PDA
View Full Version : Primary/Transmission/Driveline/Clutch
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 [32] 33 34 35 36 37 38
  1. Supermax belt drives
  2. six speed
  3. 03 roadking
  4. Transmission plate
  5. How to install Easy Pull Clutch Kit
  6. clutch cable replacement - 07'
  7. Changing from belt to chain...help needed
  8. DRiveline problem, seek help
  9. clutch seal in primary cover leaking
  10. Permatex aviation gasket sealant #3 ??
  11. Unknown engine
  12. Unknown engine
  13. American Iron (AIM) re: 07 Ultra Clatter
  14. Adjusting clutch
  15. Clutch lever rattle
  16. Rotary top trans How do they work
  17. Final drivebelt tracking issues
  18. Primary howl
  19. HELP, Rattle coming from shifter
  20. help on performance package
  21. Clutch Basket in Pieces chain jumped and pics
  22. Grinding gears
  23. Tranny Swap
  24. from belt to chain?
  25. How much power can my tranny take?
  26. stripped out primary drain plug
  27. 2002 EG Classic new noise
  28. video of clutch adjustment
  29. Does this gear need to be replaced?
  30. Rookie Mistake...
  31. Primary Drain Plug
  32. Who can tell when primary needs adjusting
  33. clutch trouble?
  34. Clutch, 1st gear
  35. I need about 15 more mph
  36. 4-speed problems
  37. Easy Clutch or Auto Clutch
  38. Outer primary cover removal
  39. trans and clutch craped out
  40. 08 trans pulley
  41. Clutch ???
  42. What is the cheapest and best 6spd to install
  43. 80 rotary top trans mainshaft tolerance??
  44. Transmission pulley 2008 FLHRC
  45. Clutch Issue
  46. DD6 Issue???
  47. Inner Primary Removal
  48. Main Shaft first gear removal
  49. You like it THICK or thin?
  50. tranny
  51. Put Spectro 6-Speed in today..
  52. 2000 to 2001 tranny difference
  53. labor to install IDS
  54. Primary Gasket Replacement Advice
  55. 2008 ULTRA IDS BEARING FAILURE & RANT
  56. 5 Speed vs. 6 Speed
  57. Switched from Formula+ to Mobil 1 Tranny, Question
  58. vent hose on the transmission
  59. Tranny slip.
  60. Rear Tranny Space Cover
  61. Shifter lever
  62. inner primary removal
  63. Clutch shifting
  64. neutral light on ultima 6 speed
  65. No belt guards?
  66. Winter Question
  67. EVO Ind. 30 tooth pulley, Info please.
  68. Primary Chain Tensioner
  69. FINAL DRIVE BELT WEAR?
  70. lost washer in primary
  71. replaced levers, now have a problem
  72. Looking for Harley Mechanic NYC
  73. 88 FXRS clutch problem
  74. Primary Cover
  75. Stock Clutch Disks Or Kevlar??
  76. Automatic Primary Chain Tensioner
  77. Whats the difference.....
  78. used parts?????
  79. transmission/primary fluid
  80. Cam Chain Tensioners
  81. Clutch Kits
  82. HD Clutch Reducing Kit
  83. Is it safe?
  84. 98 FLHTCI Oil pan change
  85. tranny rebuild
  86. transmission leaking on 06 street bob
  87. Dyna Street Bob 08, Fwd Control Kit Install Help Please..
  88. TRANNY NUMBERS
  89. clutch adj. 2007 sporty
  90. Filling Primary
  91. noisy shifting
  92. gear box drain plug
  93. my experience with the revtech kickstart kit
  94. Rear Pulley Size
  95. looking for 1980 flt inner primary
  96. FLHRCI 01 Tranny question
  97. replacement for compensator pulley
  98. Clutch Hub removal
  99. New Baker w/ 5 Quart Oil Pan
  100. Gear shifter rod
  101. Evolutions Industries 30 tooth sprocket
  102. Transmission offset install with 250 kit
  103. Transmission noise
  104. bdl help
  105. HD Reduced Effort Clutch
  106. 22 Tooth Comp Sprocket and M-6 Chain Interference??
  107. Bulletprüf Drive Belts
  108. Mobil-1/Amsoil gear oil & tranny warranty
  109. Tools to work on my Harley
  110. changed from 20/50 to tranny oil
  111. Belray tranny lube in 07 6 speed?
  112. Problem shifting into third gear
  113. Strange problem
  114. auto-clutch
  115. Bushing install on primary cover
  116. Hard clutch-89 FXR
  117. Gasket holder?
  118. Primary Question
  119. Chirping when wet
  120. Re-jetting my carb. Suggestions?
  121. manual says check belt deflection with weight equal to rider?
  122. HB-125 Replacement Shoe?
  123. Clutch upgrade to handle HQ build
  124. Tranny mainshaft fluid leak
  125. hard to find neutral
  126. Primary part number question
  127. Clutch basket wobbling??
  128. Fluid quantities ???
  129. Drive belt dust?
  130. Burn Smell In Primary Case
  131. Hearing a noise...
  132. Shift Shaft and Heel Toe Shifter Problems
  133. Primary gearing
  134. Hey guys newbe got a ???
  135. Stage III where next? Heads, Cams,Help!
  136. 2008 6 speed tranny
  137. oil type for primary
  138. 2002 wide glide primary
  139. 1989 Sportster frame
  140. Oil leaking 4-speed gearbox
  141. Measuring for clutch cable??
  142. Wide Belt Question
  143. Expected Engine Life
  144. New (or Replacement) Clutch Cable Adjuster Cover?
  145. CLUTCH CABLE REPLACEMENT
  146. Ran Tranny dry 1oo miles
  147. 06 wide glide trans question
  148. transmission 4-5 or 6 speed
  149. Primary Screech
  150. do I need to open the transmission?
  151. I this normal or does my clutch need a slight adjustment?
  152. Newbie needs help, how do I fill hole in inner primary cover left behind by shifter rod
  153. Drivetrain drawings
  154. 1985 FLHTC trap door swapping
  155. compensating sprocket Nut broken
  156. noise in my 66 sporty
  157. Lifting your Harley
  158. Problem shifting 77 Sportser
  159. Repairing oil leak...
  160. Resealing Primary
  161. Vibration Cured!
  162. Bearing Noise
  163. Size of Rear Pulley
  164. Back cut gears/powershifting
  165. Hd FXR evo rear trasmission advise
  166. Trans dipstick
  167. Baker Clutch(s)
  168. Tranny fluid 05 Heritage
  169. DERBY COVER LEAK
  170. Vibration
  171. IDS ??
  172. CRANKSHAFT RUNOUT 2007'S ANY CONCERNS ANYONE?
  173. Picked up incorrect MTL
  174. 74 ironhead primary chain
  175. OIL SPECIFICATION O5 ROADGLID
  176. Replaced clutch cable please help!
  177. Noisy 07 Twin Cam Transmission
  178. Pushrod covers help
  179. Bigger compensator
  180. Are the new transmissions well made? high quality?
  181. lost considerable tranny fluid out breather
  182. clattering clutch
  183. Primary Venting
  184. mainshaft thread pattern
  185. Oil leaking from clutch cable
  186. just installed ids
  187. Super Spoke Pulley
  188. IDS for Heritage?
  189. Simple belt tension check
  190. 08 Sportster 883R weird noise/sound
  191. '07 6 speed trans
  192. Leaking quad seal
  193. Primary Bearing 06 Dyna and newer models
  194. 2007 tranny/engine gasket leak
  195. BakerDD6
  196. Speed in Gear
  197. IDS and my Dealer...Ocean County Harley
  198. Primo Pro Clutch??
  199. Primary oil install
  200. Question about clutch basket
  201. Knocking Noise from Primary on Super Glide
  202. New 2007 Dyna Low Rider.Oppinions??
  203. Jack Shaft Issue?
  204. Lubricating the clutch cable
  205. Primary seal replacement
  206. Primary chain adjustment help
  207. 2006 Cam Chain Tensioners
  208. clutch question
  209. Metal in transmission Oil
  210. IDS for cheap
  211. 5 Hole & 3 Hole Derby Covers
  212. IDS - What is it?
  213. Converting Fat Bob to mid-mount controls
  214. Look at what this Editor says....
  215. clutch adjustment
  216. Oil Slinger on vTwin
  217. Stiffed in the UK
  218. Loctite Pipe Sealant Teflon 565
  219. tranny vent screw
  220. Drive belt
  221. Neat Idea here......from Corbin
  222. compensating sprocket
  223. Oil passing from engine into primary
  224. After IDS "whine".......comments?
  225. EVO Clutch Release - Intermittent problem
  226. Automatic primary chain tensioner?
  227. anyone do a 5-Speed-in-a-Four-Speed Case?
  228. 5-Speed gear set
  229. Gear drive camshaft kit
  230. IDS installation instructions?
  231. 6 Speed Pushrod Asembly
  232. how tight....on primary chain......
  233. IDS and spoked wheels
  234. AHHH HELP (Clutch on a shovelhead).
  235. Another leak issue
  236. have you noticed how quiet it is
  237. Oil Leak
  238. '88 883 problem
  239. Whirring noise in 06 Dyna SG
  240. 75 shovel, primary chain ???
  241. Whirring noise in primary
  242. Question about Ultima 6 speed install
  243. FRX trans ratio and final drive ratio
  244. ultima 6 speed 2-1 down shift prob???
  245. Remove Rubber (factory) Shift Peg
  246. Mobil-1 75W-90 color?
  247. odd shifting noise question
  248. Big Difference - IDS Installed
  249. NOISE !!!!
  250. Transmission repair
