- Oil filter stuck.
- Oil filter stuck
- The skinny on oil.
- Is Amsoil PAO?
- Billions and billions of bubbles.
- Need Help: RevTech 6 Speed Trans Oil Drain Plug Location
- Which WIX oil filter #?
- Is my Jagg cooler thermostat working?
- Shared Oil Pan? Dyna 96
- Oil light
- LEAKING! After first service...
- Oil leak on new HD?
- oil pressure gauge in FLHTC
- And now some oil-related comic relief...
- Tedd Cycle Motor Shop Oil
- Synthetic Diesel Oils?
- sportster oil pump cavitation
- Redline trans fluid:
- Anyone every use this stuff?
- oil problems
- 1000 mile check up question
- Walmart Mobile 1 15-50 and the 3 Holes
- Low Oil Level at Oil Change ***Dyna LR 2008***
- What is this that came out of my Transmission?
- ATF in primary - B&M vs ATF+4
- Primary oil capacity...wet or dry?
- Burning oil smell when engine is hot sitting at light?
- How dirty should primary oil be?
- RedLine Products
- 6 speed trans oil weight??
- Synthetic from the factory?
- Tranny oil from factory?!
- Different Bike, Same Size Motor, Changing Oils?
- Primary Oil
- oil filter stuck on sportster
- Permanent Oil Filter users, stand and be counted
- oil blow by vented to oil pump
- Another how do i remove this oil filter thread.
- Fork Oil Recommendations
- Mobiltrans HD 30
- 99 sportster 1200 primary fluid question
- 2012 Nightster with only 300 miles 1st oil change
- Amsoil at a decent price?
- oil pressure
- OIL LINE.. Your thoughts on the best grade of hose?
- Hot climate oil question
- 2016 Softail Slim oil leak?
- what is this???
- Getting most of the oil out of the engine... making your own scavenger puck
- Redline vs and oil for primary which one is best
- FLHR vs FLHP
- Do you use oil in you bike
- Mobil Delvac Super 1300 in Harley Davidson
- Redline 5w50 Early Results...It works!
- Draining oil cooler when changing oil
- This finally puts to rest all the millions of "what kind of oil" questions
- Oil Drain Plug O-Ring Size
- Will Using Mobil 1 Oil Void New Bike Warranty?
- Mixing types of synthetic 20w-50...ok or not?
- Mobil v-twin 20-50 for everything??
- Cleaning Drain Plug
- another dumb winter question
- Going to a 5W-40 in the winter
- Possible change to synthetic oil question..
- Loctite Pipe Sealant
- Removing a wrong hex nut for oil drain (Engine Oil Change)
- Spectro Oil
- 1997 wrong oil filter loud knocking noise
- Oil seepage on the crankcase.
- Basic Oil Change Question......
- Oil pressure relief valve sticking
- Houston we have a problem ~ oil leak
- Trans question
- amsoil primary a few oz. short
- Amsoil engine, trans, primary fluids?
- Oil Filter Differences & Ident
- Valvoline Synthetic MC oil
- oil circulation
- Lucas synthetic 50wt
- Oil spitting out of my air filter
- Oil transferring into primary - Twin Cam
- Water in chaincase oil.
- ATF Fluid in primary of 2011 street glide
- Is this the right redline stuff
- k&n
- What is high oil pressure?
- Oil pressure and rough ride
- Oil Turns Black in Color
- Oil cleanout after cam bearing lunched
- 86 softail is leaking oil
- Small leak 10 ultra
- Checking oil
- Fumoto oil drain valve for H-D
- Primeary Woos
- volar filter
- Getting all the oil out !!!
- Crankcase Oil Temp
- Primary capacity
- yup .. oil coolers all over again
- Stage 4 kit
- HD Syn3 Recommendation
- 1980 flt side cover to oil neck grommet
- oil leaking from hose on back of motor.
- Why is M1 20W-50 so much better the M1 15W-50
- Oil Pump
- Installed oil cooler
- Excessive Lead and Copper in 88 oil report
- Leaky Road King
- Baisley spring LMR-002
- Drop Dead Oil Temp??
- Opposite of Normal - Synthetic Improved Valve Noise
- Tech help. Belray 75w GS in a '13 Sporty.
- Torque Specs on Oil plug?
- after long run, leak trans. cover
- Myth or Reality: Don't mix different brands of oil?
- Big mistake -- oil change --
- Oil Level after 1K service
- 2014 Ultra Limited Oil Pressure
- what weight fork oil do i need t put in a 91 tour glide?
- Oil leak when bike sits over winter
- Oil Level Debate
- Base gasket problem
- Shoulld I drain the Crankcase ?
- Primary drive filling with engine oil.
- FXR oil tank
- anyone try using the new amsoil primary and tranny fluids
- Revtech 125" oil change
- 88 Softail
- Need to add ZDDP additive ? 89 FLH
- Oh no!!! Another oil question...
- a little oil out of exhaust gasket after oil change
- Oil pressure guage fitting broke
- Special filter for synthetic oil ?
- Oil leak - need a degreaser recomendation
- Harley Oil or Amsoil
- Oil Circulating Issues
- What part uses what oil?
- hello new to the forum, evo oil pump drive shaft
- '15 RGS oil pressure
- No Valvoline VR1 in my bike
- Scheafer's Oil
- using oil
- Oil flow help
- 2003 Road King Leaky Tranny
- 1996 dyna oil plug
- Old rider beginning again, hello all
- if it says OIL in the title, you're already mad at me
- Mobil 1 V Twin on sale @ Auto Zone (3/23/15)
- what brand of oils would you choose for your store?
- Oil Plug O-Ring
- oil pressure gauge leak?
- tc88a scavenging/return oil
- Kicks stand or straight up
- Looks like I can stay with Amsoil in the other two
- 95 nostalgia oils?
- What's the word on Spectro 6 Speed?
- Oil question
- Need help or ideas
- Synthetic VS. Regular WARNING: Absolute Newbie
- 79 Ironhead Oil Line Hookup Help
- 88 Twin Cam oil cooler design question?
- amsoil syn vs screamin eagle syn motor oil
- Lucas Primary Chaincase Oil - good or bad
- No oil pressure, recent gear drive cams install
- 2011 Fat Boy Fork Oil Capacity?
- Does Punching Oil Filter Damage the Mount Threads?
- oil pum issues
- oil pressure
- newbie oil question
- Best break-in oil
- H-D steering head grease?
- Iron 883 oil leak.
- DIY Oil Scavenger Puck (under $15)
- clogged oil filter
- Messed up
- Blow by- a syn or dyno issue
- valvoline vr1 20/50 dino
- What oil is factory fill in a 2014 103B?
- Quicksilver Oil
- 2000 Sportster 1200 oil oil oil
- 25w60 oil. ..question
- UOA - Used oil analysis
- O-rings for oil plugs and primary cover gaskets
- oil everywhere!!@
- I got soaked in engine oil!!
- Oil coming from air filter
- Bike Sat, Now burning oil
- Oil change before or after winter storage?
- oil pouring out of a/cleaner
- Syn 3 to Dino
- Going back to Dino
- Fxlr oil feed.
- Oil filter question.
- going back?
- Lucas
- Grease gun
- 2014 softail slim oil temp 300
- Oil Change Question
- Primary Chaincase service level.
- 1983 sporster primary
- Oil Press. Gauge
- Scavenger TOTAL Oil Change System
- Dino oil
- $5.99 oil filter wrench
- Oil temp test complete
- Frame mounted Oil Cooler Orientation?
- Mobil 1 15W50
- foamy oil
- Oil breather for Arlen Ness Big Sucker
- Need Help 03 RKC oil pan
- Oil classification vs. catalyst
- Oil vs trans and primary lube/ warranty!!!
- Valvoline VR1 synthetic 4-stroke?
- Xado ??
- mobil 1 Gear Oil
- Primary fill
- Same oil for crankcase and transmission?
- Lucas 20w50 Full Synthetic and 75w140 Full Synthetic Review
- Where the do I attach this oil line
- Change to full synthetic oil
- Oil Pressure
- Oil filter too tight
- Done! Oil temp is installed
- Oil temp install '07 Ultra
- 95 CI question
- Bel-Ray 80/90 gear saver hypoid gear oil VS Redline 80w gear oil with shock proof
- Oil Cooler Identification
- lifetime oil changes at dealer?
- 1000 mile service
- 2008 Crossbones
- oil pressure
- Amsoil Super Shift 10w in Primary?
- Oil dip stick blow out at low rpm
- help with oil leak.
- Please help oil leak and can not figure out where it is from
- Mixing primary oil with Engine oil
- Oil Coolers
- When to change oil?
- Question on changing the oil in the Primary?
- Which Oil to use?
- Help
- Preference?
- Best reg oil
- standard oil
- Best standard oils
- Best standard oil
- Gear oil in trans
- Install issue: HD softail oil cooler
- Interesting information. Dont shoot the messenger.
- Oil coolers and filters
