PDA
View Full Version : Primary/Transmission/Driveline/Clutch
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 [35] 36 37 38
  1. OPEN PRIMARY ON PAN
  2. clutch adjustment?......
  3. HELP I broke the clutch adjuster
  4. Milwaukee Twins?
  5. grinds going into gear
  6. Downshifting Problems??
  7. 25 to 24 tooth sprocket problem
  8. Noobie question about fluids!
  9. My 07 tranny failed
  10. SE spring / Barnett conversion plate
  11. Clutch Going, Going Gone?
  12. Starter problems
  13. 60 mph squeak while cracking throttle
  14. lotta whining from my primary.
  15. Had it at the harley shop this winterClatter question
  16. Shifter Shaft Seal - Need Help
  17. '04 FXST--Proper method to adjust primary chain
  18. What's the maximum HP a Sporty can apply against Belt Drive?
  19. Primary
  20. strip tranny drain plug threads
  21. Retaining Ring Position ?????
  22. Carbon Fiber/Kevlar
  23. Tranny wine/XL1200C
  24. Service Manuel Part Number
  25. Any suggestions on inner primary work?
  26. Neutral Problem
  27. Lub. replacement-owners man. vs. ser. man.
  28. the real truth fluid amounts on 2006 bob ?????
  29. CLUTCH ISSUES!! PLEASE HELP
  30. Secondary drive belt question
  31. Reduce effort clutch
  32. Neutal saftey switch problem on 6spd conversion
  33. High Torque Clutch upgrade?
  34. Primary Leak Warranty 3rd time fix
  35. 1980 FLT clutch grabs when cold, HELP
  36. Scuffing Clutches ??
  37. HOW OFTEN TO CHANGE PRIMARY OIL
  38. Starter Ring Gear is tore all up! Starter hangs! Help!
  39. stripped threads!
  40. Anyone have experience with J&P Kickstart Kits with modern Harleys?
  41. hot clutch
  42. silicone on primary cover?
  43. why do i eat solenoids
  44. Repeat Compensating sprocket nut loosing
  45. Did I strip tranny cover threads?
  46. secondary chain vs. belt
  47. upgrading the stock clutch
  48. Loctite
  49. 97 Evo Transmission Lube
  50. LOWER RPM
  51. Inner primary Question
  52. 2007 FLHX transmission noise fix for $24.95
  53. Primary Leaking
  54. gearing question
  55. '04 FXST primary inspection cover seeping
  56. rear sprocket?????????
  57. Heat in Primary
  58. Touring Pulley/Spocket
  59. 2007 FLHTC compensating sprocket retrofit
  60. Tranny Plug Photo
  61. HD Formula + in Tranny
  62. Advice wanted. Order in which 1989 sporty clutch is reassembled?
  63. torque
  64. gray substance on speed sensor
  65. Shifting and Starting problems
  66. Metal Shavings?
  67. bent input shaft ????
  68. jockey shifter / suicide clutch conversion
  69. BDL Help!!!
  70. Leaking Grayish Fluid
  71. engine compensating sprocket
  72. Just a cautionary note regarding Diamondback clutch cables
  73. Clutch Lever Freeplay?
  74. GEAR CHANGE CLUNK
  75. Advise wanted for 1989 1200 spty clutch
  76. CLUTCH ADJUSTMENT NEED HELP!!!!!
  77. Are 07 trannys shifting smoother?
  78. Bad Bad Clutch problem
  79. speedo ratio?
  80. Hydraulic Clutch Kit for 2007 Touring Models
  81. Open primary question
  82. 4 speed shift pattern
  83. Shifting from 2nd to neutral >>
  84. clutch no go !
  85. kicker on EFI
  86. Zippers trans upgrade
  87. Difficulties changing from first to neutral
  88. trans oil level
  89. School me.
  90. Rivera Pro Clutch
  91. BDL Belt Drive Install Problem
  92. tranny oil check
  93. engine sprocket torque
  94. Clutch Cable
  95. SE clutch diaphram spring
  96. pulled drain plug got chunks
  97. Found two broken teeth in Primary
  98. Broke my Primary chain on Saturday!!!
  99. Who has the best Baker tranny prices??
  100. Screamin' Eagle 6-speed Dyna tranny install
  101. RPM/MPH for 6-speed on a 07 heritage
  102. 2 questions on FXDI rar pulley, please
  103. 5th gear seal leak
  104. Clutch hub issue on my 52 Pan
  105. "CLONK" on gear change
  106. clutch
  107. Inner primary replacement
  108. 1992 sportster transmission in 113 cu xl - how will the gears hold up
  109. 07 6 speed oil
  110. Shift shaft seal?
  111. Difference between 6 speeds?
  112. '96 Softail Transmission Seal
  113. Primary Oil Change 06 FXDLI
  114. HOW LONG
  115. Effect of 1/2 to 1 turn on clutch adjustment?
  116. Gearing options for an 07
  117. OPINIONS ON THE S-E 6 SPEED
  118. Custom cluch cover?
  119. Size of snap clip on clutch lever pivot pin?
  120. Shift lever isn't engaging (intermittent)
  121. Clutch slipping after engine upgrade
  122. 07 shift points
  123. Primary Oil leak?
  124. And Another whirling whining Noise!
  125. Twin Cam upgrade compatibility question
  126. Lifters?
  127. Dealer Tech forgot Trans oil 1K svc !
  128. 2007 Clutch Noise
  129. Dyna Mid Shift linkage routing
  130. wide tire kit - offset tranny or not offset
  131. Burnt Smell in the Primary
  132. Whiring Noise from Primary/Transmission
  133. Clutch Removal
  134. Clutch Terminology?
  135. PRIMO Belt Drive
  136. Reduced Effort Clutch Kit
  137. sprocket bearing
  138. another whining question?
  139. 06 - Dyna Rear Axle Bolt Size
  140. HD Hydraulic Clutch Kit for '05 FLHTCUI
  141. Aftermarket Ring and Pinion Gear Set
  142. Primary oil level check
  143. N
  144. Clutch Drag
  145. New slippery Clutch Cable?
  146. Primary Seal and Bearing replacement 2007 6 speed
  147. drive sprockets
  148. foaming tranny oil
  149. Easiest way to disconnect clutch cable?
  150. primary for a 06 sportster
  151. BDL open primary 06 softail
  152. Frequency of changing tranny fluid...
  153. What's It Sound/Feel Like?
  154. 07 chatter
  155. Transmission Vent Line -- Where to Route It?
  156. BDL lockup clutch
  157. 01
  158. Clunking noise
  159. 07 Gear swap 2.79 to 3.31?
  160. whiring sound coming from crankcase??
  161. starting problems "please help"
  162. Six Speed Special Deal
  163. Clutch Inspection cover
  164. Belt broken
  165. BDL Belt and Pulley Install Help Needed
  166. 2003 xlh 1200
  167. Fix the 2007 Tranny Problem
  168. clutch slippage?? HELP!!!
  169. 78 primary housing removal
  170. 4-spd tranny kicker addition
  171. Pennsylvania clatter
  172. FLASH! BAKER RELEASES 5TH GEAR FIX!
  173. Oil leaking from tranny vent hose...
  174. Another 07 sale
  175. Clatter
  176. 2002 Road King firefighter edition...FREAKY NOISE!
  177. Can of Marbles - Found!
  178. "Breaking of the Stick"
  179. '06 Dyna Belt to Chain swap...
  180. engine break clicking
  181. tranny noise
  182. Transmission End Cover
  183. 3.37 gearing for 01 FLSTF
  184. 5 speed to 6 speed HELP!
  185. 71 Sporty - problem shifting
  186. belt length
  187. Installing Inner Primary
  188. Six speed inner primary oil feed -how?
  189. 4 speed main drive gear end play
  190. Tool to Measure Chain Deflection?
  191. water in tranny?
  192. Transmission drail plug seized!
  193. Broke Bleeder Screw Hydraulic Clutch
  194. Changing the Primary Drive Belt
  195. Ultima open primary?
  196. Groove in rear belt
  197. Mobile 1 MX4T for Primary?
  198. Drive line noise/trans noise.
  199. what would you do?
  200. Went to adjust my clutch yesterday and...
  201. Clutch Adjustment Socket
  202. iate it.Starter clutch
  203. Redline Shock Proof Heavy
  204. Clicking noise from primary?
  205. See through inspection cover??
  206. Primary Oil Change Question ???
  207. Ran My Primary Dry !
  208. Evo 5 speed
  209. 2006 Sporty clutch cable replacement-adjustment
  210. Clutch Cable fitment: What fits what ?
  211. Primary Change
  212. average joe
  213. primary cover removal
  214. 2006 classic tranny noise
  215. trans top
  216. 99 RK Stator problem
  217. EVO MOTOR CLUTCH CABLE CHANGE
  218. Put Your 07 Ultra Problem Fixes Here
  219. Tranny leak- Porous case???
  220. Tranny leak- Porous case???
  221. clutch cable adjustment vs. the clunk
  222. Tranny parts/drawing available?
  223. Main shaft leak again
  224. Preventative shifter pawl spring replacement
  225. help....im ridin the titanic here
  226. new clatter
  227. I Do Not Feel Like I Belong Here
  228. open primary
  229. 2007 Transmission: Part 2
  230. Tranny oil question
  231. 69 xlh sportster stuck in 2nd gear
  232. Starter clutch went out AGAIN!
  233. Transmission Plug
  234. Another shift help question
  235. Transmission drain plug
  236. Clutch Adjustment Locknut
  237. Clutch Cables
  238. '95 FXD laydown....DOH!
  239. clutch problem
  240. help me understand the clutch adjustment
  241. Clutch Lever Pin Clip
  242. Ticking noise from primary side
  243. Shifting problems need help
  244. 2006 4th gear whine????????
  245. Primary
  246. "rattle" coming from clutch inspection plate area
  247. Play in final drive
  248. screaming eagle six speed
  249. Noise under ultra
  250. outer primary removal help needed!!
