PDA
View Full Version : Oil Archive (no new posts)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20
  1. Mobil 1 v twin
  2. HD Long Oil Filter for Sporty
  3. Anyone use Valvoline 20W-50 motorcycle-conventional
  4. Baker Oil Pan
  5. Royal Purple vs HD synthetic
  6. 79 Shovel won't start
  7. Difference in Royal Purple brands
  8. Primary oil level
  9. Oil light after warming up
  10. Oil cooler - temp. difference?
  11. Burning oil?
  12. Accidentally changed my engine oil with diff oil.
  13. oil light after oil change
  14. XLCH oil light
  15. dipstick reading
  16. Oil for Desert Temps
  17. Still whining about oil temps.
  18. Changing the oil on an Evo
  19. First oil change
  20. Low Oil light on Ultra
  21. Belray
  22. primary oil mistake......
  23. QUESTION: Primary oil expiration date
  24. Royal Purple Oil
  25. ..one more post on OIL
  26. Oil cooler leak...stealership f'ed up
  27. 3Qts. or 2 1/2?
  28. Install oil cooler help
  29. oil pump alinement screws
  30. 07 bike/dealer now put formula+/not sny3.?? in primary and tranny
  31. 60 weight oil in twincam 88 non modified?
  32. dyno to sync
  33. oil cooler
  34. how often do you change
  35. synthetic oil to regular oil and vice versa
  36. Oil in Breather
  37. Quiet Engine, which Oil?
  38. Narleys oil coolers
  39. what oil to use at 110 Outside Temp
  40. oil filter
  41. oil light question
  42. Oil cooler for single down tube
  43. Followup..no oil pressure
  44. Oil Temp
  45. Oil light came on this morning???
  46. 07 roadking first oil change
  47. Valvoline Durablend 20W50
  48. Synthetic causes leak!
  49. Dino to Synthetic?
  50. Filter Pressure
  51. AMSOIL the Official Oil of Both the Sturgis Motorcycle Rally & Daytona Bike Week
  52. Amsoil research
  53. Using Engine Guard as Oil Cooler
  54. How to add 2nd oil cooler?
  55. Oil Level?/confusion help
  56. Heat question...
  57. Fatboy Oil Change
  58. DISCOUNTED K&N OIL FILTERS????
  59. SYNTHIC OIL, LARGER THAN 1QT SIZE?
  60. Drag 4
  61. New bike
  62. Dip stick issue on softail
  63. Mobil 1 4 Cycle/V Twin???
  64. Using Oil?
  65. IM NEW
  66. Oil Change
  67. Removing oil pan on TC motor
  68. Umbrella Valves
  69. High oil pressure
  70. quick question - steam from oil tank
  71. PLEASE HELP! OIL DIP STICK PROBLEM
  72. how about AERO SHELL OIL?
  73. Swapping out Air temp gauge with oil temp on street glide
  74. oil question
  75. Syn back to Dino oil
  76. Oil change on 96 RK
  77. Oil cooler and capacity?
  78. oil sender unit
  79. oil temp sending unit
  80. to much oil
  81. Mobil 1
  82. ANY 1 USING A REUSABLE OIL FILTER
  83. LOOKING FOR COOLING FAN THREADS
  84. No oil Pressure
  85. oil pressure gage - 07 SG
  86. Oil for 2003 Deuce 1450
  87. whining from trans..
  88. Changing oil, Checking fluid levels on trike
  89. Some help please
  90. mobil1 v-twin
  91. Could the manual be wrong? no its me
  92. Oil Preasure??
  93. Oil return line on softail
  94. Wholesale oil filters?
  95. '76 Sporty Oil Flood
  96. the more itride since my service the better this thing performs
  97. Major Oil problem
  98. Wierd Smell
  99. Can heavy-duty diesel oil be used in motorcycles?
  100. Oil Confusion for '07 Nightster!
  101. remingtom teflon dry lube gun spray
  102. Oil Question
  103. oil filters
  104. Newbe Oil Question
  105. Oil Change Question?
  106. how do you lube the throttle cables on an o7 streetbob
  107. This might the bomb oil. Cheap with high zink and the right amount of detergent
  108. Searched all the oil threads but I still have a question about zink content HD oil or Mobil 1 15/50
  109. oil line connections 1984 shovelhead
  110. Just ordered Amsoil for all 3 holes
  111. Which Redline oil for Sportster trans?
  112. Havoline 20w-50 in Sportster trans?
  113. electrical
  114. need help Engine oil
  115. Question about a Mobile 1 product...
  116. crankcase and tranmission finished!
  117. how do you check transmission fluid level?
  118. Questioned answered, thanks.
  119. so i called the dealership for a price on the gasket kit!
  120. Redline 20w60
  121. When switching oils...
  122. Good place for Mobil 1 V-twin online?
  123. Blue smoke at startup
  124. Tranny plug?
  125. Puking problems! ! ! ! !
  126. 97 fxstc lifter block
  127. Drain pan for oil change?
  128. anything wrong with super tech 85 140 gear oil freom wally world
  129. oil grade
  130. oil leak air cleaner
  131. 1,000 mile service
  132. Thinking of switching to Synthetic
  133. oil pressure light
  134. Brass or Copper found in oil
  135. OK to change all three holes at 5000 miles?
  136. Anybody use this oil?
  137. I Think My Ass Hole Is A Little Wider... Can Someone Let Me Know... (FIRST OIL CHANGE)
  138. Engine Oil Argument. Amsoil vs Harely's Synthetic.
  139. Amsoil Severe Gear Oil
  140. mist of oil?
  141. The power of amsoil
  142. Amsoil causing lifter noise?
  143. oil leak out of top reserve
  144. 2007 ultra oil
  145. Oil temp/synthetic question
  146. Mistake Synthetic back to oil.
  147. Redline Syn~ problems/issues?
  148. oil change scavenging
  149. Castrol oils
  150. Oil pressure different after going to synthetic
  151. Help with oil spots
  152. Oil filter ?
  153. message deleted.
  154. Drain Plug (oil) Location
  155. A motor total oil change ?
  156. Oil cooler connection question
  157. Synthetic oil and engine noise
  158. Oil Temp Gage
  159. Running Synthetic-how often change tran/clutch
  160. Hot an Bothered!!
  161. Help with Changing oil filter
  162. Checking oil (hot vs. cold)
  163. OIL COOLER
  164. synthetic oils
  165. oil pressure guage
  166. gear and clutch oil
  167. Mobil1 V Twin.....
  168. Mixing Amsoil with Mobil question
  169. Over tightening filter cause leak?
  170. Anyone used the StaLube syn. gear oil?
  171. New primary oil home made formula
  172. sportster oil type
  173. oil from the carb
  174. '08 fluid amounts?
  175. 1,000 Mile First Service Questions...
  176. Oil Check Valve
  177. K+N oil filter
  178. high oil pressure 70psi+
  179. Oil light coming on.
  180. Another Oil Temp Question
  181. Cranky Crankcase........
  182. Oil temp question...
  183. Pure power oil filters
  184. It didn't take 3 1/2 quarts
  185. No oil pressure
  186. different question about oil cooler
  187. 84' 4 speed tranny oil change
  188. napa1215 and 1225
  189. i did a no no
  190. Amsoil question
  191. Spectro primary oil
  192. Big Mess (no oil pressure/missing c-clips)
  193. Oil cooler fan.
  194. oil change
  195. 79 sportster oil pressure
  196. 75-90 or 75-140
  197. mobil 1 15/50
  198. Digital dip stick torx screw size???
  199. Lucas Oil
  200. Noob question- oil drain plug (all 3) location on 01 Deuce
  201. CASTROL Evo 4-Stroke V-Twin Motorcycle Oil
  202. Perf-Form Spin-On Oil Filter/Cooler Kit
  203. Evo crankcase vent valve
  204. oil cooler cover install
  205. Drag Specialties synthetic
  206. Red Line 20W50?
  207. Scavenge oil from filter before removing
  208. Oil Coolers?
  209. Oil Cooler change amount of oil ?
  210. Quick question about tranny oil
  211. oil leaking from air filter....
  212. routing oil lines 71 sportster HD???
  213. Where do you usually buy mobil 1 75w90 gear oil?
  214. Odor with Mobil 1 75/90 syn gear lube
  215. Allright to use auto 20w50, or should I buy Moto Oil?
  216. Best Oil Temp Dipstick?
  217. Redline Shock proof trans oil
  218. Oil temp gage?
  219. Help! primary case oil leakage
  220. decided to switch to syn, now what?
  221. I tried the "total" oil change method...
  222. aren't we being green w/synthetics
  223. Bikes with high mileage feedback on oil!
  224. pressureised oil tank 1980 FLH
  225. Have I
  226. Asheville, NC oil help
  227. Transmission Gear Lube ???
  228. Oil in the winter
  229. This What Iam DOIN !
  230. I hate Second Guessing Oil Levels
  231. hot or cold?
  232. AMSOIL in every hole ??
  233. Oil pump on Evo?
  234. Topping off trans oil.
  235. Transmission Oil
  236. 10K on 07 FLSTC, mob-1 VT 20-50 be ok in pri?
  237. Time between Oil Changes
  238. Bearing rotation
  239. frequency of primary and tranni oil change??
  240. Oil hose routing
  241. Fork oil weight
  242. Oil Filter FLHX 08
  243. HD Formula + Virgin Oil Analysis
  244. Castrol GTX 5w-50?
  245. stuffers for 00 fat boy
  246. WAY too much oil in a/c
  247. classic HD 1927
  248. 2000 fat boy stuffers
  249. Perform
  250. Oil change with out the mess ?
