PDA
View Full Version : Oil Archive (no new posts)
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20
  1. amsoil vs mobile1
  2. 3 hole oil change...
  3. Drag Specialties 20w50 mineral oil
  4. Amsoil primary syn v/s HD or Mobil 1 20-50
  5. Oil pressure switch
  6. 05 fxdc
  7. Oil for all 3?
  8. Oil leaking from Push Rod
  9. 2012 FXDC Small Oil Plug Leak
  10. Mobile 1vtwin at Walmart
  11. Oil
  12. Primary oil question
  13. 10w60 oil?
  14. Remote oil filter and cooler adapter
  15. Oil in tank but not in crankcase
  16. Question on changing the tranny oil........
  17. HifloFiltro Filters
  18. Crankcase dry and oil reservoir too full
  19. Mobil 1 75w 90 gear oil for primary?
  20. Baker +1.5 oil pan?
  21. M8 114 oil consumption norm
  22. Primary oil switch
  23. Effect of Red Line Complete Fuel System Cleaner On Oil
  24. Oil filter change hack
  25. Synthetic vs Conventional
  26. Did 3 holes today....
  27. Over heated synthetic oil ?
  28. Need help finding a dipstick for a '13 103
  29. S&S tappet orientation
  30. new flhtk ultra limited. what do i need to change the oils? how much and what weights
  31. Trans oil check
  32. 1st oil change coming up - synthetic or conventional?
  33. Mobil1
  34. What oil to use
  35. Preferred motor oil and primary and transmission fluids? Another Amsoil post?
  36. Oil change
  37. 06 heritage classic leaking crankcase
  38. Mobile 1 oil in a 2019 M8
  39. First oil change weird film in oil
  40. Oil line routing help needed 1980 FLH
  41. oil color
  42. Redline shock proof trans fluid in m8
  43. Choice of oil and primary gear lube ?
  44. Oil OVERHEATED after 10 minute ride
  45. Broken hose think it may be oil but not sure
  46. Dry Sump Question
  47. Oil Leak via Air Cleaner Fix
  48. Any Problem Mixing Oil?
  49. Which Oil
  50. Switching to Amsoil question
  51. Mobil 1 Rebate Offer (Spring 2021)
  52. M8 - Best Method to Turn Motor Over, Not Start
  53. Amsoil 20W-50 Best price ?
  54. oil pressure to high ???
  55. Ss175
  56. Frozen Oil Filter
  57. Transmission draining into engine
  58. Brand new Iron1200 pissing oil
  59. Amsoil Gear oil color
  60. Changing Primary and Transmission
  61. 2005 Roadking oil pan issue
  62. Oil Pressure
  63. Drag Specialties High Volume Oil Pump
  64. White stuff on dipstick
  65. Oil Pressure Gauge Install for sportsters
  66. Assembly lube leak, or oil leak?
  67. Run Old School Oil in the New M8 114?
  68. Run Old School Oil in the New M8 114?
  69. Screamin eagle oil pump alignment
  70. Brief "limp" mode while accelerating
  71. Spectra 75-140
  72. Lucas 10727 stabilizer oil
  73. Fuel/Oil Hose
  74. Whats the difference?.,,,
  75. Sumping question on M8
  76. A1 Ventilator vs Fueling
  77. Oil Pressure Question
  78. What oil needs does your engine have?
  79. Sticky Polls
  80. Good Price on Brad Penn Racing 20W50
  81. filter relocate
  82. Anyone try this oil?
  83. ATF in Primary?
  84. Maxima Conventional Oil and Heat
  85. Anyone tried this stuff?
  86. Availability of Synthetic Oils: Castrol and Valvoline
  87. For those who use 15W50 oil, NAPA deal
  88. M8 oil for crank case?
  89. Oil Filter Bib
  90. Straight 50 mineral oil in a 2012 Twin Cam?
  91. 2020 with Syn 3 sticker.
  92. Motorcycle Oil?
  93. Fork Oil Help
  94. M8 vs TC filter
  95. Checking Oil on Softail
  96. Luca dyno oil
  97. Could it be? Another oil thread? ;p
  98. Steelwool in the PCV lines??
  99. yep; another oil related thread
  100. M8 oil pump idle pressure
  101. Building my sportster
  102. Oil question, 2018 Fat Boy
  103. 2014 FLHX 3 holes oil change
  104. Are there any company’s that sell a oil change kit for us besides Harley
  105. Small oil leak near bolts under oil filter?
  106. Scavenger oil change kit
  107. Need help from you guys !! First oil change
  108. Is oil pump the culprit?
  109. Formula + over to Syn heavy duty
  110. How many of you ever get the desire to use a straight wt synthetic motor oil
  111. Thinking about going dino
  112. Does anyone use this?
  113. Lucas 20w50 or 50w Conventional Oil
  114. Winter storage oil
  115. Massive oil puking PLEASE help.
  116. Spectro 85W140 Heavy Duty Petroleum GL-5 Gear Guard Transmission Lube
  117. VR1 20/50 oil deal
  118. 2016 FLHT getting hot
  119. SYN3 observation and question
  120. 05 dyna wide glide oil issues
  121. Oil Pan screws - Allen Key size?
  122. Castrol 4 stroke 20-50 motorcycle engine oil
  123. Mobil 1 Rebate Offer
  124. Tried the Lucas oil stabilizer
  125. Kendall 20w50
  126. engine died..... my fault!
  127. I messed up
  128. Royal Purple??
  129. 81 Knuckle Aftermarket Oil Filter
  130. No oil on dipstick after change
  131. oil light issue ... weird ..
  132. oil light/sputtering/stalling
  133. 47 knucklehead oiling issues
  134. New HD Owner Question
  135. 1989 sportster oil tank venting?
  136. Oil level with oil cooler
  137. Harley's M8 Updated OIl Filter - Part #62700296
  138. Lucas Oil Comparison
  139. It seems to me.....
  140. Never Had This Happen
  141. Shopping for an indy
  142. Sumping issue wtf is that
  143. Oil leak from filter
  144. Oil smell
  145. oil leak at rocker shaft
  146. Spectro 6speed 75w140
  147. Never thought I would make one of these threads *help*
  148. Valvoline vr1 20w50 and valvoline syn mixed?
  149. Fx shovelhead oil tank removal & install
  150. fxr 1991 oil lines?
  151. Lucas Opinion or Recommendation
  152. New Longer M8 Oil Filter Available at this Dealer in York PA
  153. Oil consumption?
  154. Royal Purple 50w?
  155. Mobil 1 75/90 Question
  156. 2002 HD Electric Glide Ultra Classic
  157. oil change questions/concearns
  158. Help with a question.
  159. Mineral Oil for SE 110 Motor
  160. How many quarts of engine oil does a 2016 Street Glide take?
  161. 97 evo rebuild
  162. Revtech oils
  163. All 3 holes Syn 3
  164. Any new oil questions
  165. Primary oil
  166. Oil pressure drops 2007 Road Glide
  167. Case breather engine in a 1997 dyna
  168. Spectro 25w-60 installed for summer
  169. Made in USA oils
  170. sportster 1200 oil
  171. S&S Oil Pump for M8
  172. Blackstine lab results
  173. not your average oil question...
  174. Color of bottle ??
  175. Shovelhead oil smoke SOMETIMES on startup.
  176. Twin Cam B engine oil pressure gauge
  177. HD360 Turning Black
  178. Anyone use he vtwin Maxima oil they sell at a lot of online retailers?
  179. Dyna Oil
  180. Oil Leak from Breather Bolts
  181. Installed Ultracool oil cooler this weekend
  182. Primary Lubricant Question
  183. MoCo uses Conventional Oil in new bikes?
  184. 1989 softail hose question
  185. engine oil instead of primary oil?
  186. General service torque wrench necessary?
  187. Three Hole Oil Change Advice
  188. How to stop oil in air filter
  189. Using Condor Pit Stop for oil change
  190. Would You Change The Oil?
  191. Scavenger Puck Stuck
  192. 2014 street bob over filled
  193. New member with oil pressure issues.
  194. Several oil related ???
  195. New air cleaner and oil problems
  196. Shift Shaft Seal longevity on 2015 SGS?
  197. Oil question?
  198. Straight 50 weight , anybody ?
  199. oiled or not (air filter)
  200. New Member
  201. M8 107 Gasket Kit
  202. Debris = Oil Purge?
  203. Marvel Mystery Oil
  204. Oil for primary
  205. Oil leak Sportster 883 2017???
  206. Oil slinger problem while installing a new Baker throwout bearing...
  207. uest
  208. factory oil
  209. Sorry but Mobil 1 10w 40 RT ok ?
  210. Oil
  211. 1980sportster
  212. Synthetic or mineral oil
  213. Oil other than Harley brand?
  214. Oil overfill/oil smells like fuel.
  215. Assembly Lube- Change Oil?
  216. Syn3 or 360 Motor Oil
  217. Oil pressure problem
  218. Oil drains from bag into crankcase
  219. How many people does it take to change the oil?
  220. oil cooler
  221. trans oil in M8
  222. Lucus syn oil $9.99
  223. Another Oil Level Question
  224. Rotela oil
  225. EVO Oil line routing to oil filter
  226. EVO Oil line routing to oil filter
  227. Synthetic Oil
  228. Puking oil through the Air Filter
  229. Maintance for K&N Filter
  230. LIQUIMOLY oil additive, anyone using it?
  231. 20w-50 Synthetic OK in Primary?
  232. Pre filling the oil filter when changing oil
  233. Opinions on fluid changes for my 2005 Electra-Glide
  234. 2020 Ultra, cant get oil filter off?!?
  235. Anyone buying 20/50 oil in a 5 Gal pail
  236. Stage 2 question
  237. oil flow in rocker
  238. 2004 FXDWGI Oil Flow
  239. Papanda Oil Cooling System
  240. Mainshaft Oilseal Problem
  241. Are Sporster renound for being noisy with synthetic oil?
  242. 2006 road glide
  243. 2006 FLST oil light
  244. Lucas syn 50wt is a 20w50?
  245. Oil Gauge
  246. engine oil question
  247. New bike, should I change oil 1 year old 220kms
  248. Wet Sumping
  249. Latest thoughts on Oil
  250. 2016 Heritage Oil Change WHAT OIL TO USE
