PDA
View Full Version : Primary/Transmission/Driveline/Clutch
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 [34] 35 36 37 38
  1. Did I ruin my tranny?
  2. synthetic gear oil to reduce noise in new bike
  3. 1981-80"shovel FLT
  4. advice on lubes
  5. Great Primary Chain Tension Gauge
  6. Did you see American Iron Mag trans whine Article?
  7. Clutch Cable Leaking.
  8. Odd problem
  9. synthetic lubes
  10. Changing Gear Ratio
  11. Changing Gear Ratio-/want less rpm at high speeds
  12. Gotta Go!
  13. Does switching from 32 to 30T pulley require new belt?
  14. clutch and or primary question
  15. Clutch lever pulsation
  16. Tranny/Swingarm problems
  17. PULLEY: Can you tell me this measure ???
  18. Primary fluid change HELP
  19. Drain plug size?
  20. milky swirls in transm. oil
  21. octane booster
  22. Zippers Trans mods incredible!
  23. Derby cover removal question
  24. clutch
  25. Easy Clutch?
  26. whining from the primary
  27. Engine ticking noise 1997 Evo
  28. Primary Gear change
  29. Primary chains tightest spot.
  30. Inner Primary Mainshaft Oil Seal???
  31. 4 speed trany clutch trouble
  32. HELP: 96 Hrtge primary oil drying up, mixed up with engine oil
  33. primary noise (higher RPM), etc.
  34. Dealer Service gone wrong
  35. Clutch Adjustment??
  36. HD issues a Recall on 06 6 speed
  37. Evo Clutch Hub replacement
  38. odd question regarding primary
  39. 06 SG can't shift to 3rd or 5th, HELP?
  40. Heavy Vibration When Stopping???
  41. Starting bike in gear.
  42. Easy way to recalabrate your speedometer
  43. clutch basket
  44. ENGINE
  45. Heavy duty clutch spring, stage II
  46. Changing rotor/disk on 03 FXDWG, need advice on belt tension
  47. 03 FXDWG tranny fluid check
  48. NOISEY CLUTCH?
  49. anyone useing ALTO Cabonite clutches???
  50. Primary/Tranny Oil Question
  51. Sportster Transmission, shifting problem
  52. turret top 4 speed?
  53. 05 whines in 4th
  54. Bike will not move in gear on the ground!
  55. six gear issue
  56. sleepneagle
  57. $500 drip fixed
  58. "self lubricating" chain?
  59. 82 FLH Question
  60. Need info about Twin cam gearset
  61. tranny leak - trap door gasket
  62. 1991 electraglide trans oil change
  63. Drive belt noise
  64. Blowing oil??????
  65. delete
  66. delete
  67. sockets needed for primary chain removal??
  68. Question about Derby bolts
  69. Clutch Noise?!
  70. NEED HELP FAST
  71. BDL BALL BEARING LOCK UP CLUTCH
  72. Final Drive Probs
  73. metal slivers on primary drain plug magnet
  74. clutch hitting primary cover
  75. clutch trouble
  76. Major Oil Leak!!!!
  77. Somthing to think about
  78. NUETRAL LIGHT
  79. 07 Super Dyna Glide won't start
  80. 2007 gasket service kit question
  81. Regearing Primary
  82. AMSOIL and REDLINE
  83. Pulley?
  84. Clutch Drag
  85. Changing the derby cover
  86. Difference between primary and transmission??
  87. Transmission Problem? '06 Night Train
  88. Derby Cover Gasket?
  89. Clutch adjustment locknut backed off
  90. Broke Shift Return Spring
  91. 2006 dyna clutch adjustment
  92. clutch springs and pushrod??
  93. HB-125 Automatic Chain Tensioner
  94. Primary Fill Amount?
  95. Will Harley Fix the Trans Issue?
  96. 07 CLATTER
  97. Powder Coated Covers Warning
  98. 2003 Fatboy
  99. Belt adjustment - special HD tools
  100. Adjustment on Final drive belt,bagger
  101. stuck in fifth gear
  102. Chain Slack - Upper Deflection
  103. Inspection Cover Gasket - Which Way?
  104. Rivera Pro Clutch
  105. tramsmission getting stuck in between gears
  106. main drive seal.
  107. 1000 Miles... Synthetic now???
  108. 2006 fxdi shift clack noise
  109. gear oil vs fluid
  110. Wrench for Clutch Lock Nut?
  111. Baker 30/31 tooth transmission pully
  112. Converting FXST 86-88 primary to 90+?
  113. Baker 6 speed
  114. New Engine Install. Should I have put the primary belt on first?
  115. clutch adjustment
  116. Clutch adjustment the easy way
  117. I can't find neutral pt. II (positive outcome)
  118. My 07 trans chatter fix.
  119. What is the best clutch recommendation?
  120. Questions for MOCO Tech's?
  121. Clutch?
  122. Ultima 6spd
  123. noises no more
  124. Best fluid for primary?
  125. 6-speed gear sets
  126. Clutch adjustment 07 ultra classic
  127. Primary over fill
  128. STRANGE SOUND FROM PRIMARY??
  129. Primary Chain Replacement
  130. Pipe plug?
  131. Why does HD recommend checking fluids when hot?
  132. please help
  133. Were is the Trans Drain Plug?
  134. Mobile 1 all 3 holes
  135. Newbie OIL Question
  136. open primary fitment question
  137. Transmission Removal
  138. HELP!
  139. Pea Gravel confusion
  140. 414-343-4056
  141. Lets see a list of phone numbers about 07 tranny
  142. Heavy duty clutch spring ?
  143. N Vs. clutch pull...
  144. squeaking noise when downshifting
  145. Shifting speeds and 07 clatter
  146. HD Auto Tensioner/Primary Problem
  147. Cant remove clutch basket.
  148. Are you lugging it?
  149. "new" 4sp transmission slips in 4th
  150. came back from dealer
  151. Clutch Problem?
  152. Burly Easy Clutch
  153. 2007 6 speed Tranny Noise
  154. new transmission for 89 sportster
  155. '96 Clutch Upgrade
  156. Afraid to take hand off clutch when in neutral?
  157. What should be proper play
  158. 99 FLHTCUI Tranny oil leak
  159. Rpm reduced from 1200 to 850-1000
  160. SCRAPE/SCRAPE NOISE FROM CLUTCH AREA
  161. Whirring noise coming from middle of engine/tranny?
  162. clutch adjusting questions
  163. Reduced effort clutch and slippage
  164. Drain valve
  165. Trans/swingarm separate?
  166. chain or belt
  167. shifting problem
  168. Selector Shaft Arm is loose
  169. Secondary Drive belt
  170. Clutch won't engage
  171. Clutch going?
  172. is it possible to have both mid & forward controls
  173. Drive Belt adjustment
  174. Shifting problems when warm
  175. 6 Speed Install Question
  176. clutch install instructions?
  177. bucking at low speeds
  178. Stuck in 4th Gear - 1995 Sportster 1200
  179. Splined shifter seal
  180. 2007 Transmission Data?
  181. Chain Conversion
  182. what's a clucth consist of??
  183. sportster primary chain adjustment
  184. Lucas oil???
  185. no first gear, kinda
  186. How do you use clutch, throttle, r-brake to generate torque?
  187. primary gasket
  188. SOUND QUESTION???
  189. Damn, it could only happen to me...
  190. Luggin' the Motor
  191. Looking for clutch help
  192. milkish trans oil
  193. Is there a 69 XLCH electric start kit?
  194. Ultima 6-speed
  195. Clutch Friction Plates
  196. Do you use oil in an open primary?
  197. shift linkage play
  198. Bike Kreeps Forward in Neutral
  199. 4 speed transmission leak
  200. ATF In Primary????
  201. mobile 75/90 synthetic gear oil
  202. New clutch cable need help
  203. Help !
  204. Oil behind derby cover ??
  205. changing primary oil
  206. Pinion Gear weak link
  207. compretion
  208. Mod'd motor, slipping clutch
  209. Stiff shifting to 2nd when cold?
  210. Sprocket?!?!?!?
  211. Adjusting clutch
  212. 15000 mile service 06 Dyna
  213. Clutch adjustment 79-84 5 spd.
  214. 6 speed Road max tranny..anyone?
  215. New clutch cable, too much slack for middle adjuster to pick up
  216. Shifting
  217. What a difference gear oil can make?
  218. Shifter return spring
  219. Clutch Effort Question
  220. Rear wheel spin; neutral
  221. high pitch sound
  222. chain drive
  223. Any one use Belray in the trans??
  224. starter problems 75 sporty
  225. how much oil in the primary
  226. changing tranny oil
  227. Replacing Shifter Pawl Assembly advice
  228. 0903 ECM Remap and 07 tranny clatter
  229. m6 or hb125 chain tensioner?
  230. Clutch problem (see if you can figure this one out)
  231. Stripped Primary Torx Screw
  232. Socket size help
  233. Brand new beltdrive set up from 1979 era
  234. new grips... alot of play
  235. primary replacement
  236. redline heavy quieted my 07 roadking 5th gear whine
  237. Dry Primary from Factory
  238. Changing primary belt (older bike)?
  239. engine dress
  240. socket size for clutch hub removal
  241. 2007 clutch cable.
  242. Need VPC advice from my fellow HDFers
  243. Man, I simply can't find nuetral....
  244. Clutch QUestion???!!%%
  245. Adjustment of Clutch Cable
  246. Dry Primary -edited-
  247. Transmission problems ++
  248. Clutch slipping?
  249. Change from a 66 to a 70 tooth pulley
  250. Changing from a 66 tooth to a 70 tooth pulley
