- Valvoline VR1 20W50 Race Oil deals
- Mobil 1
- Shovelhead - oil blowing out of breather
- Royal Purple
- Best air compressor oil
- 86 Softail EVO
- Best oil for Jims 6 speed tranny..
- Oil filter wrench size
- Twin Cam oil change
- Mobil 1, V twin 1/2 price
- Mobil 15 w50 syn
- What Oil do you use?
- Oil Filter System - Shovelhead
- What is the best oils to run in my 2017 SGS
- Motorcycle oil vs regular oil
- Oil pressure light
- A fluid question for the forum.
- 2000 Heritage Oil Question
- Amsoil Filter and Oil
- Oil During the winter
- 2006 Softail Dipstick
- I’m now a Redline believer
- amsoil 15w60??
- Coupon for $5 off Mobil 1 Oil from Walmart
- Check the oil filter adapter
- WalMart V-Twin 20-50.
- Winter Storage
- does syn engine oil change oil pressure?
- Valvoline 4-Stroke ATV Oil in the Primary?
- can recommand this product for your Harley
- First full oil change on Dyna Lowrider
- Syn3 vs Lucas
- Trans and primary change intervals
- 103B Cooling and Neutral-rattle-killin'
- Tranny fluid migration
- Distance since service screen
- 75/140 vs.75/140
- Over heard a conversation?
- Amsoil
- Noisy valve train
- Mobil 1 break down
- HD 80-140 W gear oil for trans and primary
- Removed oil plug and only 34 oz. drained. What gives??
- oil compatibility question
- Amsoil 20W-50, API Service SG, JASO MA/MA2
- Stupid Question about Oil Cooler?
- Oil Pressure Gauge
- Oil Filter Relocation
- Reuse Oil Plug O-Ring or Not
- Valvoline full synthetic 20w50 motorcycle oil.
- Just tried Motul
- Mobil 1 20-50 V Twin oil
- Reusable oil filter
- Twin Power- Oil change in a box...
- Fxdx oil drain back
- Need major help!!! Oil pressure drop on acceleration
- Did I get the wrong stuff
- High oil consumption
- Lucas Oil additive
- Scavanged old oil,WOW
- Which oil ????
- Motul Oil for V-Twin
- 2001 Fatboy EFI Oil issue/s
- Castrol V-Twin Synthetic
- S&S eve oil pump, pumping problem
- 3 Hole Oil Change
- Miles between oil change?
- Oil Changes
- Out of place hose (possibly oil)
- Oil cooler lines
- How much oil to fill in at fxdwd 2010?
- Stretching an oil change
- oil blowing cap off at tank 89 fxr
- Gas in oil
- Jegs 20-50
- 08 xbones vs. 014 Slim primary oil related
- Adding T fitting before oil sensor?
- LCD Dipstick
- Slick
- Redline Synthetic
- Mobile 1
- Remote oil filter 06 FL
- Short or skinnier oil filters?
- Royal Purple 75-140 to Syn3
- First oil change on my 2008 heritage softail classic
- Oil Drain plug threaded hole.
- Just for the record, Mobil 1 really does...
- Primary: HD 80w-140 or Red Line 75W90
- Dealership using non-H-D Oil?
- Changing brands of oil
- 2009 FLHTCU (Ultra Classic) COLOR
- Anybody use this in their primary??????
- Amsoil
- Difference in dipstick level between warm and cold?
- Dex/merc in Primary
- OK! I give up.
- Sporster oil filter stuck.
- 96" Oil Consumption Questions
- Redline Tranny oil with Shockproof
- Oil leak 2008 softail
- Bubbles in oil
- Syn 3 Oil To Mobil 1 Oil?
- Cracked housing
- Canadian Tire
- Doing my first M8 oil change and have a few questions..
- Put in 2.5 quarts but only got 1 quart out?
- Castrol actevo
- Mixing gear oil in the transmission?
- Just need some reassurance
- Mobil 1 15W 50 On Sale
- Oil tanks
- Heavy Synthetic Gear Oil Transmission and primary chaincase lubricant
- S&S oil pump puking
- Oil gauge installation
- EVO oiling system?? Help!
- Street 750 Primary oil
- 91 FLHS Oil level
- Oil Plug.
- puking transmission oil
- 2000 Road king primary oil
- Mobil 1 Rebate Offer
- Mobil1 for Primary and Transmission
- Is this an oil leak or other fluid?
- A different oil filter test
- Castrol Oil
- 20w-50 three holes
- Jagg 750-1000 Oil Cooler
- Mobil 1 primary.......
- Two Different Mobil1 oils?
- Milwalkee 8 Pressure Switch
- Transmission to Promary fluid loss
- Oil light
- Shell Rotella T6 5W 40
- M1 v-twin 20-50
- Need some clarification . . .
- 07 fatboy
- Mobil 1 primary/gear
- Amsoil
- K&N filter
- Oil Warning Light
- New Screamin' Eagle Transmission Oil
- 2018 Breakout Dipstick Issue
- HO 103 Oil cooler capacity
- New owner oil questions
- What substitute for HD Formula+ for 2013 Sportster 1200
- Oil leak under engine
- Primary oil transferring to oil pan
- Amsoil 20W-40..
- Oil filter stuck, problem or issue.
- Recommendations for oil for all 3 holes
- Amsoil Transmission Fluid
- Service
- stick reading too much oil
- When did Syn 3 go full synthetic?
- Group I-V
- Optimum Oil Temperature
- have an oil leak
- Kendall 20W50
- No way this can be another oil thread???
- Amsoil with Barnett extra plate clutch
- oil cap blowing out since cam tensioner replacement
- oil
- Strange question regarding primary oil
- Disastrous oil change
- 2010 ultra classic with stage 4
- Mix Dexron III and Formula Plus
- Buell S3T '97 oil cap blew off and covered everything.
- Oil pump questions
- A weird one involving an oil change
- install a pc racing stainless oil filter and my oil presser went up to 22 lbs at idle
- Jagg oil cooler fan control switch question
- Jagg oil cooler with fan
- Maxima V twin
- Cooler Weather
- 2000 FXST Oil
- oil leak and what are these bolts
- Yet Another Oil Change Question
- Oil cooler on 2018 a FLHC 107cc
- Castrol Edge 10w 40?
- Good Price Valvoline VR1 20W50
- when to change the primary oil?
- Automotive sandwich plate?
- First few ounces
- Suggestion for alleviation - `10 FLHTCUSE5 losing oil on right side
- Crankcase breather too much oil
- Motul 7100 for my Street 750?
- 20-60 Redline in Canada
- NO OIL UP TOP BUT,.. have oil pressure
- syn 3 and engine noise
- oil filter
- Mixing oil
- 2005 Harley FLHTI Primary Oil
- Quicksilver Synthetic 20w50 Motorcycle Oil
- Oil lines routing 1990 heritage
- Shovelhead nosecone oiling question
- Watch and listen to this HD technician
- oil lines
- engine oil usage
- Not an oil thread, but..
- Need some simple advise for transmission/primary gear oil
- SAE 50 or SAE 60 Weight Oil
- P0522 trouble code on my M8
- Another Oil Thread....Don't Kill Me
- Is 75W-140 to heavy
- Amsoil sae 60 w
- Oil Brand
- Redline 20W-50 in Transmission?
- == ANOTHER Oil Post - Mobil 1 V Twin ==
- Stick with Royal Purple?
- oil choice
- Amsoil 20w-50 vs. Amsoil 20w-50 V-twin "motorcycle oil"
- Oil level check on a tank with no dipstick?
- Oil Line ROUTING for a 1995 EVO DYNA - my REPAIR Manual does NOT address the Oil Line ROUTING & the DYNA is different enough with the Oil Pan under the Transmission that I want to get it PLUMBED correctly
- Oetiker clamps on oil cooler lines at the filter adapter?
- Yes another lousy oil thread
- oil light
- Castro Edge 10w-60 in 2012 Sportster?
- bike broke down on highway leaking oil and wont start
- Oil overflow
- Transmission Oil issue, please help!
- ATF in transmission?
- 18 fat boy 114
- First Oil Change
- oil leaking badly
- Oil blowing out of hose beneath my shovelhead
- Bike has been sitting for 2 years. New oil and gas?
- Oil Change Problems, Confusion and Frustration
- Oil warning light
- Built Road King
- Engine oil for sportster
- Sportster trans/primary & Mobil 1 75W90
- What Brand 10W-40 for Winter?
- First oil change clarification
- Freshly rebuilt n bored 2000 softail deuce (FLXSTD) bubbles in oil
- 2002 dyna bottom of primary leaking
- oil ID
- Switching oils have question as new build
- lucas 5w30 synthetic in my dyna harley davidson 1450 wide clide
- crank case pressure
- 2009 Night Train oil leak, Help
- Replacement oil cooler thermostat
- what type of transmission oil ?
- What the hell did I just drain????
- A warning about K&N oil fiters
- Schaeffer’s vs Mobil 1 and Bel Ray ?
- Mixing oil weights
- Redline product Question...
- Oil Temp Gauge
- Is my oil overfilled?
- Original oils used in 2003 FLSTF
