PDA
View Full Version : Primary/Transmission/Driveline/Clutch
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 [24] 25 26 27 28 29 30 31 32 33 34 35 36
  1. Primary chain help
  2. need help with locking engine sprocket
  3. need help with my jockey shift install
  4. 83 FXRS Clutch Issues?
  5. Thickness of new friction plates
  6. Switched back to Syn-3 after ATF in Primary!
  7. Rivera Pro Clutch
  8. Changing primary oil
  9. High speed shift prob
  10. Shifting Problem-whats wrong?
  11. Sheared Diaphragm Spring Retainer Bolt
  12. primary chain drive set up
  13. Ultima six speed
  14. oil level in FLSTCI
  15. trans. primary fitment
  16. Neutral Switch Connector
  17. 6- speed R.S.D Ultima Tranny leak
  18. 96" need primary adjusted?
  19. Primary problems breaking rotors
  20. I think my clutch is dying need input
  21. Squealing Noise from Compensating Sprocket
  22. Loose bolts causing leak
  23. Inner Primary Leak Help Needed
  24. magnum shield clutch cable question
  25. Clutch is stuck
  26. 6 speed question
  27. Need help with starter jackshaft bushing
  28. 6 speed conversion
  29. Clutch shell
  30. need very easy clutch!
  31. What size nut on clutch basket
  32. compensation direction
  33. Need help with 05 Road Glide drive belt!!!
  34. clutch cable is leaking
  35. Clutch Problems
  36. clutch cable r&r can someone help me
  37. Question: Mainshaft bearing race removal.
  38. starter problem
  39. clutch not fully engaugeing
  40. Primary Drain Plug??
  41. 4 speed transmission serial numbers
  42. When to upgrade the clutch ?
  43. Clutch Adjustment - 90 Softail
  44. engine idle
  45. Aftermarket clutch pack for 2007
  46. Cam Chain Tensioners
  47. primary bearing question
  48. Watched OCC show today. No rear brakes, hardtail with rear shock? Double belt transmi
  49. How long does it take to replace 5 speed shafts to 6-speed?
  50. softail transmission
  51. Are metal shavings normal?
  52. What trans is this
  53. Shift linkage 04 electra glide need parts data
  54. clicking noise when rolling
  55. What Kind of Tool?
  56. Pan transmission identification and more...
  57. How to remove shift pawl pin?
  58. Please tell me I just need to remove top tr. cover to replace shift pawl.
  59. Clutch Adjustment Question
  60. 4 Speed Transmission
  61. Transmission whine
  62. Aftermarket Primary Chain Adjuster 07 & up
  63. wouldn't start
  64. Doesn't downshift every other time.
  65. back cylender isnt getting spark
  66. Primary oil capacity
  67. '04 & up XL DIY stator replacement
  68. Clanging noise
  69. 2008 SE Ultra Classic - Tappet Failure
  70. replace clutch
  71. 08 Touring primary tools needed
  72. clutch adjustment
  73. Oil stain
  74. Cometic Seals
  75. A good replacement clutch kit
  76. 2006 Street Glide Engine or chain area noise
  77. drive belt at 20K
  78. Primary Install Advice
  79. Getting into first on my 5 speed
  80. Shift Shaft Seal.
  81. 06 Street Glide grinds when downshifting to 1st
  82. Trouble downshifting @ a stop
  83. What other seals to replace
  84. Newbie Primary Advice
  85. Clutch disengagement
  86. Stock clutch life?
  87. TC88/5sp Tranny Fluid Change
  88. help i'm confused
  89. transmission main drive gear bearing failure
  90. Clutch won't work
  91. Some trouble downshifting. Please help.
  92. Clutch Adjustment
  93. chain conversion for 09 RG
  94. chain conversion for 09 Road Glide
  95. need help with primary leak
  96. Weird Noise Help
  97. Clutch Removing/Installation
  98. Replacing drive belt
  99. Primary Noise
  100. Is it the transmission?
  101. on/off grinding Noise in front primary
  102. Draining Tranny fluid on softail ?
  103. Andrews 30 tooth Tranny Sprocket Belt Replacement
  104. Energy One Clutches
  105. Chaincase cover (derby cover) gasket
  106. Help with tranny oil level.
  107. 01 electra glide c
  108. 07 rk tranny issues
  109. Can't find neutral?
  110. Belt tensioner. Question.
  111. Has anyone broken a 6 Speed??
  112. Trans Vent leak
  113. Tranny fluid leaking down clutch cable
  114. Clutch cable
  115. Medium speed noise when I release the throttle or activate the clutch
  116. Show me your foot clutch
  117. 49 Tooth Evolution Industries Clutch Sprocket
  118. Broken drive belt
  119. 5th gear noise in 2009 FLSTC 6 speed tranny
  120. Police Bike Gearing
  121. 2000 Dyna - drive belt broke
  122. Flywheel & Compensator Shims for Primary Alignment
  123. Trans. fluid for 2010 FLHTK
  124. belt drive
  125. Shift Lever Shaft Bushings?
  126. Transmission main shaft nut tool
  127. chain cutiing into cover
  128. Baker F6F 5th gear
  129. noisey tranny or chain 03 FLSTFI
  130. Tranny identification
  131. Clutch area noise HELP
  132. Newbie needs some help here...
  133. Wedge Tensioner Has Arrived
  134. 2004 road king custom shifter
  135. 95 xl 883 won't shift when warm
  136. Carbon vs Kevlar
  137. Baker High Torque Primary Bearing.
  138. ATF in primary??? What makes you choose one ATF over another??
  139. Sprocket Seal Oil Leak?
  140. Inner Primary Bearing
  141. Is HD Clutch Spring Essential on Stage II?
  142. Engagement Point? Tried 1/4 Turn
  143. Comments welcome
  144. dump and oil drip
  145. 01fxdwg
  146. Whats gone missing?
  147. 1996 FLHTC Vibration
  148. Se compensator noise
  149. Clutch
  150. Oil in primary case
  151. 1983 IronHead XL1000 Cam Cover
  152. Problem with the compensating sprocket
  153. Does not include 1 and 5 gear
  154. whistling from primary
  155. Starter drive noise?
  156. Leaking Primary 1985 FXST
  157. Tranny Shaft
  158. '06 Dyna Shifter Drum
  159. Stripped Primary Outer Cover Drain Threads! - How To Fix?
  160. elec.starter ???? 65-69--help
  161. Stripped Primary cover drain
  162. Clutch disaster
  163. 5th or 6th Gear Needle Bearing Walking
  164. Clutch and mystery noise from rear
  165. 1974 Z90 2-stroke gear case oil
  166. 07 RK compensator shot?
  167. 1979 xls question about sprockets
  168. tranny
  169. Wondering if clutch adj. needed only
  170. Drive belt ID?
  171. 5 gear making noise
  172. Need help with diagnosing noise
  173. Primary Housing Leak
  174. 06 DYNA owners IPB I might have your solution
  175. Pulley Nut Tool
  176. 06 streetbob inner primary bearing question
  177. Phat Performance Parts...
  178. Front Motor Seal Leak for 3rd time.
  179. 08 Ultra - clutch issue?
  180. Link to catastrophic tranny needle bearing failure 02 FLH SE RK!!
  181. Link to catastrophic tranny needle bearing failure 02 FLH SE RK!!
  182. checking tranny oil
  183. 1989 XLH 1200 neutral problem
  184. sportster clutch problem
  185. trouble shifting to 2nd when cold
  186. How to remove clutch and starter jackshaft bushing in inner primary on 2005 Road King
  187. Main Drive Shaft Oil Seal - Replacement Cost at Dealer?
  188. Clutch Choices
  189. Is this compensator chatter?
  190. Street Bob 06 Clutch Grinding
  191. Help!! Clutch won't fully disengage....
  192. SE Products Comparison
  193. 08 flstc trans drain plug
  194. CF2 Performance Clutch
  195. Simple Compensating Sprocket or bad flywheel
  196. 78 sporty road speed
  197. what do i need
  198. 07 ultra downshift and it drops 2 gears
  199. Install/Ride Report: SE Comp + Evo Ind 49T on 07 EG
  200. Clutch problem
  201. street bob clutch removal
  202. Neutral Switch Problem
  203. perplexed by my ignorance
  204. primary knocking
  205. Inner Primary Bearing - 06 Street Bob
  206. Problem with my dad's Heritage
  207. clutch went out--why?
  208. 4 speed ratchet top shifting patern
  209. trans drive sprocket change
  210. 95 Ultra clutch issues
  211. High pitch noice from either clutch or tranny
  212. Inner Primary Removal 1979 Shovelhead
  213. Not catching
  214. 2007 FLHX Clutch problem NEED HELP
  215. Whinning Noise In The Rear
  216. Sportster Transmission Clunk
  217. Tranny Not Engaging
  218. Fifth Gear
  219. 66 slovel. 4seed to 5speed swap. what trans?
  220. Clutch Hub/ Drum Replacement / Oil Leak
  221. Tight spot in chain
  222. kicker shaft.
  223. Primary Fluid Question...
  224. Sticky Shifter Problem
  225. Drive belt sqeak
  226. Different Drive Belt
  227. hard to downshift after working on primary
  228. Stock starter can not hold up to a 3" belt drive
  229. Primary has sprung a leak
  230. Stock Clutch power limitations
  231. Primary Inspection Cover
  232. Help!!! Rattle noise
  233. 2009 5th Gear Clatter and 2010 Helical Cut 5th Gear
  234. Open HD chain drive on street bob????
  235. 07 fxstd rear wheel noise
  236. 76 Shovelhead FX
  237. Champion reverse gear assistance?
  238. 73 Ironhead Help
  239. Unusual knocking
  240. Shifting from First to Second
  241. shift arm loose on shaft of bagger
  242. Clutch, Transmission Troubles - Motor Trike conversion
  243. Neutral Light
  244. chatter/whine
  245. too much pony
  246. Belt to chain conversion.
  247. New clutch cable problem
  248. EVO Clutch question
  249. Lost Drive
  250. Blue or Red Locktite
