PDA
View Full Version : Oil Archive (no new posts)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17 18 19 20
  1. oil filter 2008 heritage question
  2. Changing Oil with a MityVac
  3. '03 Deuce, noisy primary
  4. oil blowing out dipstick
  5. What about Red Line?
  6. Need yalls thoughts......
  7. 2003 FXR Dyna blowing its dipstick
  8. Where can I get Mobil 1 vtwin in Montreal?
  9. 87 evo loses oil pressure after 5 minutes
  10. The first 4 seconds
  11. Does everyone really use a torque wrench?
  12. 07 Twin Cam Noisy Transmission
  13. Has anyone tried the Filtration System
  14. Amsoil AHR 60weight rating changes??
  15. HD premium oil cooler
  16. Fram oil filters on Ebay- this guy is whacked...
  17. oil additives
  18. Need help.
  19. UOA's
  20. oil level on 06 Dyna
  21. 5 Quart Oil Change
  22. Shell Rotella oil
  23. how much oil goes in the Primary ?
  24. Different oil=high H{ and Torque
  25. Royal Purple ?
  26. My new Oil purchase
  27. I'm Back to HD Oil, dino
  28. Oil Droplets leaking out
  29. sporty oil filter question?
  30. SCAVENGE OIL CHANGE
  31. Castrol 5-50 syn
  32. No change in Temp!! by changing oils
  33. popping when cold
  34. Mobil 1 V-TWIN oil change
  35. Trouble with oil change today
  36. Oil changes and metal shavings...
  37. Magnetic oil filter?
  38. Oil Change
  39. Great Source For Oil Info
  40. Must Use HD Oil - Dealer
  41. Royal Purple
  42. Just fyi
  43. Time vs Milage for Oil Change
  44. seafoam in the crank case
  45. MOBILE ONE
  46. Amsoil White Sheet
  47. REDLINE customer service.....
  48. Changing oil help. Need fluid levels please.
  49. S&S Reed Valve problem on Evo
  50. Changing to synthetic ,I GOT ?
  51. SYN3 Question... This isn't if I should use or not
  52. 1000 mile oil change tomorrow
  53. 20K Miles on Redline Oil
  54. Base oil leak
  55. Non-Aersol Cable Lube?
  56. DINO to t he RESCUE
  57. HD Primary
  58. oil plug thread question - stripped vs. oring compression?
  59. Oil Temp question
  60. Oil pump upgrade
  61. Oil level was REALLY full-observation
  62. oil pressure problems
  63. 07 Sporty trans oil question?
  64. Cost of Amzoil
  65. oil cheap insurance
  66. low oil level
  67. low oil level
  68. oil consumption
  69. Oil Pressure Issues
  70. mobil 1 v twin now valve noise
  71. Need a new "Pusher"
  72. Went M1, M1 & Formula+ today.
  73. checking fluid levels
  74. Type of oil and engine cooling
  75. redline
  76. Who does 2500 mile oil change???
  77. oil screen for 07
  78. Using RevTech 20w50 now. Non-synth alternaitves??
  79. fill the oil filter before installing
  80. HD Syn mileage between changes
  81. Valvoline SynPower 20W-50
  82. Redline Heavy Shockproof versus?
  83. Crankcase breather
  84. Oil leaking from Air cleaner
  85. Primary plug
  86. Switching to synthetic
  87. Royal Purple
  88. Clutch fried w/syn car oil in primary
  89. Redline V-Twin Primary Case Oil
  90. Transmission Oil Plug
  91. oil leak, TC 88
  92. Oil Cooler - Detonation (pinging)
  93. Long Black Oil Filter
  94. Do I have to worry about engine damage???
  95. Comments on UOA thread above
  96. primary oil going into motor
  97. Oil temp vs head temp
  98. Bike only Took 2 and 7/8 quarts Motor Oil
  99. Help understanding my oil analysis with Mobil 1..
  100. First time changing all fluids need some advice
  101. Cannot find mobil 1
  102. Electraglide 2002 on Dipstick reading
  103. Castrol oil
  104. O ring said Oh when it squished out from under plug
  105. Oil Additives
  106. Messy Oil Filter Change
  107. HD Formula+ Trans Weight?
  108. Changing oil in my shovel...
  109. '99 Dyna Lowrider oil change..?
  110. checking oil level when cold
  111. mobil 1 ????
  112. Messy oil filter removal
  113. Syn in my new Shovelhead?
  114. Interesting tidbit on Oil Filters...
  115. Switching oils
  116. OIL COOLER LABOR COST
  117. Can the cam support plate be removed without the cams?
  118. AMSOIL??
  119. AVIATION OIL IN HD?
  120. Fork oil
  121. Mobil 1 Gear Oil
  122. Amsoil and Mobil cost ?
  123. fram oil filters
  124. Help, Can I use Auto oil in my HD?
  125. Tranny Lube change - how many miles/time interval??
  126. Oil pressure drops on acceleration
  127. Is Mobil1 compatable with HD360
  128. Switching to synthetic on a high mileage bike?
  129. Too Much Oil In 07 Ultra Crankcase - Consequences??
  130. Cam shaft bearings - not!
  131. V Twin Redline Tranny Oil
  132. Oil quantity
  133. RedLine Heavy Shock Proof
  134. When can I get a Baisley oil pressure relief spring?
  135. Spectro oil?
  136. How much more oil with a Billet cooler installed?
  137. oil blow by
  138. Oil indicator warning light is still flickering when in idle...
  139. car oil filters, pressure IS too low
  140. Newbie - How to check oil?
  141. Oil from factory syn or Fossil?
  142. Oil change
  143. True or False?????
  144. Doing first oil change on a motorcycle, not sure what oil to get
  145. Mobil I Syn Gear oil 75w-140 question
  146. Oil Filter
  147. Used Oil Analyses Thread ...
  148. Used Oil Analyses (UOA)
  149. Synthetics
  150. Mineral Vs Synthetic
  151. New guy question
  152. Another oil pressure question!!!
  153. Realistic Oil Capacities
  154. Billet vs Finned
  155. INTERESTING ARTICLE
  156. Dipstick Blew Out?!
  157. Amsoil service intervals?
  158. Oil question for 68 xlch
  159. Whats the real buzz?
  160. HD oil cooler gasket
  161. oil change with jagg oil cooler?
  162. Need Amsoil severe gear in Iowa fast!
  163. 2500 vs 5000
  164. oil system pressurising
  165. Canadian Supplier 4 Redline?
  166. oil not circulating & rustywater came out of oil bag
  167. Oh no, more opinions on motor oil.
  168. OIL FILTER recommendation... Anyone?
  169. Amsoil 20w50 in all 3 holes??
  170. Oil Temps?
  171. How stupid on oil change
  172. Red Line change
  173. Can you swap Syn oils?
  174. newb would like to thank all
  175. draining the sump
  176. Formula Plus....What is it?
  177. 1990 ElectraGlide fork oil change?
  178. VRod oil brand and weight
  179. Too much Oil!
  180. Synthetic Oil in a New Road King 2007
  181. what happened to Mobil V-twin oil prices?
  182. Valvoline
  183. Oil change on 01 FXSTD
  184. Pro 1 Oil Coolers
  185. oil change
  186. Relocating oil filter
  187. fuel in oil
  188. bel ray exp semi synthetic
  189. Oil Leak
  190. Harley Brand Wheel Bearing Grease
  191. Just thought I would share...
  192. Dino oil in a 96ci
  193. Oil filter change messy--problem solved
  194. synthetic then vibration
  195. Oil Problem
  196. Any side effects if mixing oils??
  197. Help! I think I ran bad oil in my bike for too long
  198. Can I use cars engine oil for my ride?
  199. New 07' Deluxe, wait after breakin period?
  200. question about mobil 1vtwin synthetic oil
  201. What the dealer said about Mobil 1....
  202. Oil Temps
  203. Mobil 1 in SW Houston ?
  204. Oil use on 05 Softail
  205. Need Help...Please Confirm Correct Red Line Part Numbers
  206. 20w-50 in Primary?
  207. flt tourglide oil drain line location?
  208. oil blowing out breather
  209. full 3 hole fluid change & 5K service???
  210. Klotz Oils
  211. Faint Oil Smell
  212. Dallas area - Where to buy Redline Oil?
  213. ok, I chickened-out..Redline Heavy Shockproof in Tranny
  214. leaking oil everywhere on start up...help!!!
  215. Oil Temp Gauge and Pressure Gauge
  216. My test of Mobil 1 vs Amsoil
  217. oil filter part number
  218. 2500 vs. 5000 mile
  219. Oil Question from newb for all three holes
  220. Oil Change Overfill
  221. SYN 3
  222. inch pounds to foot pounds?
  223. would'nt you think,,
  224. Used Oil Analysis
  225. Ness Oil PRessure Gauge on '94 FLSTN
  226. Recomendations for OIL for U.K. market
  227. Chrome vs Black Oil Filter
  228. What oil for older TC88?
  229. Product ENGINE RESTORE in a V Twin?
  230. Auto Oil and Filters - again. An oil cos view
  231. I'd like to switch to redline
  232. Spectro Primary Oil Where to Buy?
  233. Dealer screw-up
  234. oil pressure?????
  235. Amsoil Torque Drive for primary
  236. Amsoil in the Temecula/Murrieta CA area
  237. Mobil One V-Twin to Redline oil?
  238. 5000 mile service
  239. Fueling super oil pump vs stock pump
  240. Oil Filters
  241. 1st oild change help needed
  242. amsoil 80w-90 gear lube
  243. waRRANTY
  244. 1st service
  245. Leak around the oil plug
  246. Amsoil Excellent customer service
  247. Oil
  248. springer neck bearings
  249. Noise & Engine oil capicity w/out filter change - Amount?
  250. amsoil 60 tw race oil
