- Inner primary mainshaft oil seal: should it seat completely?
- Inner primary mainshaft oil seal won't stay in!
- Broken Aftermarket Clutch Lever
- Reverse on 2009s
- Primary Drain Leak
- Main Drive Gear O-Ring?
- Four speed kickstart
- Main Drive Gear Bearing Oil Seal - sealant?
- Driveline vibration/skip
- problem 93 roadking clutch
- Low Transmission fluid...Damage?
- How to replace a drive belt
- Mainshaft Inner Race: COMMON Loctite / Permatex / other products to "retain"?
- 1996 Shifter shaft replacement
- Filled my Primary from the drain hole
- Do I need to adjust clutch?
- How do you adjust the front brake grip?
- Transmission Sprocket Spacer - actual differs from manual
- Can't Remove Primary Chain Inspection Cover
- Derby cover hot
- Loctite 601 Retain Compound? What to use instead?
- Drive Belt and Swingarm Mounts?
- Engine rotation by rear wheel difficult
- auto primary chain adjustment
- clutch lever feels sloppy ??
- Replacing my clutch. simple question
- Quart over full in primary
- Milky Transmission Fluid
- 3:15 to 3:37 change questions
- IDS washer size?
- Primary adj. retaining ring won't stay
- How to remove clutch Hub
- New clutch on a 1998 Night Train
- Loud primary
- Trans wear, what to check first
- Clutch Adjustment Problem
- Screamin Eagle Big Twin Compensator
- Transmission or clutch problem
- oil leak
- primary oil level
- New Vibrations after Belt Change
- 2009 Softail with transmission clatter
- 55 tooth rear drive pulley for Sportster
- Changed oil in Primary... now
- Pulley Tooth?
- raising shift lever; sportster 1200
- transmission life
- Primary chain noise
- REVTECH 6 speed conversion
- TROUBLE... 2003 Road King
- 6 speed tramnsmission
- stripped tranny side cover
- What's the deal
- Starter bushing
- Changing clutchs
- tranny problem
- how often do your REALLY need clutch adj?
- Replacing clutch on 95 sporster
- Clutch Squeal
- Primary gearing
- Help needed with new IDS problem on '07
- leaking clutch fluid from shifter help!
- Best wet clutch?
- gear ratios on 78 lowrider
- Odd Noise
- who makes OEM parts for H/D
- Rattle at Startup
- clutch adjustement help
- Dry Primary Question
- I'm lost and tired.. Maybe someone can help!
- Drag specialties easy clutch by white brothers
- Easy clutch
- Barnett clutch spring conversion kit
- engine sprocket question
- Trans drain plug
- Selector Rod Adjustment
- 1st gear
- Hydraulic Clutch?
- 2008 XL 1200R Transmission Problem
- baker 6 speed dd vs harley 6 speed dd
- Upshift. Extra 'clunk' as shifter resets?
- Mainshaft Locknut Wrench & Trans Sprocket Tool
- Primary drain plug
- Metal on primary drain plug
- tranny not engaging
- Changing Primary Ratio w/ Evo Ind 49t Sprocket
- Shifter Linkage, 88 dresser
- Broken shifter pawl ?
- counterbalancer noise
- EVO drivetrain in TC frame?
- Transmission Question
- Pitting on sprocket
- Cams only or with S&S headkit ?
- shifting problem
- Clunk clunk clunk at crank-end of primary drive
- '91 FXR shifter question
- 5speed gearbox gears
- Must I remove the engine to rebuild the trans?
- Transmission Side Cover - HELP!
- Inner Primary O-Ring
- 06 dyna primary bearing
- Primary Fluid
- Clutch adjustment question
- Automatic Chain Tensioner
- Bleeding the clutch
- Tension Shoes
- Primary Tenisoner Shoe ???
- 98 Evo: Release clutch, hear gears grinding, go nowhere
- Hydraulic Clutch adjustment-2008 RG
- 1988 RK striped shifter shaft
- Help!!! Throttle loose and jerking
- can't find neutral
- HD trans Rebuilt cost
- H.P. Clutch Adjustments ?
- Changing lube early?
- Scraeming Eagle Compensator
- !978 ironhead sportster
- 04 roadking belt drive problems
- most likely a dumb question, but.
- Life of a Primary Chain Tensioner Shoe
- should I buy a 2006 lowrider or not due to primary bearing and race
- Engine problems - Need advice
- SE 6 speed problem
- 08 FLHR Clutch Adjustment
- installing 6 speed trans on a fatboy
- Clutch hub and clutch housing removal
- 1st gear problem
- Fluids
- clutch hub bearing info
- clutch change out..
- Drive sprocket stripped
- 4th gear noise
- Easy Clutch Adjustment
- visual primary lube level
- Tranny Gear Lash??
- Noise from clutch
- kick start
- Transmission Diagnosis
- Drive Belt Replacement?
- ultima 6 speed gear swap
- Checking oil?
- Longer clutch life
- Primary Tensioner
- 3 rd gear whistling on aceleration
- 94 Ultra Drive Belt
- Trans shavings @ 25K
- toasted new trapdoor bearing
- Clutch cable
- Replace a Drive Belt '99 Electra Glide
- Whinning/whislting
- Hard shift up to third gear
- Primary Questions
- 02 FXDL feels like missing gears
- shifting without clutch?
- Squeeky Clutch!
- Bottom End Chatter
- inner primary case
- Clutch Problems
- Downshifting problem
- Micro tach + digital tachometer
- Clutch cable adjuster only.
- Adjusting a 08 clutch with just the cable?
- 2009 rear sprocket on 2008
- Starter won't engage-2001 Roadking
- Torque Specifications
- inner primary bearing race spacing
- 5 speed to 6 speed conversion kits
- Prowler 6 speed transmission
- No First Gear - 2007 Dyna
- 06 Nighttrain broken belt here is the 530 chain conversions specs
- HELP!!! drive sprocket stripped
- Try to find clutch info need help
- 2008 sportster transmisson fluid leak
- Cam chain tensioner
- Primary Oil
- Clutch slip on start
- Trouble getting into one gear (sometimes)
- skip shift
- 2001 FLHT 5-speed Overdrive ?
- Weird Noise at Idle
- Primary nearly dry, possible additonal damage?
- final drive belt noise
- Preloading the compensating sprocket
- 4th Gear Whine
- Shift Arm
- Using ATF in a primary?
- Clutch adjustment problem
- Final Drive belt noise tracking problem
- coupling rubs on case
- whine on decel
- Inner primary case dowel pins
- Vibration driving me crazy
- Installing a 6 speed in old Softail
- Clutch dump
- 2006 Dyna Primary Bearing Failure
- Primary cover stuck.
- Baker 7 speed DD7
- HELP!!! Clutch Adjustment Problem!!!
- drive belt
- TEST
- Gear noise on '08?
- '83 Shovel Clutch Cable Broke AGAIN!
- Neutral on Transmission
- Inner Primary & Pulley Seals
- Chain tension in primary with HD auto unit
- Shift lever sticking
- Drive Belt Size?
- Pulley and belt question
- Clutch Diaphragm spring TQ spec's
- Clutch lever problem
- NEW- USED CLUTCH HUB TOOL
- Hard Shift
- Shift linkage pivot Identification??
- symptoms of primary chain too tight?
- Noise from primary area when bike is wet
- Auto Chain Tennsioner on a Baker DD6
- Going from a 34T to a 32T or a 30T?
- Mainshaft Bearing Inner Race removal
- confused about primary
- Suicide Vs. Rocker
- primary chain tension
- Putting Mobil 1 Synthetic Gear Lube 75W-90 in primary....
- Inner primary housing mounting surface pitted
- Chain Kit for 2007 on
- Belt Noise
- Engine oil bleeding into primary
- Primary oil level and clutch function
- Clutch Engages Too Far Out
- Weird clutch issue
- Clutch Life
- 05 wideglide primary
- Oil Filler
- Overfilled Primary and Transmission - Consequences?
- Gaskets - Which Brand?
- Possible destruction of gearbox
- Clutch question
- 2008 FXDC running hot
- jam nut "jammed" please help
- primary chain
- How much play
- BLOWN ENGINE??????
- which clutch cable
- New clutch cable has less slack
- Adjusted drive belt vibrates
- IDS Removed
- Mainshaft inner race on too far
- Which sprockets?
- shifter rod lever replacement
- Normal or Leak?
