- 1997 sportster making a strange noise
- somethin dont sound right
- Primary drain plug
- Stupid question
- EVO Primary on TC88
- transmission leak
- sportster drive belt question
- popping into neutral
- shovel clutch
- 07 Trans...or clutch maybe. Somethings up.
- number of teeth on stock motor sprocket 2003 flht??
- 99 Evo Driveline Chatter/Clatter
- Primary tension
- budget clutch upgrade 06dyna?
- Crossthreaded drain plug
- 71 sporty trap door
- Is 32 oz enough? Help
- Grease fitting and heim joint shift linkage!!!
- SE ignition/cam noise question
- 92 FXSTS clutch -- can I pull it w/o the compression tool?
- inspection cover leak
- Noise In Primary
- Primary rattle on 2002 Fatboy...
- compensator spring pack
- Help! Trans Noise kinda a racketing sound
- Beastmaster 6 SP Trandsmission ?
- clutch adjustment
- Cam Chain Tensioner
- Help with my Trans problem
- shovel clutch
- help with clutch cable
- oil on oil tank
- FXDWG Tranny Oil Drain Plugs
- 07 08 primary noise
- HELP my Trans is stuck
- how much to change
- 5th gear clatter does it cause harm ?
- Changed starter now ATF is leaking
- No IDS Required
- Rivera Pro Clutch
- Tom Hayden M6 Chain Tension vs. HB-125 Hydraulic Chain Tension
- Baker DD6Drivetrain vs Harley Screaming Eagle 6OD Drivetrain
- Clutch reinstalled question on nutural adj
- Flushing the tranny
- small whine at a specific point
- 1st gear sticking...
- Clutch slipping after big bore kit installed
- Primary Drain Plug
- Clutch adjustment
- Compensator Question
- What about Royal Purple as primary oil?
- Stock vrs 6 speed
- Clutch and neutral indicator problem
- Clutch Sticking
- opinions needed on possible problems
- TwinCam 88 5th gear - how many teeth?
- cross threaded trans.drain bolt..any easy fixes?
- 07 SG - Primary Whine - Suggestions ?
- open primary belt drives????
- slipping the clutch with hyraulic clutch
- Engine lugging in 5th gear
- Royal Purple
- 1st to 2nd hard to shift
- TC88 vs. TC 96 FLH Derby Cover Changeability
- torq specs
- 07-08 Primary chain tensioner
- chain to belt conversion???
- Clutch problems
- Inner Primary Help! Can I swap??
- clutch for 113"
- Derby cover removal
- Primary Gasket Change Necessary?
- Belt Drive for Roadking
- Starter jackshaft bolt spins itself out
- ENERGY ONE Clutches?
- 07 Dyna rear sprocket
- secondary belt drive tension
- Water in transmission
- gear whine in two gears (?)
- shifter needs lots of movement to shift
- Oil leak from shifter, 04 sportster
- 3" belt replacement
- ATF fluid in primary???
- Floppy gear shift
- Belt tension phenomenon
- motor sprokets
- Ultima 6 Speed Tranny
- 76 IronHead Sporty Clutch question
- 6 Speed 07-08 Gear Box
- 2002 Fat Boy Starter Pinion and Flywheel
- problems shifting 2nd to 1st
- Help Throttle caable
- Help! primary case oil leakage
- Primary fluid... full quart in but still can't see it.
- HELP!! - Transmision Oil Change thru Primary chain cover?
- STICKY SHIFTER
- Primary/Clutch dragging question??
- Rocker Compensator
- REAR PULLEY
- Unknown Problem....Please help.....
- Softtail Rear Sprocket
- Old Age Is Here
- Transmission Gear Lube ???
- Better primary chain tensioner
- Primary noise w/o helmet
- clutch cable lube
- Empty hole right side of 5 speed
- Trans shift problem
- The wife's ticked off at Dalton & Dawg!!
- BARNETT Clutch Scorpion
- 06 FXSTSI sprocket
- New 7 speed trans for Harleys yes its true
- No suicide shifts!!
- Help with Dyna forward controls!!!
- Compensator(Again).
- oe belt
- One quart and tranny's not full -- Huh???
- Primary chain tension on a sporty
- 6 speed tranny conversion
- How much Metal is TOO much in transmission?
- K&N RK-3909 Kit Install Problems and Solution- '02 FLHRi
- clutch basket vs inner primary cover
- 2007 5th gear, no slapping
- SCREAMING EAGLE HEAVY AIR CLEANER KIT
- Clutch adjustment help please
- suicide clutch
- Custom forward control extension?
- suicide clutch
- Can you gear down a motorcycle?
- Clutch Lever Removal
- automatic primary chain adjuster
- Solid motor sprocket conversion kit
- Clutch Kit - Replacement
- Rookie question, is clunk normal during shift?
- Clutch Kits 8000 miles ?????
- Clutch is too loose - need help
- Rear drive belt
- She has to get naked - what to take off first
- EVO Industries 30 tooth engine sprocket installed
- Troubling findings
- Vibration horrible after tire change
- Sportster Gear Oil
- roadking custom high speed wobble
- clutch spring pressure adjustments
- RoadKing primary belt drive who dun it?
- squeak when I downshift
- more tranny clunk
- clutch interlock switch question
- Help please, My first oil changes, help help
- Clutch rod on 6 speed gear set
- starter problems
- IDS/Cush Drive Question
- loss of kicker
- new clutch Cable- do I need clutch adjust??
- Rear Belt for a 2001 Road king
- inner primary fitment question
- Vibration
- Can I borrow your tools? Jacksonville, FL
- dry clutch to wet style mods
- 1st gear klunk
- Primary fluid color at change
- 2007 Starter Ring Gear
- ok now what??? (re-installing CAM Tensioner)
- Clutch Adjustment: What did I do wrong?
- Is this normal? Inner Primary
- I figured it out... Engine Whine
- 5-speed transmission Rebuild
- Can SE Clutch Spring handle higher HP & Torque?
- GRINDING NOISE & A 3RD GEAR PROBLEM
- Harley Reduced Effort Clutch Kit
- Clutch Plate Replacements?
- Getting bike in neutral while running
- Considering pulley change...
- Clutchcable/FB-07/Magnum Chromite/draw
- Transmission fluid leak, help!!
- Clutch slippage
- Clutch/Throttle Cable Install - FLTRI
- removing and reinstalling adjustable pushrods question
- Outer Primary Clearance w/ Rinehart Exhaust
- Help changing front sprocket....
- What is the attraction of a six speed?
- Need help. Clutch poping no return.
- Shifting weird
- Rear Wheel Alignment After Drive Belt Adj.
- Air Temperture gauge?
- Dry Primary??
- Auto Primary Chain Tensioner Opinion
- Help
- help please! 03 train chain conversion
- DD6 speed sensor
- Why install VPC clutch?
- primary set up
- clutch upgrade
- IDS Question
- second opinion
- Torque Question - Primary Cover Screws
- aftermarket clutch
- Problem In Finding Neutral
- hydraulic clutch problem
- Adjusting Primary Chain Question
- Primary question on my Heritage
- Anybody tried an Ultima 6 speed?
- Shift pawl assembly
- HB 125 auto chain tensioner :-/
- Evo not going in to neutral
- primary chain tensioner change, questions
- Whinning...
- sport trans clutch oil
- Dyna Wide Glide Transmission
- Shift Shaft Seal
- Clutch Ring Gear
- Primary re-fill
- jockey shift suicide clutch
- Broken Shifter Spring
- chain tensorners
- Clutch adjustment problem?
- Open Primary Question
- "Fix My Hog" CD
- Help.....Primary Hardware Question
- Drive Belt Adjustment Question
- 5000 mile service
- 07 trans noise and starter noise
- Primary Gearing Change Chain and Adjuster Problems
- crankcase pipe plugs??
- Changing belt thickness
- Diamondback Clutch Cable
- rivera 6 speed
- Tight Primary Chain
- 28 tooth comp sproket and chain
- Help!!!!!!!! Please!
- Clutch adjustment question
- 17" wheels on a budget
- Clutch Slipping after BB-Need new Spring??
- Stripped Transmission drain plug FXR
- Torque Wrench / Screwdriver
- IDS for earlier touring bikes
- Inner Primary Install Question
- Wierd Clutch Problem
- clutch?
- PRIMARY GEARING
- Clutch Aadjustment Goes Away
- Saw it myself today, baker 7 speed.........
- Trans noise
- NEUTRAL SWITCH
- adding 6 speed, how much more mph?
- Auto Clutch
- 75 shvl primary chain tensioner ?
- Can't get clutch hub off main shaft - Stuck
- screeching sound when let up on throttle
- My rearend wobbles.????
