a hydraulic clutch?
  66. Drive Belt
  67. 5 Speed kick
  68. WEt or Dry Clutch
  69. Bearing Installation
  70. Clutch adjustment
  71. Loose primary chain?
  72. HELP! inner primary is cracked
  73. Clutch - broken cable but not engaged.
  74. Neutral and Clutch
  75. need a new clutch pack: any suggestions?
  76. 3.37 Primary Gears & Starter Question
  77. Dry Trans
  78. clutch cable won't go in side cover
  79. 08 Fatboy Drive Line
  80. 93 Fifth Gear change
  81. HD 24t sprocket price????
  82. Sticky Neutral
  83. Change primary and tranny fluid after winter?
  84. Hard getting to neutral
  85. Dyna clutch help
  86. 68T IDS sprocket on '07 FLHX
  87. Mainshaft end play
  88. Pink Transmission Oil
  89. Inner Primary, loosen or grind when replace compensator????
  90. Primary ??
  91. Suicide Clutch
  92. Broke primary chain tesioner
  93. Convert 09 FXDF to Chain Drive?
  94. 02 fat boy
  95. Gear Reduction Options on FL
  96. Compensating Sprocket
  97. Figure it might be clutch time...
  98. checking tranny
  99. Suicide clutch fab
  100. Transmission shifter repair
  101. 2007 dyna starter ring gear replace
  102. Primary cover
  103. Primary leak
  104. Regina Primary Chain
  105. Gearin from 08 to 2011 FLht
  106. Gear Oil Smell
  107. lower rpms
  108. flywheel rubbing against the crankcase
  109. squeal
  110. when removing the clutch cover........?
  111. Clutch release cover question, broken tab.
  112. gear change problem
  113. Derby Cover has no Gasket
  114. 2010 RK 6 speed transmission
  115. 1989 FLH needs transmission...
  116. Can I use the parts I have to make a 5 speed tranny with a kicker?
  117. 2007 dyna primary leak
  118. Cam Tensioners
  119. Foot shifter restoration
  120. Pingel shaft install
  121. OK, need a stronger clutch but have to be able to pull the lever !
  122. New Primary
  123. Primary Setup Question
  124. Transmission help
  125. Belt Tension
  126. Sportster Clutch Problems
  127. Tensioner
  128. ultime six chain drive
  129. Derby Cover
  130. changing clutch assy. and rear belt sprock
  131. 49 tooth ring gear
  132. chirping noise
  133. what tools do I need to install everything in the inner primary?
  134. clutch issues
  135. grinding when downshifting
  136. 200mm Doherty Machine kit
  137. 85 softail tranny
  138. 1987 FXR Tranny Question
  139. 09 sporster shifter gets stuck
  140. Compensator nut
  141. 49 tooth clutch basket sprocket anyone?
  142. Great end of Warranty upgrade
  143. Jockey Shift
  144. grinding noise in tranny found
  145. RK belt tension problem.
  146. 81 Sportster shift problem
  147. So Tell Me Guys ~ Where The Heck Is That Little Filter
  148. 78 4 Speed To 5 Speed Swap
  149. belt dilemma
  150. Is there a clutch "interlock" on the perch?
  151. '04 Softail standard--hard shift from first to second
  152. GP Designs Outer Bearing Support - questions
  153. Clutch Cable Problems
  154. 1988 flhtp clutch problems
  155. Kicker Stuck
  156. Easy Clutch
  157. hi tech belt drives...
  158. Clutch Cable Issue
  159. Removing gearset for 07 dyna tranny
  160. Clutch and vibration
  161. Help with Clutch Cable
  162. Help! My clutch won't release!
  163. 2010 FLHTK Primary Noise
  164. How to adjust '92 fatboy clutch?
  165. Drive chain tension
  166. how much primary fluid ?
  167. Part number vs casting number
  168. pressure plate 1985 tour glide
  169. Inner primary part number help
  170. Inner Primary seal replacement
  171. Installing New Compersator on '09 SG
  172. Cant get clutch hub on mainshaft!
  173. going from 1" to 1.5" final drive Belt is a prob.
  174. 2010 Street Glide - Clutch.........
  175. 1971 xlch clutch
  176. Y2K S/T Clutch pack changeout
  177. Engine to Tranny alighnment
  178. Help with gearing
  179. Picked up a BDL EVO-9S
  180. Transmission Shift Sprawl lever loose - Rear inbetween primary and trans
  181. clutch (no idea what to do)
  182. engine light & battery light coming on
  183. 98 fxsts "clunking" noise on warm start
  184. 2008 flhr with a primary noise
  185. warning clutch
  186. 2007 Ultra - Stator Replacement- What parts do I need?
  187. Dumped 2006 Sportster 1200...shifter and footpeg came off
  188. Ultima Starter Clutch
  189. Aftermarket compensators?
  190. 2003 Road King Clutch Issue
  191. Noise comin from Primary
  192. 89 FXSTC transmisson noise
  193. SE Compensator discontinued???
  194. 2004 FatBoy - Tranny Problem...
  195. Tranny shims
  196. Derby cover removal problem
  197. 2007 FXSTC Primary Drive ratio...?
  198. transmission/clutch problem
  199. Primary Chain Adjuster Failure!
  200. 6 speed ultima or revtech
  201. 6 speed in an 01
  202. Starter Question
  203. 1990 electraglide speedo help
  204. Need some advise
  205. Electra Glide shifter
  206. Clutch Removal on '86 HD 883 Sportster
  207. Open belt drive primary
  208. Need a stronger clutch
  209. Automatic Primary Chain Tensioners...how much better than OEM?
  210. baffle removal
  211. Clutch hub wobble
  212. Need torque specs, changing to stainless bolts
  213. Need Help Tightening Trans cover hex bolts
  214. Mousetrap problems
  215. '99 EGC Drive Belt
  216. TC96 RSD trans question
  217. Comp Bolt Loose???
  218. Starter drive gear
  219. solid mount an FXR
  220. Got My EGC Stuck Deep in the Sand. Any Potential Problems?
  221. 6 speed installation in a 2003 softail heritage
  222. Tranny drain hole thread repair
  223. 2011 FLHTK Clutch Lever Issues
  224. primary chain tensioner
  225. inner primary seal
  226. Chatter in Primary
  227. clutch
  228. 2nd gear issues. Need help!
  229. 1000 mile service. Importance of adjusting the clutch?
  230. CLutch Whining and Squealing - Help
  231. Transmission clutch release cover - Leak
  232. Cam Conversion Kit - Feuling? Andrews? Woods??
  233. 1998 Roadglide EVO
  234. Hard Shifting
  235. 2007 sportster only starts in neutral??
  236. Clutch Squealing - Help
  237. Changed primary. Screwed up???
  238. Primary drain plug stripped
  239. Need more ''top in'' for my 2009 883
  240. primary howling
  241. gear gone bad, drive line
  242. Trouble starting... Lots of noise. Help.
  243. Spline Broaching For Shifter Shaft
  244. Won't Idle Unless Completely Warmed Up
  245. left side noise
  246. Downshifting issue
  247. 03 Road King - Clutch slipping
  248. Primary Chain Stretch
  249. Rivera/ Primo 6 Speed
  250. Difficult shifting into 4th and neutral
