- Changing oil
- HELP.>Blowback probs
- Anyone live in CT, and know where I can find Mobil 1 V-Twin?
- Softail Premium Oil Cooler Kit.....
- how good is revtech transmission SAE80W90
- 07 Roadking oil leak
- lucas oil
- Need Help with Oil Gauge !!!
- Help, Oil coming from somewhere?
- help with Amsoil
- Oil Drain Plug(s)??
- 07 Road King Classic oil and ....
- Removing SYN3
- Mobil 1 gear lube question
- 1st Service HELP! 2006 Deluxe
- Redline Oil 20-50 *NEW*
- Softail Oil Line Section
- Oil line configuration help
- Oil pressure pegging 60
- Oil pressure sensor wire
- OIL/BREATHER
- hd sport tran fluid
- primary,tranny one of the same?
- Syn 3 any good?
- HD Oil Temp Gauge Install - Power Pick-up Point
- first bike first self do oil change
- HD Formula +
- mobil 1 fyll syn 75/90 in primary???
- Oil Capacity for 2007 Electra Glide Classic
- Removing oil cooler
- Which oil pressure gauge ??
- How much for Mobile 1 20W-50
- Redline 20/60 Motor oil
- oil cooler fans
- Amsoil Purchase
- Dealer says Amsoil in all 3
- 2005 XL883L & SYNTHETIC OIL
- Pure power filters?
- Viscosity of H-D trans fluid
- White oily stuff out of my crankcase breather
- Rotella 15-40 in Harley engines
- HD cooler, need patience
- Lucas additives
- Why no friction modifiers?
- GONE - RedLine oil in Detroit MI
- What do dealers charge for oil changes?
- Amsoil SAE 60 AHR in Engine
- CRANK CASE FULL OF OIL NOT RETURNING TO OIL PAN
- Syth-3
- SVG 75w-90 vs SVO 75w-140 Amsoil
- Best place to buy AMSOIL
- 2002 Heritage Oil on oil tank etc.
- oil change question.
- Primary Oil Level Question
- Can anyone tell me how hydrolic lifters work?
- Can oil get sucked from Primary to engine?
- 1000 mile service
- oil pressure guages
- Non-H-D Oil Filters
- Oil filler cap blew out.
- HD 20w50 in Primary
- Cheap do it yourself oil extractor pump
- Transmission and Primary Fluids?
- Amsoil 75w110 gear oil....NEW!
- Mobile 1 75/90
- Oil pressure good, oil light comes on
- How Much ?
- Mileage and syn oils
- Havoline 20w50 closeout sale
- Revtech oil
- How many of you use some sort of scavenger system changing your oil?
- amsoil
- Redline Gear Lube?
- LUCAS SYNTHETIC MOTORCYCLE OIL
- Amsoil sure looks dirty!!
- Off the shelf (M-1) or mail order (Amsoil)
- oil temp gauge on twin cam
- problem switching from redline to royal purple
- reusable oil filters
- Where can I get Mobil 1 V-Twin?
- Mixing Oil
- HD fluids
- HD Oil Temp Gauge Install Question
- Duralube in engine?
- Priming the Oil Pump?
- foamy oil?
- Feuling super pump
- need help
- where to buy oil
- Mobil 1 V-Twin in all three holes = more noise?
- oil usage
- Advance Auto Parts No More Mobil 1 V-Twin
- Thread size?
- Harley Approved Oil?
- formula plus
- oil pump
- 07 6 speed dyana trans oil
- 07 FXDL oil question
- White milky around oil filler plug
- heard something interesting from a royal purple guy
- oil pressure
- Oil Cooler Results
- oil out the exhaust port.
- HD Oil Cooler Install Question
- 2006 FatBoy leak
- Doing "my" first oil change on the Road Glide
- Need advice?
- Castrol GPS Syn
- Puking Oil
- Puking Oil
- Syn 3 in the tranny? Not for me
- Fueling Tappets
- O7 Sportster 2 or 3 holes
- synthetic or not
- EG std and the newer guage kit
- Newbie: DIY Sportster Oil Change
- Lockhart 600 Series Oil Cooler
- Best oil cooler?,..
- 07 sportster oil leak!!!
- Another "when to go Syn" Question
- mixing synthetics
- oil question
- Losing Oil
- H-D Oil Temp Gage Install
- tranny change
- First DIY oil change
- 20w50 mobil1 syn for v-twins
- LCD Dipstick select F or C
- to cool or not to cool?
- Oil Coolers & Pinging
- Oil not draining
- temp dial reads low
- Mobile 1 Not Synthetic?
- Oil Light Flicker
- When to winterizie?
- Consistancy of brand
- HD Formula +
- Why 2500?
- Redline is the.....
- Getting rid of old oil
- 500 mi oil change, Help requested
- shovelhead oil pressure
- Need so tranny oil advise.
- transmission oil question
- For Softail Owners -- Do You Scavenge w/ Oil Changes
- Oil and Filter Change Intervals
- Amsoil in Primary?
- New bike oil questions...
- Oil Misting
- leaking braded oil lines
- 250 Degree oil temp!
- '07 oil question
- oil question
- OIL PRESSURE GAUGE
- Bad '05 Valve Seals
- How many oils? Primary/Engine..what is the third?
- Any one use (Spectro Oil )
- Oil filter cutter
- Clean way of changing oil
- Overfilling oil
- fogging oil
- Engine oil leaking into Primary chain case
- synthetic oil
- any comments about reed valve oil relief
- straight up and check?
- L.E.D. Lights
- H. D. Oil Filter and oil
- Winter storage engine oil
- Tranny Oil/Engine Oil Question for older Evos
- Where do you order oil from?
- Lucas oil
- New Oil Filter
- anyone use the bad boy supercooler from motorcycle innovations?
- tappet screen screw.
- how much
- how and when do you change the oil
- Sportster Oil Leak
- "the cure" or Doherty breather valves
- Wrench Size ?
- Bearing SKATE????
- Winter Storage Lube Change
- Leak at oil pressure sensor
- oil gauge/oil light
- Question about oil pressure
- oil leak?
- Missed Maintenance
- redline
- The dreaded oil leak
- How long between ???
- Is an oil cooler worth the $
- oil cooler question
- Oil Use
- Cut filter apart today
- oil filter
- lucas oil stabilizer
- Primary Oil Change
- Oil pressure
- Mobile 1 ATF
- Oil Temp and Level Gauge
- Noisy Mobil 1?
- SE Sync3 and colder weather
- how often to change oils
- A little help on location of drain plugs
- Mobil 1 and Redline going in today.
- 1000 miles service question
- Want to install oil pressure gage...
- Formula+, Mobil 1, Redline
- 06 Dyna Trans Fluid - Redline Shockproof?
- burning oil
- Help With 1000 Mile Service
- Silly Question
- Oil coolers on Evos or not
- Amsoil in high mileage bike?
- Mobil V-Twin, Atlanta
- URGENT -- Oil Amount (Actual) for Softails
- Drag specialties primary oil.
- winter storage and synthetic oil
- what if this IS true....?
- Cant use Amsoil till 3k?????
- I'm Sold on Havoline 20W-50
- Engine oiling system
- primary
- Stupid Oil Change Question on Dyna
- 60 weight oil in motor
- Syn3
- Oil Spattering out of Dipstick
- Wally World oil temp gauge for Evos
- GL-5 80W90 GearLube in Primary - OK?
- Wally's Cycle World oil temp gauge is all good now!!
- Syn3 oil change?
- To wait or not to wait?
- oil, synthetic or not
- Not much difference in oil properties
- Changing Fork Oil
- MOVED: oil line routing
- HD parts guy
- Which Amsoil Part # to use??
- Which Plug??
- cold or hot
- Ok, lets have a "do you fill your oil filter poll?"
- 91' Heritage Softail Spitting Oil
- Crazy ?
- Is This Possible?
- Oil cooler crash bars
- Engine oil
- Filling oil filter
- any raleigh nc folks out there, where are you getting your oil
- Mobil 1 15w50 In all Three Holes
