PDA
View Full Version : Oil Archive (no new posts)
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20
  1. Xr1200 air box oil leak
  2. New AZ HD rider
  3. 1981 Shovel head
  4. oil consumption and smell
  5. Winter Weight Oil ?
  6. Dual Oil Coolers
  7. 0 oil pressure, please help
  8. Mobile1 20w-50 Vs. Mobile1 SuperSyn 20w-50
  9. oil temp
  10. My FXSTC is making oil!
  11. 07 Ultra - Primary Oil in Starter
  12. twin cam 88: oil pump not pulling
  13. tight oil filter
  14. oil on air intake
  15. Redline back to Harley, do I need to flush?
  16. Feuling Oil Pump
  17. Alternating Synthetic Brands
  18. More geek talk call to Pennzoil
  19. Oil Filter Question for 2008 Nightster
  20. WARNING - Geek Talk wih Shell Tech today about Rotella 15W40
  21. Best Oil For The Pig
  22. Did the Winter oil change today...
  23. Getting New Bike This Weekend-Oil Change Before Storage?
  24. Best Transmission Oil Out There
  25. For those of you using Royal Purple....which one?
  26. Oil Pan/Gasket Change How To for Dyna Superglide
  27. Push rod covers leaking oil
  28. breather leaks oil\
  29. Anyone Know much about this Kendall Motor Oil?
  30. Amsoil SuperShift in tranny
  31. amsoil
  32. Oil drains out of tank into engine overnight
  33. How much for your Amsoil?
  34. oil temp gauge on handlebar /road king
  35. oil plug
  36. 2012 harley fat bob 1st oil change
  37. Winter Storage fluids question
  38. Oil Tank Install Question
  39. OUTLAW High Performance Oil Filter
  40. Normal Oil Consumption?
  41. :::UPDATE::: To Dumb Question thread in Dyna Section.
  42. didn't check engine oil
  43. Where Does Everyone Buy Red Line From?
  44. Is it OK to use a Drag Speciaties Oil Filter?
  45. Rotella Diesel oil
  46. Oil cooler leak for the 2nd time!!
  47. Oil pressure light on and off
  48. Low on Oil
  49. High Mileage Switch to Synthetics?
  50. Oil in primary case
  51. is my 1993 sportster 1200 primary oil level too high??
  52. Oil Pump VS Idle Question
  53. oil pressure but no flow
  54. oil pressure but no flow
  55. Should I remove primary chaincase cover?
  56. Save a fresh oil change?
  57. oil tank empty
  58. Same oil all 3 holes
  59. 1000 Nile Service Houston Texas
  60. Lucas Synthetic Oil
  61. oil filters
  62. Zero oil pressure or movement
  63. Smel of hot oil & smoke from exhaust Manifold
  64. Oil wight! Best oil for 2 mile rides to work and short distances around town?
  65. Oil Change - New to this site
  66. temperature and oil weight
  67. 2000 Harley Sportster XL1200C spitting oil out of breather tube [Pictures]
  68. using oil
  69. Engine light
  70. blowby rerouting kits
  71. Oil leaking
  72. 1991 fxsts primary oil level
  73. oil filters
  74. Do not use Valvoline Racing Oil in Primary
  75. Test oil pressure gauge..
  76. oil pressure
  77. Dino oil for winter storage
  78. TH exhaust in the way of checking oil
  79. Another noisy engine witha twist
  80. Oil in the display of your digital oil dipstick? Fix it!
  81. oil bubbles
  82. Evo softail oil
  83. 1996 fxdwg
  84. 2005 ultra clasic
  85. Changing types of oil
  86. softail oil tank mounts
  87. Oil on fins
  88. Too much oil Street Glide?
  89. Valve Clatter
  90. 2000 HD Sportster Motor Oil
  91. oil change
  92. Oil from breather tube when still.
  93. Engine Oil or Tansmission Oil
  94. Trans oil level
  95. Redline / Amsoil / Royal Purple / Syn 3 / Other
  96. She's blowin' oil!
  97. oil presure
  98. A Change to Synthetic
  99. oil pump
  100. Guys: What Do You Think Of This Additive
  101. How hot is to hot
  102. oil swap cause of valve ticking???
  103. oil drain plug location on 85 flht
  104. Outer Primary Leak
  105. Harley Oil Types (58, 75, 105) and SAE Grade
  106. Evac system
  107. Oil in air cleaner
  108. Oil tank/line info
  109. Where to Find Mobil1 V-Twin 20W50 in Canada
  110. What would You do?
  111. oil
  112. shovel oil cooler and external oil filter
  113. Same Price-M1 & Redline 20/50-Which to Buy?
  114. 1971 XLCH primary/trans oil question
  115. D & M floorboard oil coolers
  116. External oil cooler and filter hookup, shovelhead
  117. AeroShell Oil Sport PLUS 4
  118. leaking primary seal
  119. Checking oil level
  120. Scavenger oil change system
  121. Oil brands
  122. Did my Dealer do the right thing???
  123. 30K service interval question (RoadGlide)
  124. 1st Service 2012 Fat Boy Lucus Oil Products
  125. Void warrentee
  126. Oil plug
  127. Oil Grades
  128. Oil Filter
  129. Oil Mess
  130. 08 road king
  131. Oil leak
  132. Oil Change in 09 Road King
  133. 94' FXR Fluids
  134. Have any of you used this? "THE" Oil Fix
  135. Amsoil Propaganda
  136. Cut my filter open. Now what am I looking for ?
  137. Oil Type and filter
  138. Anyone using Motul oil?
  139. Advice Needed: At 1,000 miles is it too early for Synthetic oil?
  140. Derby cover
  141. Redline Motor Oil.....
  142. Wix Oil Filters now made in Mexico...
  143. K&N Oil Filter Part Number and Source?
  144. MAster Cilinder Oil leak
  145. Bike Runs HOT! 300° Oil temp
  146. Amsoil in your clutch? NEW BIKE
  147. warranty void non harley oil???
  148. Oil Stabilizer
  149. Oil change mistakes
  150. oil cap blowing off
  151. Reusable oil filter
  152. 20w-50 vs 20w-60
  153. 1989 Sportster 883 w/ 1200 kit
  154. My concerns with synthetic oils
  155. Wtf
  156. Oil Tank located under gear box dilemma
  157. Changing oil on 2011 dyna
  158. Walmart Stop Carrying Mobil 1 V Twin ?
  159. When to change OTHER fluids?
  160. Average oil temps
  161. Squealling clutch
  162. Oil Change = Power Loss
  163. Oil Pressure Gauge
  164. is this possible?
  165. LCD oil dipsticks
  166. FYI on Shaeffer oil
  167. How do I run my oil lines correctly on my 1952 panhead engine?
  168. The New Syn 3
  169. what is wrong with my 71 sportster 900
  170. digital oil dipstick
  171. Too much oil pressure on a 98 evo motor
  172. relief valve plug question
  173. Flashing Oil Light on my Road king?
  174. Valvoline VR1 synthetic 20w50
  175. oil cooler or engine fan
  176. Is Harley using a new oil supplier now?
  177. amsoil
  178. oil leak in front right side
  179. Checking oil - Bubbles/Foam
  180. lucas?
  181. 2000 UC-- dipstick question after oil change
  182. 86 FXRD oil filter
  183. Reg. oil vs. Synthetic Noise ?
  184. Why does my Road King drip?
  185. Filthy oil after change on neglected scoot...flush?
  186. Oil consumption - normal
  187. Oil Lines and TC oil tank
  188. Can oil pressure go to high?
  189. Just Changed Primary Oil.
  190. Blue Red Line
  191. How to Find Mobil 1 15w50 at Wal Mart
  192. Water in Tranny fluid?? Help!!
  193. UltraCool Oil Cooler
  194. a few questions
  195. Oil drips, blow-by, What is really the correct oil level?
  196. 1980 shovelhead drain plug?
  197. Softail oil change- makes a mess
  198. Oil and filter question
  199. Six speed trans oil
  200. Rotella T6
  201. Sportster 1200 1997 Transmission oil
  202. VR1 $2 off again at Autozone through end of May
  203. Mobil 1 V-Twin on Sale
  204. Primary Oil
  205. Duece oil change question
  206. NAPA Oil Filter on sale
  207. Red Line Shock Proof Trans oil
  208. New Mobil 1 Oil Filter?
  209. Oil drips, blow-by, What is really the correct oil level?
  210. Oil Change for 2007 Fatboy
  211. Transimission Fluid
  212. Oil in the Filter
  213. oil blow by
  214. Where to buy Heavy Shockproof?
  215. Oil coolers?
  216. 200.00 You got to be kidding!
  217. '89 Evo Engine Leaking Oil
  218. Oil from the breather
  219. Harley fluid specs., not an oil thread technically
  220. Synthetic oil, change with time, mileage, or both?
  221. Old time oil verbiage help
  222. Oil tank install/hookups
  223. when to change to synthetic
  224. "Motorcycle" or regular 20w50
  225. What about Mobil-1, Fully Synth. 15w50?
  226. Oil in Intake
  227. Ever hear of Dynacycle Oil?
  228. HD Syn 3 oil
  229. cream coloured froth in my oil tank
  230. How to test a oil temp sending unit?
  231. Oil Temp Reading-IR Thermometer
  232. Oil pressure sender for 78 Shovelhead?
  233. Gonna try Spectro-Oil products
  234. moving to synthetic in primary
  235. Fluids/gaskets change on a 1998 FLHTPi
  236. Advance auto mobile oil $8
  237. Last oil question, primary oil
  238. What's with Amsoil?
  239. what weight gear oil?
  240. From a '58 Porsche Magazine
  241. Flhx 1000 mile servcie decided on oil
  242. Oil Cooler?
  243. Oil change problem, tank overfilled
  244. Revtech Pure?
  245. Gaskets / O-Rings
  246. Another damn oil question?
  247. royal purple
  248. Redline
  249. I like my bel-ray Gear Saver Oils Best after all
  250. Confused?
