- 05 ultra..down some oil
- 1,000 mile change for FLSTCI
- WAHT LUBE WHERE
- changing oil
- Dexron III Mercon in Primary, yes/no???
- over filled a bit
- An educated guess
- Possible Oil Leak
- Drinking Problem?
- How much oil to put in
- HD Oil Cooler Installation
- First 5K oil change - a mess
- where to buy Mobil 1 VTwin Oil?
- clutch slipping
- Oil Pump Check Valve Repair
- Routing of EVO Oil Lines
- Changing Oil ?
- Wet Sumping Explained
- Synthetic Oils On Breakin
- PRIMARY OIL
- HD's premium oil filter or not?
- '59 Oil Line Routing
- Synthetics and Wet Clutches
- 500 mile switch to synthetic engine oil ok by consensus
- Primary and Tranny Oil in a 2004 Sportster
- Change fluids at 500 or 1000 miles on new deluxe?
- changing oil from one brand to another.
- Changing oil help
- 5000 mile service
- Checking Oil Level on Your Harley Davidson
- Oil Filters and Air Filters
- Engine vs Gear Oil
- Making Custom Oil Lines
- Checking the oil level
- Question on oil level please?
- Mobil 1 Synthetic Gear Oil ?
- Proper Motorcycle Oils Are Important
- Missing oil?
- Who Makes The Harley Oil & Chemicals
- Oil Filter Comparisons
- Primary Oil
- DIY Oil change Tips for First Timers
- Twin Cam Oil Pressure Issues
- Synthetics and Breaking In a Fresh Motor
- Keeping your COOL (oil coolers)
- Motorcycle vs Car oil
- 10 Micron vs 30 Micron Oil filters
- Crash Bar Oil Cooler
- HD Oils Made By ...
- AMSOIL 20W-50 MCV (new formulation)
- newbie question re EFI Stage 1
- Oil Pressure , Oil temp.
- HD Leaking Oil Cooler Adapter Fix
- How is this possible?
- 20W50 Royal Purple
- oil filters
- oil temp on sportys from H.D
- Stupid question du jour
- Returning to Dino oil from synthetic
- Drain ing the sump
- What oil comes in a new bike?
- newbie query: oil pressure and clutch question
- Ford ATF?
- Wet Sump Solution?
- 10W-40 VS 15W-50
- Can Synthetic replace regular oil?
- Mobile one in all three holes or not
- Is it okay for me to use Mobil 1 15w 50
- Oil question for Skip
- Shelf live of Type E Fork Oil
- Let's talk brake fluid
- Amsoil 20W-50 in all 3 Holes,or, not?
- Someone has to ask....
- MOVED: Oil Temp
- Royal Purple Motor lubricant
- HELP ... Oil fill cap blowing off
- First time Harley owner Question
- Oil Change Questions
- oil change/5000 mi check-up
- Oil Temp
- H-D's new synthetic blend...
- RevTech oil
- Red Line Oil for Transmission
- Harley's new fitment for Syn3 oil
- Gear oil?
- amsoil "Motorcycle" oil?
- Checking Oil
- $%&*#@!*$ Oil Leaks!!!
- MOVED: Dynacycle motor oil or not !
- Dynacycle motor oil or not !
- Oil leak CURE!
- Oil Filter Manufacturers
- 1K oil change and mileage increase with synthetic oil
- oil dipstick-lcd readout
- MOVED: Harley Website says you have to still change your Synthetic oil every 5000 miles, is it so?
- MOVED: Synthetic oil destroy's engines?
- oil leaks!
- Synthetic oil destroy's engines?
- MOVED: How many people have Oil coolers on there Softail Harley's
- Harley Website says you have to still change your Synthetic oil every 5000 miles, is it so?
- MOVED: Castrol Syntec
- OIL LEAK! HELP!
- Castrol Syntec
- oil lines
- Amsoil users...
- Primary oil question
- leaking oil
- chain lube
- MOVED: Oil Analyses Results
- Fork oil
- oil problems?
- Oil Analyses Results
- wrap-around oil tank with spin-on filter?
- When Checking the Level of....
- Primary Oil/Tranny Oil
- Addendum to earlier oil post
- To Synthetic Or Not to Synthetic
- shelf life for oil?
- Help! I have no crankcase oil?
- oil lamp will not illuminate
- 'Nother Dern Oil Topic!
- Oil Change at 500
- Oil Filter
- oil temp
- What kind of oil do you use in your Harley
- Ultra OiL Cooler
- Oil change time.
- Oil Leak Tale
- Synthetic vs. Petroleum Oil
- The Right Way to change your sporty's Oil Filter
- What oil anf filter to use on a 2005 1200R
- 18th Birthday & Oil Leak
- oil leak
- Oil Blow by
- Best Oil for your Harley
- amsoil synthetic ......anyone use?
- trans oil white & milky
- what type of oil?
- Brake Fluid - Newbie
