- IDS - some post-install questions
- 1990 FLHTC with "Clunking" noise when moving
- Want more top end speed for Softail
- Two rides and its broke AGAIN!!
- Hey everyone. I'm screwed. Please help.
- I believe this is where i should post.?.
- clutch problem...
- six speed trans
- chirping noise
- general question about twin cam failure
- Retaining Ring Position
- Automatic Tensioner Question
- whirl sound at primary till warm
- H.D. Reduced Effert Clutch Kit
- Ready for my next bike, but have a few questions?
- 1980 FXWG Transmission vent screw??
- Transmission Tools
- Gear whine NOT an '07
- primary fluid getting into trans case
- Compensator
- Stater and jackshaft problems please help.
- RK won't roll forward only backwards..PROBLEM SOLVED.
- Primary Bearing problem ?
- 1990 HD FXRS 5 Speed Tranny
- Oil leak from primary or tranny? Help!
- Primary -- Can you get away with 1 quart?
- Primary gear ratio
- Belt Squeak - or Engine Ping
- Stripped primary Torx-T30 got it out
- IDS installed -- A little disappointed
- IDS installed - back to Formula+ ???
- Need Help...I'm Going Crazy!!!
- How much is too much
- Warning Motion Pro Clutch Cable
- Driveline ratio change
- What's an easy way to measure the primary chain tension?
- deleted
- Stater 1996 FXSTC
- Little Help Please
- Adjusting Clutch
- Removing shifter pawl/splined shifter shaft from 99 Road King tranny
- 2004 Road King Police Interceptor?
- 2006 ultra whirl noise
- Race Clutch kit
- Clacking between 2800-3100 rpm
- Clunking when I let out clutch
- Stock primary final chain drive?
- IDS Pictures - *Dial-up warning*
- I thought I broke something inside the tranny!
- Finding the tightest spot
- Tranny questions
- 4spd shifting problem
- IDS for 2003 FLHRCI
- Heres a (stupid) question
- ADVICE: Odd engine squeak started tonight...
- Shifter Forks 96 1200
- Question on clutch adj.
- clutch slipping
- rear sprocket
- Easy Pull Clutch Kit - Installation??
- Trans Leak
- reduced tooth front belt pulley
- Baker F6F Kit?
- Experience w/ Primary Adjustment
- Primary chain
- syn3
- PINGING, ENGINE KNOCK
- Gasket Part# ?
- another IDS question
- IDS question
- Noisy drive belt '06 FLHRI POSE
- Transmission upgrade?
- Help - Want to Replace Throttle/Idle Cable
- Primary main shaft seal 05 RKC
- '07 Primary "Chatter"with "auto" chain adjuster
- Looking For Overall Diagram Of Drive Train
- IDS Warranty Coverage?('07 Ultra Clatter)
- Small washer found in primary oil
- 6th gear tick
- shift pattern is back wards what's wrong
- Yet another Primary chain Question
- 07 Clutch Cable Routing
- 00-05 dyna rear pulley to a 07 night train?
- Open primary and final chain for an '07
- Interesting Leak
- Shifter return spring problem
- Water in Primary Fluid?
- Open primary
- 4spd-3rd gear whine
- Slipper Clutch question
- ids driveline part 189.56
- Hot weather and noise
- Clutch Clearance
- Primary Chain Adjustment?
- Shifting noise?
- EFI conversion
- FNG screwed up my first HD!!!
- Please HELP!!!
- Bike running strange
- Trannyproblem six-speed ?
- grinding clanking knocking sound
- IDS simple question
- 06 FLHRI 3rd mount ...
- Red Line in primary -- OOPS!
- IDS Installed!
- strange starting prob
- useing drive train for slowing any harm
- reverse on a dyna
- Gasket?
- Primary Chaincase drain plug
- belt drive q?
- Final drive ratio
- Primary Chain tension specs
- Overfilled Primary?
- another clutch adjustment question
- Any TC Rev Tech 6 speeds installed?
- 07 classic (clutch adjusted several times)
- Longer heel shift lever
- Hot Idle Noise
- Clutch Hub
- 2003 883 primary noise in neutral
- 07 and 08's
- Oil capacity in 07 Electra Glide 6 speed?
- dry, primary beltbelt primary replacment
- ids drive
- Change in design of H-D auto tensioner?
- Open belt primary for FLHR?
- bike feels squirrelly turning
- tranny problem
- primary
- Clutch loose/leak?
- Rev Tech 5 into 4 with kicker
- Help with Clutch Adjustment
- HELP!!`
- revtech 6 speed
- loose shifter & hard finding neutral
- '00 EG Classic tranny/shifting problem
- Hot or cold ?
- Clutch Adjustment Question
- squeeking noise
- Primary Drain Plug
- 4 Speed transmission
- REAR DRIVE BELT & SPROCKET ?
- How to,,, Scorpion clutch install? How hard???
- new clutch cable install prob.
- clatter when downshifting from 2nd
- stripped transmission drain plug
- 2008 Tranny Problem!!!
- Outer primmary
- Budgies in my motor?
- Adding kick start question
- Need some guidance with a stripped or missing bolt
- 1979 XLS Sportster tranny issues
- Need HELP A.S.A.P
- engine/tranny weep>seep>now leak
- Primary chain inspection cover leaking
- Starter replacement - quick help needed!
- 79 sportster tranny
- CONFUSED PLEASE HELP
- 2007 6-Speed Trans Saga Ending?
- Ironworks Baker F6F Install
- MOVED: "New, Improved" SE slip-ons
- 2007 Tranny Problem Diagnosed
- clutch change tutorial
- tips requested (gasket change)
- tranny side door and gear removal problem
- tight drive belt
- Identifying parts
- revtech 6 speed, installed, fist thoughts
- Squeeky primary
- ??(how to)remove/install chrome tranny cover on 86 FLHT??
- striped drain plug
- Primary Leak...
- Transmission Side Cover
- tranny side door gasket help
- Dropping into gear
- Chugging sound from tranny
- EMAIL JAY LENO, PETER FONDA AND ROBBY KENIEVEL!
- What is the time line to switch to Syn
- Evo hard shifting into high gear
- clutch adjustment/problems getting into nuetral
- redline
- Redline is the answer to the Whine
- 1 1/8 Drive Belt Help
- oil pressure ????
- oil leak on 07 fatboy?
- Big Bore Kit information ?
- problems after 10000mi Service
- trans leak
- Aftermarket speddometer calibration
- Warranty help / question.....
- "07 Ultra Primary oil is full of metal.
- Anyone Help??????????????????????????
- trans explained
- How do you break the Shoe??????????
- New 2008 Ultra's have IDS for drive line noise!
- Leak somewhere!!!! not sure
- Tranny Case Seal
- 1450 six speed?
- 82 sporty- loose drive chain
- Primary capacity --'05 Fatboy
- Primary 70-84 fl
- HELP!
- Cheap Man's Over Drive Transmission
- Electric speedo
- DRIVE BELT
- Transmission removal
- wierd 2-3rd shifting
- Has anyone used this 30t sprocket?
- Neutral light stays on in 5th gear
- Clutch problems
- shifting...book vs. real world
- How much trouble to change belt?
- 2006 Deuce Tranny Problem
- No Tension on Cable After New Discs Installed
- Adjusting Primary Chain? Help Please
- odd shifting question
- spins on start
- Lower 1st Gear
- Primary chain tension problem
- Knocking/rattle sound coming from somewhere....help please
- tranny ticking
- help with primary leak
- Shoockproof seeping out of trans case
- 2005 883 Primary Cover Replacement - Help!
- shifting problem
- mainshaft locknut wrench
- installing BDL open primary (any tools required)
- 07 GEARING POSSIBLE FIX?
- 2002 Sportster Primary Question?
- se 6 speed trans sprocket
- Reverse
- starter clutch
- Open Primary on a softail
- Hydraulic clutch installation instructions ?
- Recommendation for Cable Lube
- adjusting shoe- 1995 fxstc
- Baker swapout for HD 6 speed?
- Hydraulic clutch problems
- Clutch help
- Did I ruin my tranny?
- synthetic gear oil to reduce noise in new bike
- 1981-80"shovel FLT
- advice on lubes
- Great Primary Chain Tension Gauge
- Did you see American Iron Mag trans whine Article?
- Clutch Cable Leaking.
- Odd problem
