PDA
View Full Version : Oil Archive (no new posts)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20
  1. No manuel, need pdf's for fluid changes
  2. Can't seam to get my Oil level right on my 07 SB
  3. OIL CHANGE
  4. Synthetic Oil
  5. Noob trying to change oil HELP!!
  6. Sportster oil tank question
  7. Spectro Synthetic oils
  8. Oil level question
  9. Dipstick Issues
  10. wix filter on evo
  11. Should this be pluged off
  12. Why 75w90 in tranny?
  13. SAME IN ALL 3 HOLES
  14. Mobil 1 75 w 90?
  15. 1st 1,000 mile oil changes
  16. high oil pressure
  17. AMZOIL
  18. 07 Road King 10k mile service/questions
  19. oil flow question
  20. doing some oil filter research
  21. burning oil in 95 road king!!!
  22. Burning oil?
  23. Oil Filter Relocation
  24. 2002 fatboy oil
  25. 2007 RKC Oil Change
  26. after 95ci build high oil pressure
  27. Oil spewing out of the Filter
  28. Need Some Oil Change Directions Please
  29. Oil Filter length
  30. Oil Change Engine Temp Question
  31. Oil Pressure on tc-88
  32. Synthetic at an early age
  33. How much is too much?
  34. Oil dipstick blowing out, oil all over right side of my 2000 TC88 Deuce
  35. Oil Light
  36. Oil temp guage install question?
  37. Penzoil Long Life 15W-40
  38. zMax?
  39. break ii miles before syn?
  40. Amsoil new grade srn & srt
  41. oil cooler sleave
  42. does anyone use straight 50 or 60 wt oil?
  43. HD fuel formula+ question.
  44. oil cooloer ??
  45. HELP!!! Low Oil
  46. Amsoil.....Wow
  47. new oil cooler
  48. REPSOL OIL
  49. Oil Res Temp dipstick
  50. Well...did my first tranny fluid change today.
  51. Anyone have suggestions for something like this...
  52. Oil change
  53. Standard Oil Consumption on a 95"/ 2004 FXDWG
  54. Lookin for a good synthetic...
  55. Baker P1P
  56. Mobil 1 Warranty
  57. oil comming out of carb
  58. Slick 50, Microtech, other?
  59. 2005 Deluxe Fluid Capacities
  60. Ordered the Scavenger
  61. Fuel smell in oil...
  62. Engine Fogging
  63. oil again (sorry)
  64. Well, did my first oil change today...
  65. oil leaks
  66. changing engine covers
  67. Oil Temp Gauge For FXDBI
  68. Fork oil and capacity??
  69. oil around the spark plug???
  70. pertroleum products
  71. color of oil??
  72. Do you use Harley oil or others?
  73. Drain plug question
  74. Best Fluids
  75. 1st oil change in 08 ultra, What is Formula+
  76. mobil 1 5w50
  77. tranny oil ?
  78. oil cooler
  79. Syn vs Conventional
  80. gas smell in the oil
  81. Fan Kit yes or no
  82. when to use synthetic oils ?
  83. How does this sound - 3 fluids in holes
  84. Fluids on 06' Street Bob - Confused, with questions??
  85. HOW OFTER SHOULD TRANNY AND PRIMARY OILS BE CHANGED?
  86. Where To Find V Twin
  87. Oil warning Lamp
  88. k&p oil filter
  89. HD to non-HD oils
  90. Condensation build up
  91. Mobil
  92. Recycling used synthetic oil
  93. Purolator oil filters
  94. I may have screwed up
  95. Lubrication
  96. NoBody Really Knows-Do They?
  97. Spectro Golden Semi Synthetic in Crankcase
  98. Tranny oil question
  99. '01 Road King noisy mobil 1?
  100. Amsoil or purple?
  101. Advice from Stu Pididiot
  102. What torque weight do you use?
  103. WTK: Oil Chaning Tips ~ Softail
  104. Reading dipstick level
  105. Oil Temp 88 vs 96
  106. Synthetic oil for '81 shovelhead?
  107. Primary oil and clutch wear
  108. An observation and 2 questions
  109. Oil Filter Gasket Blowout
  110. when can i switch to amsoil ?
  111. Oil Cooler Cover
  112. 3 Holes?
  113. Oil Gauge / Oil Pressure Fitting on TC88?
  114. Who runs Amsoil
  115. What type of Fork Oil
  116. Oil cooler brand - Any suggestion?
  117. Synthetic Causes Bearing Cavitation
  118. Oil Coolers
  119. h/d oil filter part#
  120. Fluids for '92 DynaGlide Custom
  121. Oil Pressure Sender
  122. 25K Too late to change to Synthetic?
  123. Factory oil......?
  124. Of Interest to Oil Junkies
  125. Oil cooler thermostat?
  126. changing from reg oil to synt oil
  127. 98 hert. softailspringer annv plug???
  128. Who has very high mileage engines on synthetic oil?
  129. Synthetic... but not yet.
  130. Engine Oil
  131. check this out!!
  132. 5 Micron Filter
  133. OIL FILTER MESS
  134. Oil Pressure
  135. Oil Options???
  136. Valvoline 4-Stroke Motorcycle Oil
  137. M! 75-90 Gear Oil
  138. Oil tank puked on me...
  139. Pulled wrong Plug
  140. Oil Temp Guage
  141. Oil
  142. WHAT BRAND SYNTHETIC SHOULD I USE?
  143. Drain Hole locations 06 Fatboy
  144. What is this allen bolt???
  145. Softail Scavenge Oil Change - Mishap OR Cleaning Your Bike When You Don't Want To
  146. Oil Pressure Problem HELP Please
  147. Which Redline
  148. synthetic oil and your bike
  149. oil dip stick
  150. Dyna Oil Filter Relocation
  151. Oil Pressure Idiot Light.
  152. oil change issue
  153. Oil change hot or cold?
  154. Which tran oil to use?
  155. Oil plug location on Harley
  156. change stock oil to synthetic oil
  157. Oil Analysis
  158. I've done it
  159. WTF went online searching for type E weight specs
  160. IF OIL COOLER USED
  161. )* FLSTC anniversary edition tranny oil question
  162. newbie stupid question number 1
  163. Feuling Oil Breather...SAVE YOUR MONEY!
  164. TC Oil Change, how much oil
  165. spectro 6 speed lube in a twin cam 5 speed tranny
  166. '53 Panhead oil pump
  167. Oil filter Question.....
  168. Oil Filter Change
  169. H-D dealer suggested, Mobile 1 in engine and H-D in transmission.
  170. GREASE
  171. Wal-Mart
  172. miles and temps
  173. Oil Cooler
  174. too much oil in tank
  175. Pure power oil filter
  176. Cam Tensioner and Synthetic Oil
  177. Trany oil change by the manual 20K miles
  178. switched to Mobile 1 today
  179. How cold is too cold
  180. Tranny oil
  181. oil pump cavitation
  182. Just changed from dino to Mobil1
  183. Bent oil pump shaft!
  184. Second Best
  185. Cold Oil Pressure
  186. Redline MTL
  187. synthetic oil choice
  188. Leak
  189. Cold weather is here... what weight oil are you using?
  190. Where to buy oil on Oahu?
  191. Do I need to change oil
  192. High Temp Oil Breakdown re: 96ci
  193. OIL CHANGES
  194. Mobil gear oil in Vancouver BC?
  195. oil in phoenix
  196. neutral light flickers when hot
  197. hanging oil filter!
  198. syn 3 air bubbles on dipstick
  199. Old Horse, New Oil?
  200. Oil for Big Bore Conversion
  201. Advantage of using V-Twin over regular Mobil?
  202. Royal Purple
  203. Have I Stuffed Up Here?????????
  204. Syn3 in trans and primary
  205. Mobil1 5w50
  206. Breakin oils change
  207. Lucas 80w-90 Gear oil
  208. a friend of mine who owns a shop says
  209. Red Line Oil response to tests. Long
  210. I have a oil leak
  211. Interesting oil test report from MCN
  212. Oil/filter
  213. Oil Filter
  214. Tranny and Oil Change Question
  215. severe gear or 20-50 in tranny
  216. how to get amsoil local
  217. Another filter question...
  218. Redline vs Mobil1
  219. Interesting Observation (oil)
  220. Filled oil a little over the dipstick line...
  221. Mobil1 75-90 information required
  222. Military Use of Synthetics
  223. synthetic oil in primary ok??
  224. Cold weather oil
  225. Added oil, but now overfull? Coming out of overflow...
  226. Cant find the oil filter cover?
  227. Amsoil High Performance 20w50
  228. Oil in 06 Fat Boy
  229. my 08 SERK came with SYN 3 in all three holes-whats the consensus-keep it or M1?
  230. Primary Level
  231. Cam Plate Good or Bad?
  232. Newbie needs help with oil leak
  233. How do you dispose of the old oil after an oil change
  234. I HATE AMSOIL synthetic oil !
  235. Oil Filter Mount Loose
  236. Oil Change experience using the Scavenger Method
  237. ATF Type F Oil?????
  238. MyOilShop - sponsor?
  239. rounting oil lines on a twin cam bagger
  240. First timer to change fluids
  241. Redline ShockProof Heavy - Is it suppose to be clear?
  242. UOA
  243. Switching to synthetic oil what about left over dino oil.
  244. Teflon Paste on Drain Plug threads.
  245. CANT FIND MY MANUAL>>>>>URGH!!
  246. 20W50 In All (3) Holes
  247. Synthetic Oil, how many miles?
  248. Purolator PureOne - Expired
  249. Oil Full reading....
  250. oil filter 2008 heritage question
