PDA
View Full Version : Primary/Transmission/Driveline/Clutch
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38
  1. Clutch slipping after 128 build
  2. Ultima 6 speed
  3. Primary clutch or trans knocking noise
  4. 09 fatboy clutch questions
  5. Love Jugs? Cooling jugs?
  6. Engine out of a 08’ crossbone 96ci
  7. Which way to loosen the nut?? Softail Deuce 2002
  8. 2013 fltrx issue
  9. Shudder from primary in neutral. Clutch handle released.
  10. Tranny question
  11. Clutch adjusting screw too short!!
  12. Hard Hit on First Gear after Changing New Clutch Cable
  13. starter locating pins
  14. What spacer for Timken conversion on 07 FLH?
  15. Transmission Question
  16. 1984 Softail Foot Clutch Conversion
  17. What color is formula +
  18. 2015 CVO A/S Clutch....will the SE high capacity fit?
  19. TC 88 Compensator
  20. Whistle Primary side
  21. Derby cover screws.....
  22. Clutch Lever Buzzing
  23. Noise and "surging" on deceleration.
  24. 07 FLHX Derby cover/outer primary sizes??
  25. Dsr1
  26. IDS drive pulley flht
  27. Starter problems
  28. ***NEED HELP*** Primary guts
  29. 2010 FHLX gearbox noise on jiffy stand
  30. Hayden primary tensioner 2001 roadking classic
  31. 2019 Softail Compensator Sprocket Failure
  32. Andrews adj push rod problem
  33. 2015 883 iron won’t move in gear
  34. aluminum shavings in my primary
  35. Shovelhead not engaging clutch
  36. Low Rider S Primary Question
  37. 1999 Roadking slipping in second and third question
  38. 2003 RK shift shaft seal leaking
  39. Dragging after adjustment
  40. Barnett scorpion Headache
  41. Ultima OD6 speed left side transmission question
  42. What are the differences between IPB 9231 and 9135?
  43. Primary chain slack after baker attitude adjuster 2009 heritage
  44. Sportster dies when letting off the clutch
  45. Shifter Problem
  46. 1990 sportster drivetrain swap
  47. 96 FLSTF shifter falls forward and back
  48. Clutch change over...
  49. Clutch won’t engage.
  50. New Member seeking info
  51. Final drive belt question
  52. Drive belt alignment 2009 heritage
  53. Does an open primary make shifting smoother?
  54. 2000 Red Horse Chopper Starter/Pinion Gear/Ring Gear issue
  55. Primary side noise
  56. 6 Speed for 1990 FXR
  57. compensator noise 2008 Elecrta Glide UC
  58. Push rod adjustment
  59. Iron head transmission work
  60. Chunks in primary
  61. Replacement derby cover bolts with hex head
  62. New clutch
  63. 2009 FLSTC comp sprocket bolt #3368
  64. clicking noise when clutch let out
  65. 1998 Custom Sportster Anniversary 1200cc Clutch release plate explosion
  66. 6 Speed Reverse gear set
  67. 05 heritage softail classic- compensator nut fixed but now runs like c**p
  68. Bandit clutch hub
  69. 5 speed transmission interchange for 1990 softail
  70. Cam install
  71. Another primary issue.
  72. 2013 fatbob fluid changes
  73. Replacing clutch cable
  74. Main Drive Gear Inner Seal Naming Conventions
  75. 2000 Sportster 1200 primary/clutch mystery.
  76. 2001 dyna superglide inner primary leaking
  77. Clutch and Compensator compatible?
  78. Replacement Clutch Cable for '18 FLHC
  79. Transmission Mount not flush with frame
  80. Transmission Mount
  81. Transmission mount to frame
  82. 1998 Harley custom sportster 1200c Anniversary
  83. fr33thomas
  84. Transmission off Frame mounts by 1/4"
  85. Primary oil change question
  86. Screamin' Eagle Manual Primary Chain Tension Adjuster
  87. Broken countershaft bearing removal
  88. Oil leak inner primary by Stator?
  89. Inner Primary Sealant
  90. 2005 FLHT Compinsator
  91. baker compensator
  92. SOMEBODY STOP ME!!! Or not... My dealer says don't do the 30T 70T pulley swap.
  93. clutch broken
  94. Clutch or Transmission
  95. 2016 Softail Deluxe Neutral issues
  96. 94 evo 5 speed tranny fluid choices
  97. Goodyear Falcon Belts?
  98. 2008 FXSTSSE2 new compensator required
  99. Changing clutch cable for ape bars
  100. Barnett clutch plate bolts backing out -- loctite?
  101. Need a little help
  102. Primary fluid for new barnett clutch
  103. Clutch cover question
  104. Softail Evo 6 Speed Conversion - Gear Assembly Only
  105. relocating foot controls
  106. What are 76 flh tranny output shaft oil leak upgrades?
  107. Trans Needle Bearing
  108. 75- SXT125-aermacchi-shifting trouble
  109. Clutch release push rod
  110. Cant find Neutral
  111. 2016 compensator questions.
  112. Clutch is sticky
  113. Seals for the Inner Primary Bolts
  114. Primary rotational parts (Best parts)
  115. Clutch/shift linkage problem
  116. A LOT of water in the primary
  117. Clutch basket nut
  118. oil from tranny toprimary
  119. Transmission
  120. M8 CVO Odd Downshifting
  121. 86 softail main gear nut
  122. Seal in fifth drive main shaft.
  123. 2019 HD Clutch Problems
  124. Transmission oil leak
  125. Primary cover interchangability
  126. 1966 FLH Electra Glide
  127. Transmission Oil transfer to Primary
  128. Troubled 00 5 speed
  129. Clutch squeal sound w/videos!
  130. where did I go wrong?
  131. Trap door bearings
  132. Stuck on primary....
  133. Need Some Help
  134. inner primary
  135. Shovelhead Trans sprocket
  136. Clutch Slipping or Trap Door Bearings
  137. 2001 Fat Boy always hard to shift from 1st to 2nd but this AM was nearly impossible
  138. Primary Chain Recommendations
  139. Armored Attitude Adjuster
  140. Ultima Six Speed Trans
  141. 6 speed questions...
  142. primary oil level
  143. Vibration 1600-2100
  144. BDL tranny problem
  145. 07 dyna trans output shaft
  146. which drive belt?
  147. Noise when clutch is engaged
  148. Is a new swingarm required for chain drive conversion?
  149. 1984 Harley Davidson Sportster
  150. rekluse clutch friction plates or stock?
  151. Clutch problem after VPC
  152. Hayden M6 BT-07
  153. Evil Engineering Clutch Springs
  154. Forwards to mids
  155. Clutch Release
  156. 2001 XL1200 downshifting issue plz help.
  157. 1967 sporster XLCH, 3rd gear jumping, only with no throttle, with throttle no problem
  158. Transmission Question
  159. Primary noise and burnt smell
  160. Push starting
  161. Neutral or NOT
  162. Good starter brand?
  163. Compensator Eliminator -Your experience with 32T or 30T sprockets
  164. Drive Belt
  165. Toe shift lever went limp - heel okay
  166. tranny swap
  167. Hydrolic clutch friction zone (solved!)
  168. burnout!
  169. Primary Leak
  170. broken clutch cable
  171. Stuck inner primary cover
  172. Which way to turn clutch adjustment screw?
  173. I can use this oil for primary case?
  174. Midcontrols convert
  175. Hydraulic clutch line heat concerns
  176. Red oil coming out of tranny shaft on clutch end?
  177. clutch issues
  178. No clutch lever tension. Cable good, moves ball and ramp
  179. starter gear and end play shovelhead
  180. 2009 Flhx transmission repair ?
  181. Clutch hub bearing
  182. 1975 ironhead sportster shifter playing
  183. Sportster Clonk and slack feel in driveline
  184. Sportster dies when put into gear
  185. torque specs
  186. Clutch Cable on Bagger
  187. shift problem
  188. Clutch problem brought to me
  189. homemade primary bearing tool
  190. What to update on 07 primary?
  191. Ugly rattling noise. Maybe primary?
  192. Evo 5spd Sticks in 1st gear when dead cold
  193. HD-34902-C - best tool?? (2008 and up touring) - primary bearing race removal/install
  194. EVO clutch adjustment gone wrong
  195. Clutch ID ?
  196. Good Primary Bearing?
  197. Replace hydraulic clutch with cable clutch
  198. primary "extra part?"
  199. Primary chain slack
  200. Alignment issues!?!?
  201. 30T pulley
  202. Using clutch tamer kit and bigfix???
  203. 1973 shovalhead clutch question
  204. please help
  205. 2003 screaming eagle cluch
  206. Lost.
  207. Chain conversion sprockets
  208. Need help please
  209. HELP 78 fxs shovelhead inner primary/clutch hub/front pulley/stator issue
  210. Gears in transmission
  211. Hydraulic clutch fitting leak
  212. 68 tooth rear drive pulley for dyna ?
  213. front transmission sprocket
  214. BDL Competitor clutch on Evo FLSTC
  215. Peculiar starting problems (transmission/clutch related, probably)
  216. hydraulic clutch
  217. Primary Cover Bolts
  218. 2001 Buell X1 Lightning that will not shift into 3rd, 4th, or 5th
  219. 88 electra glide classic trans upgrade
  220. 88 flhtc trans upgrade
  221. Primary belt replace
  222. Leak: Primary or transmission?
  223. Transmission noise
  224. Transmission Sprocket Nut Stuck
  225. Worn out inner race
  226. Stiff clutch
  227. 88 Sportster won't shift
  228. Final drive belt
  229. One Piece Inner Primary Bearing, or S&S race?
  230. Clutch Basket ID......
  231. Clutch adjuster rod overtightened
  232. Grinding on Hot Start
  233. 1996 HD EVO FXSTC Softail Belt Life??
  234. 1970 4 speed won't downshift
  235. Drive pulley bolts location
  236. Frozen Clutch
  237. Sportster clutch replacement: with a twist (HELP!)
  238. Different primary cover?
  239. Inner Primary Sealing Fasteners ???
  240. Chain Final Drive Pulley
  241. Clutch Recommendations
  242. clutch problem
  243. clutch adjustment
  244. dyna compensator question
  245. Heavy Clutch.
  246. Main Shaft Seal - 2016 FXDLS
  247. 194 FXSTS Outer Primary Cover
  248. Tuning lock up clutch
  249. Clutch slipping during shifting
  250. do I need a drive belt??
