PDA
View Full Version : Oil Archive (no new posts)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 [19] 20
  1. More oil confussion
  2. Harley Oil Cooler
  3. Mobil 1 V-Twin
  4. First oil change
  5. The "White Paper"
  6. Transmission Lube API GL rating
  7. CHROME OIL FILTER
  8. TC88 OIL, TRANSMISSION, & PRIMARY CHANGE
  9. Skip and Bill
  10. Oil Drain Plugs (Pics)
  11. Increased engine noise
  12. Help!! Oil Drain Plug
  13. 2000 sporty
  14. What oil to use?
  15. Scavenge
  16. Comments about Rev Tech Pure
  17. When to change to synthetic
  18. Normal oil temp?
  19. Oil line Leak
  20. oil line routing
  21. oil line routing on evo
  22. Switching to Synthetic......Any Leaks?
  23. Change Between Brands of Lubes
  24. Oil cobwebs
  25. oil
  26. Just a little more synthetic
  27. Oil, Oil everywhere!
  28. Old Type Primary Oil Available
  29. Schaeffer Lubricants
  30. Castrol V-Twin??
  31. Redline 20W60 HD VTwin oil
  32. Dumped Syn3 out of my trans.
  33. Oil cooler removal help
  34. oil leak
  35. Oil Changes
  36. from shovel to evo
  37. Royal purple motorcycle oil
  38. how much do you pay for a quart of mobil 1 v-twin?
  39. Is synthetic oil louder?
  40. H-D SuperPremium 10 or 5 micron Oil Filters
  41. complete oil change
  42. changing from dino to synthetic
  43. Mobil1 Gear 70-140
  44. Where to buy 20/50 Mobile 1 syn oil in Canada
  45. What Brand Oil Filter Do You Use
  46. How good is HD Formula+ ?
  47. Oil Capacities
  48. 05 Road King Oil Question
  49. Mobile 1 Vtwin 20-50W--Stealer "fear of God"
  50. How hot is too hot?
  51. oil blowin out crankbreather on back of aircleaner
  52. Mobile1 Vtwin vs HD syn3??
  53. How much oil in a Fatboy?
  54. Tranny clunk after switching to Amsoil 10w-40
  55. oil plug blewout across the garage!
  56. Synthetic Gasoline
  57. 2205 XL1200R Oil Loss - Anyone Else?
  58. Softail Standard Oil Tank Removal
  59. Synthetics and break in ?
  60. is good to put.....
  61. Total Oil Change
  62. Total Oil Change (softail)
  63. Thanks
  64. Amsoil
  65. Oil cooler and exhaust question
  66. Oil Filter Wrench
  67. Question for the SMART guys!
  68. motorcycle quick lube
  69. HD Formula+
  70. STP
  71. Mobile 1
  72. Syn3...Again
  73. Mobil 1 or HD while under warranty
  74. Is mobil 1 v-twin oil a synthetic?
  75. Where can you buy Mobil 1 v-twin oil?
  76. Thread Sealant
  77. Motul Oil
  78. Lockheart Oil Coolers - What happened?
  79. STP Oil Filter?
  80. Making THE switch
  81. warranty
  82. Synthetic Oil Analysis
  83. running a single tube for breathers
  84. Time for 1k service
  85. White sludge update
  86. White sludge
  87. Fluid Changes for a Newbie
  88. Question about oil usage
  89. old sportster oil pump question
  90. Oil Changes
  91. Photos on a 5 qt oil change?
  92. Changing your oil
  93. Ok....decision made!
  94. Suitable oil for tranny...
  95. HD Oil TEMP Gauge Installation TIP
  96. Harley Oil Temp Gauge Installation
  97. 72 FLH puking oil at startup
  98. Is 75-140 Oil OK For Tranny?
  99. Synthetic Oil On Breakin From The Factory
  100. A question of temperatures
  101. question / aqain
  102. Mobil 1 or HD primary oil
  103. small oil seep from front cylinder
  104. Oil Breakdown At Temps
  105. Keeping it warm in the winter
  106. Redline not covered under warranty???
  107. Where To Find Redline shockproof?
  108. My .02 cents
  109. Where to get Mobile 1 V-twin?
  110. Mobil 1 V-twin in Phoenix, Arizona
  111. Slightly elevated copper, lead, & tin on SE103 using Syn3
  112. SYN3 Service Intervals Extended??
  113. Cold Check Scale Dipstick
  114. Pipe Plugs What For?
  115. Oil spitting question
  116. Oil Temperate Guage Questions
  117. Oil Change at 250 Miles?
  118. Easy way to get your oil
  119. Who's Oil Filter???
  120. Drained the Crankcase
  121. winter storage fluid changes
  122. Answers for what oil, you may be suprised
  123. Oil bleed through
  124. Transmission oil smell
  125. Trans & chain oil difference question??
  126. What do I do if I only have two holes?
  127. Synthetic or regular motor oil ?
  128. Oil Pressure & Oil Temp Gauges - Are They Needed?
  129. Synthetics not doing the job?
  130. Sources For Harley Oils
  131. Syn3 in the transmission
  132. Bel-ray oil for v-twins
  133. Electronic Oil Dipstick
  134. High Temp Grease
  135. Oil for primary
  136. Primary Fluid?
  137. Oil Temperature
  138. Oil Cooler Fans Anyone
  139. My Oily Air Cleaner is Fixed FINALLY
  140. END TO OIL CARRY OVER INTO BREATHER
  141. Oil Basics, Part 2
  142. Oil Basics, Part 1
  143. Bel Ray Tans oil and Red Line Opinions
  144. Oil relief valve stuck?
  145. Twin Cam Oil Pressure Issues
  146. Oil leak
  147. All About Oil
  148. "3 Quart" Heritage
  149. Oil leaking from filter
  150. Strange Oil Leak Fix
  151. V-Twin Or SYN 3 In The Primary?
  152. Oil filter install question.
  153. More oil questions
  154. 1987 FXSTC - Oil Spray
  155. Flushing the engine....
  156. Valvoline Syn 75/90 Gear Lube
  157. Switching to mobile 1 vtwin syn?
  158. Oil comming out of my sporty`s oil tank vent hose
  159. Now listen to what the dealer is saying
  160. Oil problems
  161. oil additives?
  162. oil press. issues continued.
  163. FATBOY oil change?
  164. oil pressure issues
  165. Oil change for winter?
  166. Primary oil in 2000 XL1200
  167. 2000 XL1200C Oil problems. . . . . . . . .
  168. Tired of Panty liners
  169. sportster trans oil
  170. Cool Fins for Oil Filter
  171. RED LINE OIL
  172. oil line routing
  173. Why so down on HD Syn3?
  174. Need help about Synthetic Oil in 1996 Sportster
  175. EFI Idle with AMSOIL
  176. Mobil 1 V-Twin Syn ?
  177. 05 SuperGlide: Which lubes in which holes?
  178. Oil leak
  179. Tappet filter/screen.
  180. Is Harley discontinuing dino for tran and primary?
  181. oil catch cans
  182. Blowing oil out air filter
  183. UK spec oil
  184. What about Royal Purple?
  185. HD Factory Warranty vs. Non HD Oils
  186. Oil Cooler Install on Road Kings *
  187. mobile vtwin 20 /50
  188. What oil should I use?
  189. oil crossover into the primary
  190. 2004 Softail FXST--Changing engine dino to Synthetic
  191. Recall Code 0109 - Touring Models Oil cooler kit
  192. service
  193. Emergency Oil Filter wrench
  194. Primary capacity ?
  195. Making the switch to Mobil 1
  196. 5 Micron New HD filter causing excess foam
  197. Oil Comparison Information
  198. Mobil V-Twin vs Gold Cap
  199. Should I install an Oil Cooler?
  200. New Oil Filter?
  201. Oil Pump Check Valve Repair
  202. Moblie 1 in transmisson
  203. my options
  204. The Real Scoop On OIL (From Skip)
  205. Ot to switch?
  206. Oil Filters
  207. MILITEC-!
  208. Help! No oil pressure.
  209. Mobil 1 V-Twin Where To buy From ?
  210. Synthetic Question
  211. Bad Synthetic Experience
  212. Oil Facts or Fiction?
  213. MOVED: Engine light?
  214. Oil Filter Cross Reference
  215. Mobil One change
  216. primary oil going into engine oil
  217. Blowing out the dipstick
  218. Installation of Oil Temp Gauge (Wally Worlds Version)
  219. unable to fully drain oil
  220. New oil change frequency
  221. Massive oil from breathers
  222. lubrication question
  223. 05-06 Oil Usage Information
  224. What's up with HD chrome oil filters?
  225. HD Oil Cooler questions?
  226. Latest oil change ...
  227. Service Bulletin from HD on oils
  228. Oil Question
  229. Oil in air filter
  230. Gear Oil question
  231. What Primary Oil is your Choice
  232. Question on swapping from Syn3 to other..
  233. What TRANS oil do you use?
  234. What Brand Engine Oil do you use in your bike
  235. No synthetic in '05 Sportster?
  236. primary oil?
  237. 205 F Temp reading on oil dipstick
  238. 03 softail fluids.
  239. metal in tranny oil
  240. PTFE and Harleys
  241. gear oil
  242. Redline Shockproof Heavy
  243. Missing oil update
  244. Checking level
  245. Oil - How much?
  246. installing oil cooler
  247. when to change the oil
  248. Engine Cooling & Lubrication
  249. can the PureOne or Mobile-1 be used on HD
  250. STEALER MESSED UP MAYBE
