PDA
View Full Version : Oil Archive (no new posts)
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20
  1. Oil levels Hot / Cold
  2. Oil Coolers / Warranties
  3. Redline Transmission
  4. checking oil on stand or up level
  5. Screamin Eagle air cleaner leaking but not leaking but leaking...
  6. Alen Ness Oil LeaK
  7. oil psi problem
  8. oil psi problem
  9. '13 FLD Switchback oil change
  10. What is the best price on oil now?
  11. What should High-flow oil pump oil pressure be?
  12. Oil light not illuminating
  13. What would you recommend
  14. Lost
  15. Who's Running the Same Oil in All 3 Holes?
  16. Striped out trans drain, Help
  17. 1990 FXR Lowrider Oil Light On
  18. Super Glide Custom Using oil
  19. Chaincase Drain Plug Leak
  20. Oil Cooler ?
  21. transmission oil
  22. Mobil1 at Auto Zone
  23. Oil light coming on on brand new dyna sreet bob
  24. Shell Rotella T1 50W Oil Question
  25. How much ?
  26. Changing the fluids from PO.
  27. 50w???
  28. Any ideas what oil is in my trans? Its light milky brown in colour..
  29. oil leak
  30. High oil pressure after Stage 1 A/C install
  31. Green/Brown/Yellow Oil?
  32. Reuseable Oil Filters ?
  33. Schaeffers oil 20/50
  34. FLO Oil Filters PCS4 & PCS5
  35. amsoil Dealer
  36. Grey Sludge
  37. Adding extra Moly to engine oil
  38. Stored all winter with (nearly) new oil
  39. Oil level higher when hot?
  40. Quicksilver 20w50
  41. First 3 hole change, my head hurts
  42. K & P reusable filters
  43. pro flow oil pump
  44. Oil filter hard to get off (may have fix)
  45. Harley Oil?
  46. synthetic and standard oil
  47. Oil question for Twin-Cam use?
  48. Oil cooler?
  49. changing oil tank out
  50. oil cooler
  51. Synthetic vs. Conventional Motor Oil
  52. SPORTSTER 1988 - quad seal - oring
  53. Question on oil eight
  54. Full syn or mix with dino oil?
  55. Which fork oil?
  56. greasing the steering head
  57. 20w50 full syn buy 1 get 1 free Advance auto
  58. 2009 Sportster Puking Oil; Not sure why
  59. Softail transmission oil change drama
  60. High oil Pressure
  61. Question for oil experts
  62. Autozone close out
  63. Reusable oil filters.
  64. Accidently put Gear oil in the clutch
  65. Oil filter.
  66. Finned oil filter cover...
  67. With all the talk about 5 Microns
  68. castrol power rs vtwin 4t 20/50
  69. Oil Level Issues
  70. Remote oil filter benefits?
  71. Metal shards in oil after Twin Cam rebuild
  72. Vaporizing Oil ??
  73. Stripped primary drain plug
  74. thoughts on oil change
  75. 2002 Twin Cam 95 Superglide
  76. Synthetic Oils for Shovelhead Motor
  77. Another Reality Check...
  78. How much does the oil pump actually per min
  79. Help w/ Oil Tank Replacement
  80. Small leak outta head .... what to do?
  81. Build up on oil drain plug
  82. All 3 Holes
  83. Is it dangerous to switch from reg oil to syn at 33,000 miiles?
  84. So How Good are J&P Cycles oil filters ?
  85. Which oil cooler is best?
  86. oil pressure gauge
  87. Oil filter bypass valve spring psi set point ?
  88. Food for thought...read at your own peril
  89. oil coming out of breather tubes
  90. Wyhy does conventional oil make my bike quieter?
  91. K&N Oil Filter Needed For A 2005 Harley Deuce ?
  92. How to determine oil type when it's in the bike...
  93. What is a good break in oil to use?
  94. What oil in 90 flhs?
  95. Switching to Synthetic Help
  96. Motor oil “wear protection” ranking list
  97. Which oil in which hole??
  98. Is Redline 20W50 ok to use?
  99. Oil and IPB failures
  100. No oil pressure at all when hot
  101. oil presure changes sounds like slaping
  102. Tight Oil Filter
  103. Does oil have a shelf life?
  104. H-D oil cooler install
  105. Burping Oil from vent tube filter
  106. Synthetic to conventional oil ?
  107. Oil cap shoots off.
  108. Trans fluid leaking???
  109. old oil in bike
  110. Oil light flickering then seize. Advice on rebuild?
  111. Scavenging - anyone else doing it?
  112. stock oil filter adapter
  113. Using oil between changes
  114. Oil Loss. This happen to anyone else?
  115. discounted oils!
  116. Help!!! What did I drain?
  117. 2011 Ultra Classic oil usage
  118. Are You Ready For This?
  119. Mobile-1 75w140 gear lube Verses SuperTech 75w140
  120. NEW Rider with Oil Question from overheat
  121. Any suggestions on oil/filter purchase
  122. Oil running out of air cleaner
  123. Mixing oils
  124. Oil running out of air cleaner
  125. Evo oil usage
  126. 98 Evo Dyna Wide Glide Oil Plug
  127. 1991 fxr oil filter housing
  128. Oil light goes off after turning off the bike (2012 Iron 883).
  129. New ride & rider... Couple questions!
  130. need advice quick, low oil, stranded an hour from home, carb misting oil
  131. On Sell M1V2
  132. Oil Pressure, but no flow
  133. Oil Temp Poll
  134. Air cooled engine oil question?
  135. Boiling oil
  136. conversion problems
  137. small oil spot after oil change
  138. Oil pressure indicator lamp
  139. Dumb question of the day !
  140. oil pressure gauge reads 0
  141. dino to synthetic
  142. 08 nightster with andrews cams,what oil pump do i run
  143. Oil leak from under oil filter
  144. loosing oil
  145. I Did Not Know This:
  146. Oil Light Coming on After rain
  147. synthetic @ first service
  148. Same oil in all three?
  149. klotz vs redline
  150. black oil lines are
  151. 98 sportster intermittent oil light
  152. Synth or conventional
  153. Primary Oil Change Help
  154. AeroShell 15W-50
  155. Mobil 1 15W-50 Extended Performance
  156. Oil Pump??
  157. Good vibes, or maybe not..........
  158. Great video on youtube with step by step instuctions
  159. API Oil specifications from Harley-Davidson
  160. Oil
  161. GOING FOR MY 1000 mile service tuesday
  162. Newbie Transmission Lube questions
  163. Don't know about this!!
  164. milky gunk in oil
  165. what fluids do I need Guys and gals
  166. Oil not pumping back into the pan
  167. Oil Dipstick popped out while riding
  168. reccomended oil filter?
  169. Jagg
  170. Oil and overheating questions
  171. Importance of API Classifications on Oils
  172. oil pressure guage
  173. Oil temperatures and oil coolers
  174. 03 Fatboy with serious oil leak problem. Help!!!!!!
  175. oil level
  176. Valvoline max life
  177. 120R Heating & Cooling
  178. Primary and trans oil question
  179. How far past break in can I go on new oil
  180. The eternal question...
  181. No API on Harley 360 conventional oil
  182. How to fix a wet sump... without running
  183. V-twin oil or not?
  184. Hi, new from CA, Oil ?
  185. condensate in oil
  186. Replacing HD Oil Cooler with Jagg Oil Cooler
  187. 2009 FLHX Street Glide Oil Plug Locations
  188. high oil psi to no psi
  189. Monolec Engine oil and gerbox oil.
  190. leaking oil
  191. Redline Heavy Shockproof #58204
  192. Mixing Syn 3 with straight 20/50
  193. Oil temp problem
  194. oil temp dipstick
  195. 2011 FXDB Fork Oil Level
  196. Oil change questions
  197. Transmission Oil Change Question
  198. Oil Sale
  199. where is the oil
  200. Why is there oil down the side of my bike?
  201. Oil Drain Plug O-ring........
  202. Spurgin oil heat sink/cooler
  203. How Clean Is Your Oil?
  204. Tapping sound in warm engine
  205. Leak after cooling off
  206. Oil dripping from breather
  207. atf??
  208. primary fluid Q
  209. Stupid question
  210. Fumoto Valve
  211. O-Ring for Oil Plug
  212. What 2-stroke oil to use, and where to find it
  213. 2011 Softail Oil Change - only takes 3 quarts
  214. 2000 Dyna Super Glide Oil Won't Drain
  215. Oil Leak Fixer
  216. Oil line change
  217. oil feed outlet from tank
  218. help please. first time pan owner.
  219. Stopped using oil
  220. oil tank seam leak
  221. Is it possible to have air in oil lines...?
  222. Racking my Brain
  223. oil temperature
  224. turn signals
  225. red line oil
  226. API Gear and Engine Oil Service Category Charts
  227. oil cooler delete?
  228. Lubing Steering Head Bearings
  229. 2007 road king
  230. Please, help a brazilian about oil
  231. Forgot to refill oil
  232. 2013 XL1200X (Sportster 48) Oil/Primary Question.
  233. Oil line routing from oil pump 99 sportster
  234. gurgling and spitting oil out the breather help
  235. Pulling the primary cover
  236. Bel-Ray Gear Saver - Anyone using it?
  237. looking for a video to repair valve and rocker box oil leak?
  238. oil filter
  239. No oil in pan
  240. Shovelhead Oilers
  241. gear oil?
  242. 74 Shovehead oil
  243. High mile changeover to synthetics
  244. Oil capacity for 05 883L with oil cooler
  245. Jagg oil coolers?
  246. oil changes
  247. Redline primary oil in trans?
  248. oil light lit but the oil level is full??
  249. Anyone tried or uses PENRITE Oil?
  250. stroker oil return
