PDA
View Full Version : Engine Mechanical Topics
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24 25 26 27 28 29 30 31
  1. Ticking fuel ejectors
  2. Can some help identify?
  3. Engine stand
  4. bike stumbles
  5. Burning oil
  6. New 1200 custom oil drips after ride
  7. Circlips source....
  8. S&s 124lc
  9. I need cam opinion
  10. Stock 103 (88,96) valve spring lift maximum?
  11. Connecting rod issue
  12. Andrews +4 in 103
  13. Rookie question
  14. Pushrods on 1980 Shovelhead
  15. Normal Valve noise, I think???
  16. Engine light
  17. Twin Cam Hydraulic Chain Tensioners
  18. things to look out for while checking my run out
  19. 2010 fxdb not starting
  20. 2010 fxdb not starting
  21. Bg dog
  22. Starter issue help needed
  23. Help Please, Need Opinions!!
  24. Oil Pressure Switch - does this look bad?
  25. Starting question, 10:1 compression
  26. cam bearing installer/puller recommendations?
  27. Cam switch and bearings
  28. Oil light came on temporarily - 08 Rocker
  29. 04 fatboy?
  30. 2010 Wide Glide front engine oil leak?
  31. First went to limp mode, now nothing!!
  32. What are these?
  33. SE 254e cams. Thoughts and comments
  34. Identifying parts
  35. Identifying parts
  36. 2010 ultra limited 103
  37. Darkhorse/S&S/WFO Larry 117" build time.
  38. 1988 fxsts jackshaft or starter problems.
  39. Cam shoes upgrade decisions
  40. Profiling cams
  41. S&S data and reviews for engines and kits?
  42. Can you ID these cams?
  43. Big bore break in issues 02 dyna...fueling??
  44. 107 Head & TB Suggestions
  45. 110 & Triple 8's
  46. Evo crate engine
  47. Where to get pistons flycut
  48. only on cylinder running please help!!
  49. How the F%$#.....
  50. Can someone help with my fuel line problem?
  51. Head removal with out disturbing base gaskets?
  52. Why is my front cylinder singing to me?
  53. Motor storage
  54. How to install Cam Tensioner
  55. Fxr problems
  56. Starting HD Heritage Softail Classic
  57. I dont know any different
  58. Tire shredder on a 13 Slim
  59. Heads
  60. I need intake suggestions. Complicated
  61. Smoking
  62. Adding the 110 cylinder kit ONLY to a Twin Cooled Rushmore
  63. 1973 shovelhead fx.-- oilpump shaft
  64. Humbled by my experience and seriously asking for advice
  65. UltraBD
  66. Spark Plugs
  67. 2009 FLHT crankshaft bearings
  68. Adjustable pushrod advantages
  69. Dynoed the build!
  70. Stage?? Results Breakout FXSB 2016
  71. Moisture in my oil?
  72. First Build 04 FXST
  73. Rocker Box
  74. Newbie Cam question
  75. Seized bolt in Evo rocker
  76. Cam swamp (stuck) mesh filter location?>
  77. Cam swap Blunder?
  78. Inexpensive 88 Upgrade
  79. Cam Plate Upgrade When Upgrading Cams 2013TC
  80. my 1994 883 to 1200 rear jug
  81. Cam poll: best low to mid torque
  82. Night Train Upgrade
  83. Baisley spring
  84. Instructions for HD to convert engines to automotive style connecting rods. Easy!!!!!
  85. Piston ring question
  86. O2 sensor on '17 ultra limited cvo
  87. Heartland Cam Bearing Tool Question
  88. Engine compatibility
  89. Chasing Engine Noise
  90. Trouble turning engine over after rebuild - Do I need ACR or S&S Easy Start Cam?
  91. Any comments about HD going to twin cam, then back to single cam?
  92. Another Loctite question...
  93. Pushrod Adjustment
  94. Not Idling
  95. Pump up lifters by hand?
  96. Cam install problem
  97. Odd valve train,noise after cams install
  98. 2005 Dyna using excessive oil.
  99. looking for a cam suggestions.
  100. Engine Temp Sensor
  101. My ironhead project
  102. Recommendations for head work and trottle body size for a 110" drop in kit
  103. '03 Sportster 1200S - Valve Spring Compression, Can't Re-Install Gears
  104. Best cam install kit?
  105. TTS150 in 110
  106. Yet another cam thread....
  107. Help! IAC module replacement.
  108. Which Cams ?
  109. '04 E Glide engine skipping
  110. 98" Kit Questions
  111. .030 head gasket / cam selection
  112. Changing crank. What about races and bearings?
  113. new M8 S/E 515 cam specs
  114. 1200 conversion pro tips
  115. Boggin down
  116. Hep - no oil to rockers??
  117. Changing Rocker Boxes
  118. 99 883 no spark, but has power. Trigger rotor?
  119. TC Tensioner Failure Prevention
  120. 259e cams in a 2012 103 street glide
  121. Will heads from a 2015 FLHX fit a 15 FLSTN?
  122. Screamin' EagleŽ Pro Crankcase Set
  123. 2017 Milwaukee eight street glide
  124. new to me bike with many motor upgrades
  125. My build
  126. Question about cams
  127. new 103" build!
  128. S&S 100" kit on 05 Heritage...
  129. 95 inch build list
  130. Check Engine Light on new 2016 Softail Slim S
  131. S&S push rod adjustment
  132. Engine noise
  133. Heavy breather swap
  134. 88 to 96 options
  135. 98" big bore
  136. Milwaukee Eight funny problem!!! Drunk enineers???
  137. 2002 dyna key problems
  138. 95 inch question
  139. Rebuilt carb now it won't even ie without dying
  140. Carb rebuild failure, help please
  141. S&S 583 case clearance
  142. TC88 cam kit recommendations
  143. Repurpose cams?
  144. Piston/ cylinder scoring
  145. missing and backfiring
  146. Breather assembly
  147. Why Replace Cam Bearings
  148. Head swap?
  149. Lower than expected cold crank compression
  150. 2016 FXDLS head gasket... rust?
  151. High Compression Spark Plug Cross Reference
  152. Carbureted twin cam sputtering and stalling at 60 + MPH
  153. Crank Run Out 96 CI Motors 2007
  154. What would you do
  155. 95" 11:1 compression producing big low end torque, is it possible?
  156. Head modifications?
  157. Dip in power curve?
  158. 88" to 96" top end
  159. 2000 touring, motor upgrade. 35,000 miles.
  160. Harley oil cooler adapter
  161. Starter motor not able to rev eng - cables smoking
  162. Swapping to thin head gasket on cammed TC96?
  163. jackshaft seal orientation
  164. Engine coming apart...upgrade device??
  165. I had a knock in the front cylinder....
  166. Socket size?
  167. SE259e vs SE585
  168. 2016 RGS stage IV tire shredder with no labor cost??
  169. CV Carburetor Problems
  170. Cam Choice for 107" build ??
  171. 103" jugs on a 96"? What do I need?
  172. S&S Cam's - Easy Start or No?
  173. Melling JB-2079
  174. Cam choice options
  175. Se 204 cam reversion
  176. Plans for 107"
  177. 1997 cam cover removal
  178. Which HD 110 kit for my Ultra?
  179. Piston ring orientation problem?
  180. New build and now engine clatter
  181. another 103" build question
  182. Rockout inserts, 2014 FLHTK
  183. need to upgrade the cam in my 2013 ultra
  184. I Guess It's About Time To Start My Own Thread
  185. How much did each extra HP cost you? About engine mods.
  186. Lifter or valve clicking after battery replacement
  187. FM 107 vs Revolution Perm. 107
  188. 2006 FXD Rockerbox Gasket Issues
  189. 2002 FLHTCI 117 CI build
  190. Heads on the low rider s (and other s bikes)
  191. Wet head?
  192. I was told it is sumping but i dont know
  193. 83 xls 1000 is backfiring/stalling out after start up
  194. M8 Heads on a TC
  195. Twin Cam Timing & "punch marks"?
  196. cam chain tensinors inspection
  197. Cams for 2007 Stage I Fatboy 96ci
  198. 77 shovel rebuild
  199. Bad Piston, Losing Oil...
  200. Keep SE 204 or change to 57h
  201. Engine does not start.
  202. Aftermarket Oil Coolers For Twin Cam 103
  203. 11 Limited Tear down
  204. SE adjustables 24 TPI
  205. Identify parts from box
  206. twin cam 88 vs 88b displacement
  207. SE 103 Stage IV Kit
  208. Andrews 288157 fits stock 99-06 chain or SE 25284-11 plate?
  209. 07 engine in 01 softtail frame
  210. Fuel Moto build complete
  211. TP 113 what to do
  212. Another 2007 Crank
  213. S&S 95" hot set up
  214. M8 bolt in cam
  215. M8 Stage I Upgrade
  216. Tc88B engine build question
  217. Rick
  218. Cam spacers
  219. 95" bagger cam choices
  220. Expectations
  221. S&S kit 124 build, care to share experience?
  222. Cams in a Fatboy S
  223. Who uses non-Harley filter and which one? Got Mobil M1-102
  224. Rocker Cover Install
  225. How to turn crack manually? (except rear wheel)
  226. Cam Tensioner
  227. TC88B Tensioner Shoe Job
  228. rear cylinder not firing
  229. Can tensioners
  230. Ultima 113 head gasket
  231. Basic CID questions...
  232. S&S MR103 Cams & Stock Valve Springs
  233. Not so "Good Vibrations"!
  234. Proof/Thunder Jets Work.....
  235. S&S Performance Oil
  236. Cylinder head porting....
  237. Another Shovelhead motor question. This time....pistons
  238. B 2303 R. Johnson hi lift high rev EVO
  239. Most cost effective way to build a bottom end
  240. Post lifter install question
  241. Evo stroker 103
  242. Need some help.
  243. 1996 EVO carb Motor work in an FI Bike
  244. Cam install
  245. Yellow fluid in trans..?
  246. FNG here
  247. 96 to 103 in a '07 Street Bob
  248. What Would Be Considered Normal
  249. Evo style engine serial number
  250. Twin Cam 88" build-Cam questions
