PDA
View Full Version : Oil Archive (no new posts)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18 19 20
  1. Formula+ in tranny and Primary-OK?
  2. Sifton oil cooler
  3. 75/90 or 75/140
  4. Dino verse Syn
  5. redline heavy shockproof....isn't it too heavy?
  6. Amsoil Question?
  7. Redline at 7.95 a Quart!
  8. Redline Oil
  9. does anyone else notice this?
  10. 1000 mile service on new Ultra
  11. How hot is hot?
  12. Dipstick blowing out!
  13. 10,000 mile service
  14. oil check
  15. Oil Cooler filter mount freeplay?
  16. Redline Shockproof - Leak
  17. Pure Power Reusable Stainless-Steel Oil Filter finds HP and TQ article
  18. MOVED: POLL from Doc 1
  19. K&N Oil Filter or Genuine HD Oil Filter?
  20. Discounted Amsoil??????
  21. Brad Penn Oil
  22. Lift Required to Change Fluids?
  23. Amsoil Dealer in Indianapolis Area
  24. Dealer Oil Change
  25. Engine Running 20 degrees cooler
  26. Oil Filter Cross Reference
  27. motor oil
  28. Castrol Motorsport 10W-60 motor oil
  29. What type of Gasket
  30. Feuling oil pumps
  31. First 1000 Service Question - New Rider
  32. Redline shockproof trans oil
  33. Transmission / Primary oil
  34. Oil Change HELP
  35. crankcase breather blowing oil
  36. Is the Mobil 1 20w-50 V-Twin in a new container???
  37. Amsoil philosophy question
  38. need oil!!!!!!!!!!!!!!!
  39. Red Line ShockProof Gear Oil Review
  40. Royal Purple Oils?
  41. Amsoil Oil filter size change??
  42. Oil leaking like seive!
  43. Oil filter question
  44. Amsoil Rep Say's
  45. Finally did the COMPLETE oil change plus other fluids !
  46. Mobil1 V-Twin in Houston
  47. K&P Engineering Stainless Steel Micronic Oil Filters
  48. Purchaseing Mobil 1 V twin in Omaha
  49. cam support plate/ oil pump....TC/88
  50. Amsoil trany oil??
  51. 75w-140 OK in '07 Tranny?
  52. FORMULA + IS NO GOOD IN TRANNY!
  53. Considering changing oil to Amsoil in a 95 Road King FLHR. What do you think?
  54. USING OIL??
  55. Miles between oil changes
  56. How much fluid in primary?
  57. purolator oil filter
  58. 15K oil change, Should I do it myself? Newbie here!
  59. Oil Pump Data
  60. primary
  61. Best prices??
  62. Low Oil Pressure Light on Sporty
  63. Hi oil temps caused by wet sumping?
  64. odd oil leak
  65. Redline Oil
  66. omitting primary oil feed lines
  67. Mobil 1 V-Twin Oil...
  68. Oil Cooler
  69. How useful is a jack to service the fluids?
  70. Motorcycle Oils vs. Automotive Oils
  71. dark color in primary case lube
  72. oil
  73. Dumb Question
  74. oil pressure
  75. Oil from the Factory
  76. mobil one 20w50
  77. oil/gear oil
  78. Need Advice on Fluids
  79. Transmission oil
  80. 81 FXE OIL LEAK SOLVED
  81. Syn3 Blows Donkey Balls
  82. Transmission Oil Concern
  83. Confused with Amsoil policy
  84. Oil Change ? on 07 Custom
  85. How much oil
  86. Oil other then HD
  87. Paranoid oil change.......
  88. Which oil cooler to buy?
  89. Trans Oil Question
  90. Void Warranty? Name the Dealer who says it!
  91. The REAL truth behind MC vs. Auto oil? Facts & Claims
  92. wrong redline?
  93. Oil Help - 2007 Clatter 5th Gear Noise!
  94. Syn3 from Factory
  95. Lucas Oil
  96. manual has wrong info per 06 dyna fluid plugs
  97. What's this on my oil plug?
  98. Mobile 1 by mail?
  99. Fast Delivery of Red Line Oils!
  100. Jagg Oil Coolers
  101. should be ok, right??
  102. please help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  103. Red Line Shock Proof Heavy...
  104. mobil 1... i have 2 questions
  105. Oil pressure guage
  106. Putting 79 Shovel to Bed
  107. fatty trans oil change a friggen mess??
  108. Congrats to you all
  109. Proform oil filters
  110. Oil Change ???
  111. Severe Gear vs. Redline Shockproof
  112. castrol 20w-50 oil
  113. MEASURING CUP
  114. Hard Oil Lines
  115. So so experience with synthetic 20/50
  116. SYNTHETIC OIL IN NEW BIKE
  117. please help
  118. Is AMSOIL that good?
  119. Complete oil change on 05' Fatboy ?
  120. Another oil test guys.
  121. 1000 mile -> Royal Purple
  122. AMSOIL question
  123. oil gause has water in it
  124. oil circulating
  125. Gear Oil 85 /90 or 85 / 140
  126. breather problems
  127. Oil Cooler - Leak?
  128. A question before my first oil change..
  129. Who uses K&N oil filters??
  130. 07 FLHR Fluid Capacity
  131. Mobil 1 75W140 gear lube
  132. should an oil cooler be part of 95" build?
  133. 89 FLHTC Oil Plug?
  134. any one use Valvoline V-Twin oil??
  135. Is there a way to flush old oil out of bike?
  136. Simple oil question....really!
  137. oil amounts
  138. Rookie Needs Oil Help, Lots of questions
  139. Would you make the change
  140. Where to buy oil besides dealer
  141. oil cap blown off
  142. My turn to bash the "oil experts"
  143. Amsoil
  144. hey sedbiker62
  145. Mobile1
  146. Spectro 75W-140 6-speed transmission oil
  147. leaky fuel tank
  148. White goop in oil
  149. 96 CI oil temp?
  150. Spectro oil, Anyone use it
  151. Need Help! How much gear oil in a six speed?
  152. Installed HD Oil temp gauge in the RG.
  153. Rev Tech Oil
  154. oil cooling
  155. Amsoil Oil Filter Question for my 06 Sportster
  156. oil cooler install?
  157. Oil cooler fans
  158. A question for all the oil changing experts
  159. anti drain back
  160. Damage Anything?
  161. Primary oil levels.
  162. oilI
  163. Amsoil question
  164. Questions for sedbiker62 (Amsoil Guy)
  165. Oil Leak
  166. oil change intervals
  167. 1993 EVO Wide Glide - OIL PUMP WARN OUT?
  168. Any credible research on best oil for hot weather
  169. First Oil Change
  170. Oil for revtech motor??????
  171. Torque wrench'n oil/tranny fittings ?
  172. Oil indicator warning light is flickering when in idle... (hot?)
  173. cold oil
  174. Oil Leak, need help
  175. Synthetics in a '56 panhead?
  176. When to switch to synthetics?
  177. oil filter leak
  178. road king primary oil level
  179. tranny plug location
  180. Lucas Heavy Duty
  181. Umm...
  182. Oil Leak Help!
  183. road king oil quanity
  184. Castrol
  185. "Quietest" oil for the valve train?
  186. Harley digital oil gauge
  187. New Guy Question - Oil for Breaking in
  188. Changing Fork Oil HELP please
  189. Royal purple
  190. Can stealer tell what oil you are using?
  191. BND aoutmotive (Brand) oil
  192. Amsoil in the most unlikely place...
  193. Softail oil feed line - weeping
  194. trans oils
  195. oil filtration
  196. 06 Ultra Classic oil change
  197. Complete oil change question ?
  198. MISSING OIL after oil change.
  199. Never thought I'd have to ask this, but......
  200. Newbie Question
  201. CASTRO 20w50 sYN
  202. P/N for Mobile1 filter
  203. HD Lube Sources
  204. Good Stuff (complete fluids change)
  205. Revtech 100"
  206. Red Line Supplier
  207. Fork oil question
  208. oil fill mark 1995 fxstc
  209. Oil Temp conflict
  210. Oil Change Question
  211. What is normal Oil Consumption?
  212. synthetic oil
  213. A couple of Amsoil questions
  214. Hook a brother up
  215. Pure One filters
  216. oil change help
  217. Oil again
  218. What size torque wrench's do i need ?
  219. Amzoil vs Royal Purple
  220. Read all the posts............still confused!
  221. "Genuine HD Oil"--That annoys me!
  222. oil change mess avoidance
  223. longer oil filter
  224. When should I change my oil?
  225. harley oil filters
  226. Red Line MTL question ?
  227. Conflicted on what oils to use...
  228. Decided to try Amsoil
  229. Dealer Said Warranty Void
  230. oil drip - revtech - newbie!!!
  231. oil switch and sound
  232. AMSOIL DEALERS
  233. Wheree do you buy K & N oil filters ?
  234. HD Premium Oil Cooler for Softails - For Sale
  235. Oil grade {help}
  236. Mobil 1 synthetic ATF in primary
  237. Stupid newbie Question
  238. Definitives Filtration System
  239. 91 FXR Oil coming out of vent
  240. Red Line Oil
  241. oil leaking at air filter
  242. primary oil?
  243. is ROYAL-PURPLE car oil also group IV syntetic?
  244. 81 shovel oil leaks
  245. Mobil 1 gear oil question
  246. Jus Changed to Mobil1 75/90 trans
  247. what else but... Synthetic oil
  248. Oil Cooler Valve?
  249. Bye, bye Syn 3
  250. 10K Amsoil Oil Change
