- The Art of Noise ( Mufflers)
- Exhaust and Harleys
- The Scoup On Heads
- Big Bore and Cam Install
- Head Porting For The Do It Yourselfer
- Engine Tuning Principles and Guidelines
- Finding An Intake Leak
- Cam Specs Chart
- RPM's vs MPH Calculator for All Bikes
- Exhaust System Facts
- Header Pipe Lengths
- Muffler Size and Effects
- EVO Ignitions
- Cams and Compression Pressures
- Too much cam...
- Engine RPM's vs MPH
- Selecting a Performance Camshaft For Your Riding Style
- Shovel Intake Manifold Alignment
- What To Check if Your Engine Fails to Start
- Learning To Read Spark Plugs
- Spark Plug Heat Range and Installation Facts
- Spark Plugs and Gapping Change Facts
- EVO CAM Specs
- Twin Cam CAM Specs
- Proper Engine Break-In by S&S
- Enricher Use Tip For Carbed Bikes
- Dual Plugged Head Ignition Changes
- Hard Starting Motor Tips
- Stage 1 Explained (2 of 2)
- Exhaust System Comparison/Explained
- EVO Cam Install
- Cam Chain Tensioner and Bearing swap
- Twin Cam CAM CHANGE with Pictures
- VOES Switch Explained
- Exhaust Blueing Fixes
- Tuning The Fuel Injected Motorcycle
- Engine Cuts Out...Ignition or Fuel?
- Twin Cam Performance Guide
- What's A Squish Band? (Engine head related)
- Proper Engine Warmup
- Exhaust Terms Explained
- More Power To You (How to get it)
- Starter Woes For Big Inchers
- Choke That Engine
- Preignition & Detonation explained
- Oil Puking at Startup
- Twin Cam Developement
- Dyno Truths & Lies
- Oil Venting & Solutions
- 2005 EFI to Carb Conversion
- A few words On Cams
- Oil Carryover In Air Cleaner
- Intake System Leaks
