- Should I or shouldn't I???
- 03 night train slapping sound fron the left
- Any help ? On Speedo ?
- Ratling between second and third gear...
- changing gearing
- Speedo stops working
- Tranny drain plug washer
- Shifter Spring assy 2003 Fatboy "HELP"
- Missing Identity of Harley 4 spd...Can you help it remember?
- 97 Wide Glide Starter Problems
- Could it be the clutch?
- Back Wheel Wine Noise
- Trouble shifting in to higher gears.
- Transmission whining
- Shifters loose?
- What Happened To First Gear?
- 5 speed in a 4 speed case?
- 2007 primary chain adjuster
- '90 FXSTS Trans Detent Spring Broke
- Reduced effort clutch kit
- Hydrolic Clutch
- Dealer forgot to refill transmission oil.
- 5th gear whine.....
- Shift linkage loose from tranny?
- Redline shockproof - finding a leak
- Chain adjust
- chain and sprockets needed
- Trouble shifting to third
- Quad seal failure, HELP!
- back lash on my 2005 ElectraGlide?
- can hd primary oil 9987-84 be used in 06
- Compensetor Nut
- belt and wheel rubing...???
- couple a questions about primary and clutch
- Sportster Tranny Fluid
- Clutch removal help.
- Tranny locking in 4th
- Brief rattle when letting clutch out
- dropped tip of bottle in tranny
- Help needed removing front belt pulley nut.
- Baker Hi Torque or S and S?
- shifter fork? bike stuck in first......need help
- Belt particals stick to exhaust question
- Mueller Power Clutch
- Clutch Question
- Shifter Return Spring, 5 speed.
- '72 sportster shifting problem
- HELP starter won't engage and grinding noise in primary
- clutch spring question
- HELP! no fourth gear
- Need Transmission Help
- Sticky Shifter, Yes I Searched
- Advice on a Baker DD6 Leak
- drive belt
- Gearing on an '04 XL883C compared to XL1200C
- Andrews 30T Sprocket.
- Primary Belt Drive...Inch and a Half.?
- electra glide model motorcycle Inner primary seal failure
- klunk
- new clutch cable
- 2007 High Milage 6th gear Problem?
- Gearing help please
- Shifter willn't move back
- no neutral
- Need help (deinstallation clutch softail)
- clutch cable release HELP!!!
- '79 Shovel Troubles
- Clutch Question
- clutch question
- Open Primary
- 07 sportster oil leak where clutch cable meets primary cover
- Clutch adjustment ?
- How to tell year/model of 4-spd tranny?
- how do you tell year/style of tranny?
- Trans / Primary Fluids Mix
- main drive gear removal
- how to check gearbox oil level
- Clutch spring question
- Primary drive chain & bearing cost recovery
- clutch problem
- clutch problem
- Belts?
- Ultima 3.35 Compadability
- 06 dyna clutch
- Shovelhead Outer Primary Questions
- Clutch Relief
- belt drive problem
- 1st gear slipping
- Primary cover differences.
- 6 speed gearset install on 05 RK
- 78 shovel transmission oil seal leak
- fxr clutch hub removal question
- Mainshaft Oil seal still leaking?
- Transmission or Clutch
- half shovel half evo gotta change clutch basket help!!!
- Starting Issues After Ultima Belt Drive Installed
- Belt drive to chain drive???
- 68T Sportster rear spocket fit 07 Ultra?
- tranny leak
- tranny leak
- Drive sprocket change out 883 to 1200 Sportster
- Changing rear pulley on '97 Heritage from 65T to 70T???
- Dropped nut in Tranny--HELP!!
- Will It Fit
- highway gears
- 07 Night Train tranny/primary help needed
- 01 Deuce Oil Change....sigh
- Replacing tranny fluid on an 07 Night Train
- what happened to my post?
- 1989 Sportster ate the alternator rotor
- Slipping on hard launch.
- what will happen if theres to much tranny fluid in trans?
- Clutch question...bike won't move.
- Anybody swapped to a Revtech 6 speed?
- Shifting between 3rd and 4th
- Broke Jackshaft Bolt**Help
- Baker Trans Trouble
- '89 FXR clutch
- Tranny and Primary oil
- Klank Klank Klank goes the sportster
- belt drive system for 68 Sportster
- Clutch problem?
- 70 tooth rear pulley.
- Eating starter clutches
- 73 FX superglide
- 09 SG Trani whine?
- Serious Tranny Leak & Hose To Nowhere
- hayden m6 chain tenisoner
- hayden m6
- 96" service primary oil amount
- 06 softail - Hard to roll in Gear with clutch pulled in
- can't get 1st
- replacing outer primary cover
- Rebuilding a 4 spd transmission (+++PICS)
- Outer primary aluminum or chrome?
- Shift arm ?
- rocker clutch with an open primary
- Clutch replacement question
- more torque with a primary belt?
- Primary Overflow Leak
- OIL seal cork washer
- 07 6speed has trouble changing down gears
- Panhead compensating sprocket plug part number?
- clutch
- clutch install trouble
- Brand new FXDF sounds like a tornado....
- New Clutch Cable Issues
- over filling Primary ?
- inner primary ?S please help
- I have a question about shifters???????
- Clutch cover gasket or seal?
- Clutch pack adjustment .... something I'm missing?
- 1979 Ironhead Sportster First Gear
- Six speed cable
- Question about changing primary fluid...
- red line tranmission oil
- is there a spring in the outer primary
- clutch cable ?
- Milky Looking Tranny Fluid
- No more chain oil...
- heel relief stirrups + fixed mount pegs
- Rebuilding 68 FLH..primary/clutch suggestions
- forward controls on A 2009 SUPER GLIDE CUSTOM
- Remove clutch lever
- New Clutch Install
- Wheel Alignment Questions Eletra Glide.
- Frozen Clutch hub removal
- rear chain
- Which Setup
- 5 speed in a 4 speed FXST?
- 83 sporster case repair
- pulley change
- Balance Masters or Fisher Concepts
- New clutch cable issue
- belt drive squeak.........Help!
- Ultima six speed question
- 96 Evo scraping sound from primary
- 91 Electra Glide Vibration Problem
- Pitting in rear pully
- 2001 Fatboy 22,000 miles
- Pushrod adjustment screw
- inner primary removal
- Do the drive belts get tighter after ridding for a short time?
- Does this look normal
- 02 sportster shifting problems
- Transmission sprocket
- 84 fxst primary level
- belt's length calculating
- Transmission Oil Leak FLHTC
- Baker 30T aluminum trans sprocket?
- Gearing change, what method?
- Compensator Spring Pack
- clutch adj.
- I want lower RPM's...any ideas?
- Looking for help installing baker 6 speed in 4 speed shovelhead frame
- Help
- Inner Primary replacement
- Primary Leak
- No inspection plate on pimary cover
- primary worn
- manual to hydraulic clutch- 4speed
- primary gasket
- chain drive open primary
- 07 ultra
- Question about installing open primary belt drive??
- How much oil in the primary case?
- Replacement Fluids?
- Cutting a drive belt to make it thinner
- '82 FXR, is my clutch wet or dry
- Ring Gear replacement tools and tips
- 31Tooth front pulley,does one exist?
- Clutch basket question
- 4-speed /Evo swap
- Which Primary to use
- 66T pulley on an'07
- How many steel & friction plates do I need?
- Inner primary housing
- 7 speed at Javitz Center!!!
- SE Race Clutch
- Clearance between Main drive pulley and Tranny
- Forward controls
- Belt to tight or not to tight?
- How many steel / friction plates?
- Anyone using a 34 tooth drive pulley
- baker dd6
- Shift Linkage for FlHRCI
- SE compensator???
- how much oil goes in tranny?
- Primary gearing
- Stop leak
- 4 speed blues
- Tranny swap
- Clutch cable rubbing crash bar
- Want to get rid of the chain
- Pulley spacer for wider tire and new pulley
- loud wine
- Stumped! clutch problem. need help!
- kick starter on 68 xlch
- Bike feels like it's revving high at cruising speed
- Question about SE clutch spring
- outer primary bolts
- Clutch life
- Inner Primary seal leak
- Clutch disassembly
- What kind of belt?
- Transmission Leakage
- Clutch Assembly Removal
- help on RevTech/ Custom Chrome 5 speed problem
- Excessive viabration!
