- Derbix primary cover drain plug
- Rear wheel won't engage
- 2003 fxdl tranny
- 5th and 6th gear slipping
- noise
- Clutch Pushrod Welded?
- Jumps out of gear?
- BDL's New Compensator
- revtech gearbox
- ok it maybe my fork shifter
- transmission whines= clay color muck in fluid
- Primary Chain
- 05 Softail factory clutch pressure plate torque specs
- not shifting right
- not shifting
- Need some help
- 1984 Enclosed Drive Chain
- Anybody have reverse shift linkage on their bike?
- Help with engine swap
- compensating sprocket shot
- Tranny problem ??, need some help
- Piston
- clutch pack adjustment: cable became too loose!!
- Warm primary
- *Need Help*: clutch pack adujustment-->cable got too loose
- Can't shift passed third gear
- Clutch friction and pressure plates
- 88 drivetrain Q
- primary chain
- okay..primary oil change and refill?
- Noise in primary
- Loose hose!
- Clutch Line
- 1985 flhtc primary noise
- Are Tranny/Primary bearings the weak link on DYNA's
- SE Comp Sprocket Removal
- clutch cable
- Smaller compensator sprocket.....????
- Belt pulley
- Inner primary bearing race positioning?
- sprocket removal
- Baker DD6 Leak:
- clutch cable problem
- Revtech bolt in 6 speeds?
- Engine noise
- Part number for sporster please
- Help 93 softail clutch cable
- 2008 Softail - comp sprocet thread direction
- Does Neutral exist? Normal?
- clutch
- After fluid change
- Shifter linkage spacer 94 FLH question
- rear wheel fitment issues
- Inner primary bearing question
- gear oil flstc
- '04 Softail Std. Trans Main Bearing install
- tranny growl 77 sporty
- What's that noise.
- 85 Roadster XLS clutch assembly diagram
- Help removing shift shaft seal
- Engine oil in primary!!
- Dry Enclosed to Open Primary
- 6 Speed - Help
- Transmission fill port
- Removel of the inspection cover
- Grinding into first.
- need a clutch cable for Heritage Softail
- 05 ultra clutch
- Clutch Adjustment
- Neutral Switch wire goes?
- Clutch Confusion
- Primary clunking
- primary oil leak
- Primary noise
- oldschool0072
- Terrible Clutch Pull - Hydraulic actuation?
- Oil tank/pump question
- vibration
- What is the gearing for an Italian-made 1972 SX 350 Sprint Enduro
- Transmission won't shift
- Which way does the gasket go?
- Loud primary.......
- Clutch doesn't seem to disengage
- No oil in trans.. started ticking.. pulled cover to find this..
- Squeek or squeel..... from Primary
- shifting hot
- Noise in primary
- 77 iron head
- remove starter
- Help locating trans leak ???
- 1942 Harley 45 rear wheel hub problem
- Putting a "Baker Anti-Overshift Ratchet Pawl" in an Ultima 6 speed.
- primary knock at Idle
- hairline crack in inner primary
- Demon's Cycle Knockoff Part Leaking Oil
- 3rd Gear slipping
- Saxon Tranny
- For All The Tech-Heads - Throw Me A Line
- Clutch Issue-Need Insight
- Trans dipstick allen wrench size?
- dead shifter, wtf?
- Compensator Nut
- Leaking primary question
- FX Shift Pattern
- shifter shaft seal
- Shifter Pawl Spring
- Clutch slips
- yes ANOTHER compensator question
- anyone use DuPont Teflon Multi-Use Silicone spray for clutch cable?
- Knocking in Primary gone now whining.
- Cant get into nuetral!!!
- Burnt Up Clutch... Thinking about tackling it myself... Any Tips
- Burly ape hangers clutch cable problem
- topend noise ?
- Primary Cover
- Squealing noise?
- how do i adjust the clutch?
- Starter woes, please help
- Rear shift lever
- 97 Ultra shift problems
- help! cannot downshift lower than fifth
- 2006 FLHX trans / primary noise - HELP PLS
- shifter stays down
- sound like bad starter clutch?
- Push Rod Accesssiblity
- fitting a 2002 FXDXT clutch to a 1994 Dyna EVO
- 2006 Softail Tranny Speed Sensor Location
- Any Yellow metal inside a 5spd?
- I'm getting mixed info please help!
- Coil spring clip for a clutch basket
- Here's a good clutch problem to have..
- Clutch Ramp Retaining Clip
- Conpensator Nut Removal
- Service experince with Baker Trans
- Open Primary Excessive Belt Deflection
- primary alignment issue
- primary oil, 96 sportster
- Clutch issues
- Inner primary part numbers for '72 FLH
- Transmission Problems - 6 Speed RSD Gear Changes
- Custom shifter peg help please
- Need help
- Sticky neutral
- 99 Sportster transmission leak
- chain alignment
- Whiney Sportster
- oil leak ?
- Derby cover blues-help!!!
- gear ratio question
- 87 Heritage Softail Clutch Problem
- 87 Heritage Softail Clutch Problems
- hard clutch lever after cable replacement
- Clutch cable install
- How to Remove Main Shaft Oil Seal
- Hydraulic Kickstart 5 or 6 spd
- Clicking Noise From Primary
- Primary Noise
- drive belt too tight
- Harsh gear engagement normal operation??
- Help! Clutch Is Not Releasing
- Tranny fluid dripping from primary drain plug. Comming from higher up somewhere???
- Open Belt Drive owners
- Auto primary chain tensioner question
- JIMS 6 speed right side drive hydraulic clutch adjustment
- Hand Shift Conversion 1984 FXST
- 03 super glide clutch lever real stiff
- Engine and transmission swap
- 09 Ultra Clutch maybe?
- 77 flh starter
- ultima belt drives
- Final Drive options for 08 FXD
- Help adjusting clutch
- 63 stock duoglide clutch problem
- Clutch cable replacement
- 2006 RKC bike wont shift
- Clutch/shifter out..??? Help
- Limp Clutch Lever
- Cruise drive 6 speed sprocket tool
- Derby Cover Gasket & VPC Install?
- primary chain adjustment
- Convert to Heel & Toe Shifter on '92 Softail Springer?
- Primary oil
- primary leak
- Locktite on outer primary cover bolts?
- big bore kit
- Installing SE Performance Clutch Kit
- '02 FXDX Drive belt replacement procedure
- Gear Adjustment: I Need Help.
- Clutch pushrod too long.
- Engine Swap
- Five Speed Shifter Rachet Spring
- high rpms when warmed up
- Clutch screeches under load
- Rivet Tech
- 06 Road Glide Tranny Leak
- 06 FB Primary Auto Chain Tensioner
- Synthetics in primary?
- Question - Starter
- DD7 arrived today.
- Had to make my own "Better Lever"
- No 3rd gear???
- Jumping into 1st from neutral
- Heel/toe shifter
- 83 fxr
- Sprocket bolt torque, how much?
- evo primary need some help
- sportster starter
- Sloppy Shifter
- Sloppy Shifter
- 120R + Rivera Primo - Pro Clutch 1056-0020 - slipping
- Knocking noise at compensating sprocket
- 1960 panhead trany
- Gear Whine
- 2000 softail transmission gears
- Baker DD6
- Vibration
- Carb or timing problem
- Clutch oil capacity
- Clutch problem
- Leaking drain bolt
- 3:37 Gearing
- 6spd swap on 04 5spd Tranny
- 2008 Primary belt drives???
- transmission output spline
- 69 Shovel Transmission problem
- Stripped out threads in Transmisson case
- help with Sporty trans
- Clutch Release Cover
- I screwed up royally need help
- Any idea what transmission this is???
- shift points?
- My 2008 FLHX transmission bearing is bad...
- New FatBob ,Hard to find neutral
- real advantages of a hydraulic clutch?
- Drive Belt
- 5 Speed kick
- WEt or Dry Clutch
- Bearing Installation
- Clutch adjustment
- Loose primary chain?
- HELP! inner primary is cracked
- Clutch - broken cable but not engaged.
- Neutral and Clutch
- need a new clutch pack: any suggestions?
- 3.37 Primary Gears & Starter Question
- Dry Trans
- clutch cable won't go in side cover
- 08 Fatboy Drive Line
- 93 Fifth Gear change
