- slight lurch
- Shifter shaft bushings length 77 sporty
- Clutch cable replacement?
- Rattle from primary
- Ball diameter...
- kickstart tranny problems
- 06 Dyna Inner Primary Bearing Failure
- broke 3rd jackshaft
- Transmission problem?
- Primary adjustment question...
- Can tranny fluid leak into clutch??
- EVO Sportster oil line routing
- primary drive
- question about belt tension
- what material is made of the clucht cable road king classic 2004
- (SOLTAIL) Drivebelt rubbing on low guard on 07 Deuce
- Chain noise
- WEIRD
- 3rd to neutral?
- Roller Primary Shoe
- Clutch keeps coming out of adjustment?
- Primary Shoe ?
- compensation nut ?
- Dye in tranny oil
- shift without clutch in
- primary noise 2007 FLHX
- Primary chain adjustment
- clutch adjusted no change
- Newbie Question about EFI/Trans
- Tranny Problem
- Changing timing cover question
- Changing the primary cover question
- derby cover was drippin for 60 miles.
- Removing Clutch inspection cover 08 CVO
- Clutch Issue I think 2007 FLHR
- speedomoter off
- gremlin in tranny
- Primary chain adjuster
- M6 primary chain tensioner
- Trans oil?
- premature clutch cable break????
- Metal Filings, Jumping into Neutral, now Overheating Tranny
- engine light issue
- Shifter spring
- Downshift Problem
- Knocking noise on idle
- Couple o' questions 'bout my clutch
- yikes, when should i shift?
- clutch adjustment
- Transmission? Starter!
- OIL EVERYWHERE / Crank Case breather hose HELP!!
- 07 RG primary adjustment
- 2006 Dyna Bearing Failure
- too much trans fluid????
- tranny interchange help
- vin problems please help!!!
- with the bike on the stand
- Ultima 6 speed tranny neutral switch problems
- Removing oil pan on TC motor
- rotational noise after riding about 100 miles..
- Upgraded to SE 6-speed: not a happy camper!
- 5 psd suicide clutch question
- Specs on transmission input shaft
- Direct Drive Primary vs. Compensator system
- Bold jackshaft size for compu-fire
- Slipping Clutch
- 08 6 speed clutch cable removal
- 1979 hd sportster 2nd gear
- hot primary
- Belt Replacement (secondary)
- belt rides towards inner primary
- Lost 2nd gear
- shifter arm/ shaft clanking
- Primary Leak?
- Change Drive belt???
- Rocker C not shifting 3 - 6
- Primary Chain Tensioner
- Clutch Kit
- WHAT WEIGHT IS HARLEY GEAR OIL ??
- Grinding? noise when coming to a stop...
- Clutch lever travel/clutch engagement point
- Need drive belt advice.
- open belt drive for 93 fxr
- Belt Chirp Problem
- recomendations for Mid Controls on a 07 softail
- Sportster Clutch Hub / Shell Slop
- Trouble getting into 3rd gear (sometimes)
- 1st and 5th Gear whining, loud! Normal?
- Over run clutch inside the starter
- 2007 softail working great
- STARTER: Is this correct?
- Change it or leave it alone?
- primary inner bearings
- Derby cover won't come off
- RE: TWIN CAM SECONDARY CHAINS
- Rear Sproket
- Transmission and Primary Oil Change
- Bike still rolls w/clutch engaged
- Help, Linkage replacement
- clutch will not disengage
- correct clutch shifting techniques
- Leak is back!!
- what is the pressure plate torque?
- Royal Purple/Hard shifting
- belt tensioner
- small clunk when releasing the clutch
- &\\;rsquo\\;06 Sportster 883R/1200 w/slipping clutch
- 32 tooth trans sprocket to 30?
- Confusion about Oil/Trans drain plugs... Owner's Manual goodness!!
- I need a sportster clutch guru...
- tranny hits nuetral between gears
- clutch cable
- HD SE 21 tooth compensator gear
- Fluid Leak between Inner Primary and Transmission
- EVO Ind. 30 tooth Sprocket-Update
- need help keep cracking inner primary ,how do align properly
- Clunky
- Dyna Glide down shifting problem
- Changing Primary cover
- Softail won't move when in gear...
- Trying to learn..
- Softail Hig pitched chirp
- chatter/vibration
- Vibration
- Clutch Cable Ajustment - Adjuster Will Not Turn
- chrome inner primary installation...
- PRIMARY GEARING FOR 07 FXSTC?
- shift levers just go up and down now
- shifter NOISE
- 2006 Heritage shifting problems
- Help changing Primary Oil (HELP Please)
- LUBE
- '85 Softail - 4 speed trans Problems
- Clutch pull in '08 Sportsters
- 1K service now clutch feels out of adjustment
- noise??
- How do I check/fill primary?
- Follow up on Reduce Effort Clutch
- 05 RK clutch cam and balls
- primary blues
- Cracking sound
- Gearing Question
- Gearing Question
- Secondary Belt SNAPPED
- Derby Cover O-ring
- Clanking sound when clutch released
- Clutch cable install issues
- Lost my clutch
- what kind brand you would recommend for 6 speed transmission?
- Hydraulic Clutch Problem
- transmission sprocket
- need help with diagnosis, all teeth sheared of final drive belt, grinding noise coming from primary
- ok you shop manual guys
- Compensating Sprocket
- Clutch Lever sticking
- M6 on a 04 sporty HELP!!
- Clutch Pack Locknut Tool
- Compensating Sprocket Removal
- burnt trans oil
- Noise From Primary
- Primary leaking through shifter shaft
- tranny drive sprocket removal
- Please help clutch basket play...normal?
- stupid with oil drain plug
- Might have stripped the tranny plug????
- Primary Oil Question
- Help! 2nd gear shift problems
- Primary chain vs starter
- New SIX SPEED tranny for less than $600?
- Rekluse Clutch
- Changing transmission oil in 2005 sportster
- Clutch cable housing.
- "Blue" colored Tranny Fluid ?
- 06 Road King Clutch Adjustment Question
- Clutch Question
- drive belt
- 95 Fatboy clutch cable cost ?
- Need help with clutch
- Suicide Shift
- Tranny acting weird....
- Sportster "skipping" in first gear
- Redline Primary Oil is the ticket
- 1975 Electraglide
- MY BIKE WON'T START!!!!
- Noise in Primary diagnosed
- Plastic rear sprocket
- Normal wear for a rear sprocket?
- 32 tooth Compensator Sprocket
- 97 XL Pimary Chain Adjustment
- 06 Dyna inner primary bearing part #'s
- 08 ULTRA:GEARING CHANGE FROM 2.79 TO 3.15
- Compu Fire 10/84 Starter Gear Set Broke Today
- Clutch Adjustment Help
- Barrnet clutch spring 06 dyna
- Sprocket size (81 FXEF)
- Oil Drain Plug
- shifting hard
- 5 gears vs 6
- removing primary, tran, cam covers??
- Clutch won't disengage
- Primary drain location and fill??
- Clutch dragging help???
- SE 6 speed noises
- Clutch or tranny question
- Allen wrench size for Transmission fill port?
- late 84 fxst/first year ot the evo
- Transmission won't engage
- oil leak out of the primary case
- Clutch wear?
- Primary case pressure??
- Primary oil quantity?
- engine oil in primary case blues
- B&M Trick Shift for the Primary
- Primary Chain Length and Shortening
- EZboy or other clutch deal for 95 Fatboy
- HELP! bent mainshaft
- primary whine
- open belt
- Qiuck Question
- Primary converson
- Transmission leak
- CLUTCH PACK WEAR
- Buzzing Sound on Deceleration
- Clutch plate replacement
- starter issue
- Clear primary cover?
- trans acting up
- Primary Clatter?
- Bike making strange noise
- Baker High Torque Inner Primary Bearing Question
- HELP PLEASE - weird noise
- Drive belt replacement...
- ULTIMA 6 sp trans problems
- primary case lube
- seals on a 5 speed mainshaft
- Baker Drivetrain
- Primary Drain plug
- Bravo Zulu to Jim's
- AMSOIL SEVERE GEAR 190
- REDUCED EFFORT CLUTCH QUESTION
- Small clip stuck to my tranny drain plug magnet
- Stupid Primary... (and rider)...
- synthetic oil in 5sp during partial break-in?
- 45K AND TIME FOR A NEW CLUTCH
- Primary oil
- Primary Inspection Cover
- Clutch hub nut
- Primary Noise
- Tranny oil change
- 1997 sportster making a strange noise
