- Check my research
- Switching types of oil
- Unknown oil leak
- Changing Oil 2011 Heritage Softail
- Oil leak 2016 Heritage Classic
- synthetic oil
- Reusable Oil Filters
- over filled oil
- new harley oil system
- 2017 touring forks
- Changing oil on a '97 FLSTF
- Mesh reusable oil filter truth
- oil Bled from tank to crankcase early evo 1340cc
- M8 Breather bypass
- To those of you who run ATF in your primary
- Oil Pressure GAUGE
- Elec. Dipstick
- Truth or Being BS'd???
- Oil pressure spring?
- Sportster wheel chock
- gauge reads zero
- Pressure Sensor / Switch
- Castrol 20W50 with HD360
- Syn 3
- Milwaukee 8 oil
- trans mission oil change on a 2011 softail deluxe
- 2006 Street Bob Drain Plugs
- Love Jugs
- Breaking down 30 year old 2 stroke oil
- Dino vs Synth with M8?
- 2016 low rider with 120R
- Oil question
- opinions matter when vibrating
- engine oil
- Oil in the Miami area
- The latest in oil receptacles..a oil bag.
- Mobil 1, 0w40 fs oil
- New build- 1st start- freezing temps
- Not an Oil war just information:
- SS reusable oil filter question
- Replacing Oil Pan on a DYNA
- Oil spitting out trans breather tube
- Oil Pressure ???
- Suggest Transmission oil to use
- M8 oil issue -- HELP
- 3 hole change to Redline - Neutral a bit harder to find
- Penn Grade Semi Synthetic vs Mobil 1
- What kind of oil to use in a Shovel?
- Redline vs. Amsoil
- No going to the heads but oil is pumping to the tank
- Red Line Transmission Oil Question...
- Oil Temperature
- 81 Shovelhead Wide Glide
- oil change and mileage
- Oil Mixing Question
- Anybody not make a mess when they change their oil?
- Switching from Syn3 to HD360 20/50
- Hey guys I think I have a problem
- Oil Level vs Oil Consumption
- are volar oil filter any good?
- Type of oil for a harly sporster custom
- Washable Oil Filters - Anyone have test results?
- 89 Ultra Oil Cap
- oil around spark plugs
- Easy oil change? Or larger problem?
- 2003 fat boy
- What Brand of Oil do you use for your harley
- Oil leak
- Mobil 1
- Primary oil for a 1200 evo sporty
- 97 Electra Glide Classic
- $220 K&N Filter "Meets OEM Specs"
- Not Impressed with Mobil 1 VTwin
- 2017 103b tranny dip stick
- Oil lamp on
- lost oil pressure why?
- Rogue Chopper Scavenger RC140
- Amount of oil left in bike at oil change?
- Reverse storage
- Amsoil vs Klotz vs Screaming Eagle
- Blud lubricants,New Oil ?
- best oil viscosity rating for 1200 sportster
- Spitting oil
- Bubble, Bubble, Toil and Trouble..Harley SYN3...
- oil change on jiffy stand or horizontal
- Sale at rock auto
- 103 a tad noisy
- oil temps
- Sumping ...need enlightenment
- $7.13 Price! for K&N Oil Filter # KN-171B
- I had a big bore 95 kit installed on my 2000 Dyna and i seem to use more oil now
- Belray semi syn 20/50 oil opinions
- 2014 Dyna Low Rider Oil Problems 103
- Scavenger oil change system.
- Progressive 2" Drop fork oil level
- 02 Sporty oil not draining
- 2000 Flhtpi oil amounts
- Wally World Quicksilver 20W-50 Motorcycle Oil
- metal in oil
- Speaking of thread
- Hose leak
- Should I keep or should I change?
- Digital oil temp and level dipstick
- Engine stalled oil light goes on
- Oil everywhere!
- Definitive proof it doesn't matter what oil you run
- Oil tank question
- All so confusing Primary and Transmission oil?
- Primary oil instead of motor oil
- Harley Oil changes easy with This tool!
- Oil filter loosely mounted?
- 2003 1200s
- Royal Purple HPS Syn 20w-50 all 3 holes
- Harley Oil Filter NO SPILL "Capture Bottle"
- oil filter
- loss of oil from tank
- Switchback 2012 oilchange
- South West HEAT, fluid recommendations.
- 02 softail oil change question
- 20W-50 vs 10W-40
- Syn 3 in all 3. Not a fan.
- Oil change mistake!
- Too much crankcase pressure.
- oil cap popping off
- Motorcycle oil or conventional oil?
- lubricants
- fork oil
- '97 FLSTS Flooded, not talking gas and oil
- 245 degrees to hot?
- Oil filter
- too much oil
- Trans fluid
- 1988 Harley Davidson Softail FXST
- Beware of the redesigned K&N KN170 and KN171 filters
- 1971 sportster
- Convert hard oil lines to rubber
- Oil overflow tube
- Synthetic oil dos and don'ts
- Recommended oil type
- oil breather
- Switched
- Stripped Primary Drain Threads
- Maximum Miles on HD360 oil?
- 2012 streetglide oil dip stick
- Blow Back
- Getting a good oil reading?
- Oil filter relocation?
- Normal Operating Temp '15 Dyna Low 103
- oil grade
- "Stop smoke" additive increases viscosity.
- Oil cooler gasket
- Should i complete Fluid swap after sitting for a couple years?
- Alternative Oil Filter
- Mobil 1 20W-50 V-Twin Oil
- 2016 street bob oil level
- Which oil for forks and rear shocks?
- Checking oil level
- Oil shut off?
- Anyone Using SuperTech 20W50?
- Amsoil base stock
- SYN3 related transmission and engine failures
- Which Redline Shockproof for tranny?
- Cometic Gaskets
- Oil choice, here we go again.....
- 1981 shovel crankshaft oil feed
- Oil Question....Calling All Oil Gurus
- My 15 RGS is leaking Oil
- oil filter wrench
- Replace Air Temp Gauge with Oil Temp Gauge
- schaffers oil
- System 1 reusable oil filter
- Mobil 1 V-Twin Synthetic
- Red Line MT-90 75W-90 in 2007 XL1200C Sportster
- oil tank
- What oil can I use besides the HD brand.
- How much oil is left in crankcase, when you drain oil pan?
- Please explain how engine is connected to oil pan, which is under transmission(?)
- Ever tried Omega 690 Super EP gear oil?
- Oil Filter Sandwich Plate
- Funny oil discussions. Engine guy is here.
- Redline causing moisture in trans?
- Weird set up+harley n00b
- Oil cooler mix and match
- what type of oil
- an opinion oil question
- Oil pump and cam plate Fueling or S&S
- Change oil?
- Oil pumping out of breather
- Uoa
- Where can I buy Amsoil online for a decent price?
- Trans fluid change temp
- Conventional vs Synthetic in an older bike
- Just changes oil... only a quart came out??
- Oil filter housing
- Lucas or Castrol oil? any feedback? (96 and 103 Twin Cam engine)
- Don't run your head into a wall just yet...
- Digital dipstick, reset from degrees C to F?
- winter storage
- FLKTK oil light comes on at idle with 400 miles.
- Oil leaking 2013 sportster seventy-two....
- New oil available for the winter riding season...
- Oil Temperature High Now
- time for my first oil change?
- Engine Crankcase Vent Issue
- NOOB oil Dipstick Question
- Old Amsoil / Does Amsoil expire ??
- Trans and primary fluid
- I screwed up
- washable oil filter
- Oil Leak Issue
- High capacity oil pan
- Oil Problems
- High oil pressure
- What say yooz?
- oil funnel
- 60wt in the primary?
- Oil drainage 2004 heritage softail
- S&S Oil Filter With BelRay Dino
- Flushing oil tank?
- Metal Shavings On Primary Plug
- 2003 1200c
- Oil viscosity
- Amsoil 20/50 or Mobile 1 20/50 for the new 107 M8
- Initial Oil Change Question
- Oil coolers
- Oil dipstick plug blows out of tank
- Oil Leak From Air Filter
- Shovelhead primary oiler hose replacement
- Wrong viscosity..now what?
- Breakout oil temp gauge
- Mobil 1 15-50 vs Mobil 1 V-Twin 20-50
- Another Oil O Ring question
- WILL IT FIT - Oil Cooler Part# 62868-99B
- oil Pressure
- Fresh engine new oil how to marry the two
- Primary oil change
- Real 100% synthetic engine oil
- amsoil shock therapy 5w fork oil or penrite 5w synthetic
- Expensive oil in primary?
- 20-50 dino oil with "Superior Wet Clutch Protection"
- Been away from the game for a few years..Oil ?
- Major oil leak
- New Harley running way too hot
- Oil leaking from oil cap
- 2015 glide oil in air cleaner housing????
- Let the great oil debate begin.
- Red Line 20W60HD in Twin Cam 103"
- 79 shovel 80ci oil for fla summer
